Sharp Aquos profile update
funguide
Post Wed Jan 01, 2014 9:03 pm
Do you guys think we can get an updated profile for the sharp. There are some video files that dont playback and I think its mostly a transcoding issue.
This is the profile for Sharp AQUOS LC 60LE655U
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8C100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/mpeg:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/mp4:*,
http-get:*:video/3gpp:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/quicktime:*,
http-get:*:video/avi:*
funguide
Post Sat Jan 04, 2014 1:47 am
Re: Sharp Aquos profile update
Does the above mean that ac3 codec is not supported?
funguide
Post Sat Jan 04, 2014 10:57 pm
I did some checking up with VLC. It seems the tv plays "AVC_TS_MP_HD_AC3_ISO" but it doesn't play "AVC_TS_MP_SD_AC3_ISO". Does anyone have a solution for this?
This file plays:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://192.168.2.4:8895/resource/100
0000240006905/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL"
[mpegts @ 003FECA0] max_analyze_duration 5000000 reached at 5024000 microseconds
Input #0, mpegts, from 'http://192.168.2.4:8895/resource/1000000240006905/MEDIA_
ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL':
  Duration: N/A, start: 1.407667, bitrate: 384 kb/s
  Program 1
      service_name    : Service01
      service_provider: FFmpeg
    Stream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 12
80x536 [SAR 1:1 DAR 160:67], 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
    Stream #0:1[0x101]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo,
fltp, 384 kb/s
While this file doesnt
0000240005504/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL"
[mpegts @ 01C8ECA0] max_analyze_duration 5000000 reached at 5003333 microseconds
Input #0, mpegts, from 'http://192.168.2.4:8895/resource/1000000240005504/MEDIA_
ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL':
  Duration: N/A, start: 1.400000, bitrate: 384 kb/s
  Program 1
    Stream #0:0[0x100]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 63
6x264 [SAR 1:1 DAR 53:22], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
fltp, 384 kb/s
Users browsing this forum: Baidu [Spider] and 13 guests
