How to config Serviio?
alis5
Post Sun Jan 12, 2014 8:57 am
Hello, I have installed Serviio on my Ubuntu server.
But how do I configurate it? I can't find any configuration-file. And how do I log into it?
I'm using Ubuntu 12.04-server. So I don't have a monitor to it, I only talk to it through SSH.
Post Sun Jan 12, 2014 9:29 am
Re: How to config Serviio?
you are running serviio headless. You need to install the console on another computer that has a monitor and then you can configure it.
http://wiki.serviio.org/doku.php?id=how ... buntu12-04
alis5
Post Sun Jan 12, 2014 10:24 am
Hello Moltra,
Thanks for the help.
I'm guessing that you refer to installation part 4 here. Where I should change something on my C/program.... But I haven't got kanything on my Windows machine, only on the Ubuntu server. What should I download on my Windows machine? A link there would be helpfull. :roll:
Post Sun Jan 12, 2014 10:33 am
Download Serviio 1.4 for windows, and when you install it, select just the console. You can then edit C:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions as described in the wiki to point the console at your server.
alis5
Post Sun Jan 12, 2014 11:47 am
Thanks again for the help.
But things still keep messing with me. :x
Nothing happens when I start to open Serviio Console (on my Win 7, 64bit).
At the first atempt it took a while and after that it told me it couldn't find the server (I was a little bit to fast and forgott to add the lines in "ServiioConsole.exe.vmoptions".
But after adding the lines here (and changed tp my servers ip), nothing happens when I klick the serviio console.
This file "ServiioConsole.exe.vmoptions" is empty. Should it be that?
At installation I unchecked the server edition, and kept the client and "top thing" (think it was about some libriries).
I haven't installed it on my C-drive (it's a small SSD, so I try to not install programs there). But I guess that this shouldn't do anything.
Any suggestons on what to do?
alis5
Post Sun Jan 12, 2014 5:18 pm
I found a log-file fron Serviio, it says:
2014-01-12 17:05:12,654 INFO [ServiioConsole] Initializing Serviio Console
2014-01-12 17:05:12,668 INFO [ServiioConsole] Starting Serviio Console
2014-01-12 17:05:12,722 INFO [ServiioConsole] Connecting to Serviio REST on 192.168.0.100:23423
2014-01-12 17:05:13,474 INFO [Messages] Loaded console message bundle for locale: en
2014-01-12 17:05:13,772 WARN [ServiioConsole] Serviio server version is 1.2.1, ServiioConsole version is 1.4. They might not be compatible.
2014-01-12 17:05:17,069 ERROR [ServiioConsole] Unexpected exception occured: null
at org.serviio.ui.view.swing.StatusView.initComponents(StatusView.java:150)
at org.serviio.ui.view.swing.StatusView.<init>(StatusView.java:108)
at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:72)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:116)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2014-01-12 17:05:17,071 INFO [ServiioConsole] Exitting Serviio Console
The console is 1.4 and server 1.2.1 is this a problem? How come I can get wrong realises when I download them the same day?
Or is it a java error? If so, on windows (client) or Ubuntu (server)?
Any suggestions?
Post Sun Jan 12, 2014 5:34 pm
Iveky
Post Sun Jan 12, 2014 6:49 pm
if you have graphical interface on your server, then you can run local console on ubuntu server... console script is in folder /bin, but i like to use remote console from my android phone.
alis5
Post Sun Jan 12, 2014 6:55 pm
Thanks, now I got that up and running as well.
But I still have one question.
As I mention earlier, I have an Ubuntu-server (running 24/7) where the movies are on. How do I point up those folders in the windows console?
I tried /\\localhost\Private\movies\ but that didn't work. How do I tell it to look on the server (that have serviio-server running)?
Iveky
Post Sun Jan 12, 2014 10:35 pm
like this:
/disk.2TB/Music
(local linux folders)
Users browsing this forum: Google [Bot] and 27 guests
