Serviio 1.3.1 - Unexpected Error 500
tvjunkie
Post Wed Dec 11, 2013 7:33 pm
As of yesterday, Serviio has seized to recognize any of my device. After I reboot the computer, the server appears to recognize the shared devices right away, however, after a couple minutes, it just de-list the devices the list and that panel is blank. After I try restarting the program, I get an "unexpected error (500) check the log". I am not sure what is causing this.
The program shows the server continues to run, but all the devices then disappear after I try to access a couple folders. The only way I can get it to work again is to reboot the pc.
I've attached the program logs for reference. Thanks in advance.
Serviio log
(383.72 KiB) Downloaded 314 times
Post Thu Dec 12, 2013 5:26 pm
Re: Serviio 1.3.1 - Unexpected Error 500
Looks like the database got corrupted, try to reinstall Serviio.
tvjunkie
Post Thu Dec 12, 2013 5:46 pm
What is the proper way to re-install? Shall I uninstall and delete hidden folders, registry entries, and anything else associated with the program as well?
Post Fri Dec 13, 2013 2:32 pm
Just uninstall and then install it again.
