How to install serviio on DS214 play
simonxy
Post Mon Dec 30, 2013 11:00 am
I have Synology DS214play.
I have successfully installed Serviio package 1.4.0-0024 and Servio Web UI.
Then i have opened port 23424(TCP) on my router. I can ping it from any of my computers.
When I open Serviio Web UI on my NAS, there is green for server status. When i would like to add my shared folder to library, I can't see any and also can't type inside to add it manually.
(serviio user has read/write permission on my movies folder: DS/VIDEO/)
The I have installed servio console on one of my computers. When I opened it, there is a message: Cannot connect to Serviio server, it does not seem to be running.
What I'm doing wrong? Are there some instructions how to correctly set the server on some NAS?
thanks,
Iveky
Post Mon Dec 30, 2013 12:19 pm
Re: How to install serviio on DS214 play
you need proper settings for console on other one, or use serviidroid on android phone?
simonxy
Post Mon Dec 30, 2013 1:15 pm
I have tried everything but with no success. I have inserted the following line on my local computer vmoptions file of serviio:
-Dserviio.remoteHost=192.168.11.50
This is local IP of my NAS. The computer is also in local network.
If i open console from web on my local computer(http://192.168.11.50:23424/mediabrowser/#/login) then It seems to work, I get a page, but there is password requested.
Then I have tried to insert new password from serviio Web UI which is installed on my NAS.
There is some external address requested.
I have tried with my static external address from my provider, with local router IP address or local NAS IP address. But without success.
I have always got an error, when clicked on: Check connectivity status.
If I go to http://192.168.11.50:23424/cds/application, I get the following xml file:
<application>
<version>1.4</version>
<edition>PRO</edition>
<license>
<type>EVALUATION</type>
<expiresInMinutes>21475</expiresInMinutes>
</license>
<databaseUpdateId>12a7cf7481a6491c8b1c032b2cc656d0</databaseUpdateId>
</application>
And i still have problems with adding local folder. When I click on Add local, I don't see any folder to select. Any idea?
simonxy
Post Mon Dec 30, 2013 1:39 pm
It works now.
I can open console from local computer and manage settings.
I can open servio Web UI from NAS.
I can open mediabrowser from any computer inside or outside of my LAN.
(Intersting is that I get a red cross when I click check connectivity from console or error from WEB UI from NAS. But it works now :) )
Now I need to add folder.
I have shared folder with all rights to everyone on: "/volume1/video/"
From Web UI on NAS I can add only local folders. If I click add folder, I have no folder to add.
But from console on my local computer, i have 2 buttons: add local or add path.
If I click add local there and point to network shared location "\\DSZUPAN\video", the path is automatically changed to this:
/volume1/homes/serviio/\\DSZUPAN\video
How can I add folder with location: /volume1/video/
Iveky
Post Mon Dec 30, 2013 2:53 pm
i use remote console, and without problems add remote (server's) local paths like:
/diskSDB/FolderMKVs
i add them as 'local', i TYPE it, I can't CHOOSE it.....
