Faster forward or better steering
ruckb
Post Thu Dec 05, 2013 7:19 pm
I have no trouble in connecting to serviio from my 46PFL8685K.
but the steering functionality is not acceptable.
there are only "Fast forward" and "Faster forward" available on the TV. But even with the fastest forward it takes 15 minutes to go 60minutes real time.
So if you stop in the middle of a movie you need to wait 15-20 minutes to get there again.
The additional poblem: if you hit the outer ring of the Remote instead of the inner one you jump to the next movie .. And then you need to re-start "fast" forwarding on the original movie again.
Is this a problem of my Philips TV or maybe some setting in the streaming configuration ?
thanks and regards
Hermann
Post Thu Dec 05, 2013 9:09 pm
Re: Faster forward or better steering
Looks like this is the way it's been implemented on the TV. try to contact them.
ruckb
Post Fri Dec 06, 2013 9:34 am
Thanks for the fast feedback.
Does anybody have some feedback how this is working on other Philips TV's ?
I have opened a thread in the philips forum. Let's see what comes back there.
I can not imagine that I'm the only one you thinks this is not usable.
So I would be interested how this could/should work on other Philips TVs.
Is there any option to jump to a specific time or is the normal forwarding faster ?
Thanks and regrds
Hermann
Joan Murt
Post Tue Dec 24, 2013 6:41 am
Exactly the same here... :(
Probably the best would be streaming the VLC contents to your TV, if you do that you could probably search in the vlc and then see what you want in your TV.
Return to Philips
