24Bit/192KHz FLAC Audio Streaming
Laz Baz
Post Sat Jan 04, 2014 11:22 pm
I am using Serviio to stream 24Bit/96KHz FLAC audio files to my Receiver. This Receiver is not capable of playing streamed 24Bit/192KHz FLAC audio file.
Is Serviio capable of streaming 24Bit/192KHz Flac audio file? If it is I want to buy a Receiver that is capable of playing streamed 24bi/192KHz FLAC audio file.
I would like your help.
Regards
Samsung UE55JU7000; Panasonic BDT 110; Cambridge Audio 640; IMF TLS80 Mk II front & Yamaha centre & surround speakers
TMPatrak
Post Thu Jan 30, 2014 2:54 pm
Re: 24Bit/192KHz FLAC Audio Streaming
Dear all,
I am happy I have just found the exact question I am looking an answer for! Unfortunatly, nobody replied :(
I am just giving it another shot!
In my case, I have already an amplifier (a Yamaha RN-500) who handles DLNA and Flac up to 24bits / 192kHz stream and I am wondering if Serviio is the right tool to help me streaming my HD Flac from my computer to my amplifier
Thank you very much for helping! :mrgreen:
Best regards,
Pat
Post Fri Jan 31, 2014 5:00 am
Moving post to Support & Help where you may get better responses.
Wirehead
Post Fri Jan 31, 2014 11:56 am
Afaik, Serviio only handles up to 48kHz sampling. Do correct me if I'm wrong. I get warnings in the log file if I try to play files with a higher sampling rate than that without transcoding.
Tamefox
Post Sat Dec 19, 2015 10:43 pm
I also want to stream 24/192 FLAC files to various DLNA devices - can Serviio stream at this rate without transcoding down? (Assuming of course that the DLNA Renderer device can handle 24/192).
Post Sun Dec 20, 2015 1:23 am
You got me curious, so I downloaded a 24/192 test file from http://www.linnrecords.com/linn-downloa ... files.aspx and it streamed it via Serviio natively to my Yamaha RX-V500D (which has native support for 24/192). No transcoding.
So yes is the answer.
Users browsing this forum: Google [Bot] and 20 guests
