New update now no connection
foxhole
Post Tue Dec 24, 2013 10:30 pm
Updated servio to latest 1.4 now no devices can 'see' serviio.?
avion
Post Wed Dec 25, 2013 10:20 pm
Re: New update now no connection
I had a similar problem after going from 1.3 to 1.4
I have 2 Samsung TVs - A UA55D8000 and a UA32ES5500. (so a D series and an E series)
Neither will see my video files unless I tell Serviio that they are both "Samsung TV (A-series)" in the Renderer profile under the status tab in the console.
Under v1.3 i had he appropriate profile for each TV selected and that worked fine, but seems broken in 1.4
Post Wed Dec 25, 2013 11:43 pm
The only thing I can see in the CD and EF profiles (that isn't in the A profile) that could potentially affect the device seeing Serviio is the lines:
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
You could try removing these (one at a time, and then both) and seeing if that improves things. Remember to restart your PC after changing profiles.xml.
foxhole
Post Thu Dec 26, 2013 1:38 pm
Ok will try, my samsung are e or f series but the playstation 3 is also affected.?
foxhole
Post Mon Dec 30, 2013 2:28 pm
Well not touched settings but all resoveled, seem that Serviio is just inconsistant, sometimes it works other times nothing.
foxhole
Post Sat Jan 04, 2014 9:14 pm
Where can I download 1.3 version the 1.4 has too many problem, crashes etc.
Post Sun Jan 05, 2014 3:16 am
http://download.serviio.org/releases/se ... -setup.exe
However, I haven't experienced any of these crashes or inconsistencies. 1.4 has been as stable as a rock for me. Have you checked you are running the latest java version?
foxhole
Post Sun Jan 05, 2014 10:17 am
Have latest java, every movie playback seem to scrabble picture at about 20mins into it. Whatever the format.
Users browsing this forum: No registered users and 50 guests
