genre and not updated meta data
sparx
Post Sun Jan 05, 2014 3:05 pm
I use swisscenter to set the genre of my movies, (since I have not found a better simpler alternative)
However, I have a number of movies with updated xml files with right genre. However Servio does not see this, and puts the files in genre "unknown"?
How can I make serviio see it?
I have tried the "rescan metadata button"
I have tried force library refresh
but still remains unknown, how do I fix?
Post Mon Jan 06, 2014 8:29 am
Re: genre and not updated meta data
Can you raise a bug on bitbucket and attach the metadata file to it?
sparx
Post Mon Jan 06, 2014 1:46 pm
sure, how do I do that, bitbucket?
sparx
Post Fri Jan 17, 2014 3:01 pm
where do I find bitbucket?
Post Fri Jan 17, 2014 11:13 pm
Return to Panasonic
