Issues with Denon CEOL Piccolo
Sheriff Hobbes
Post Fri Jan 24, 2014 5:53 am
I'm using Serviio to listen to my MP3 collection with the Denon CEOL Piccolo multimedia device. The music plays fine, but two features don't work: pause and search. When I press the pause button on the remote, nothing happens. Next and previous title do work. When I press the search button and I type in a word that I know is part of the artist's MP3 Idv2 tag, no results are displayed. I've uploaded the seviio log with debug option. Since it was 20 MB in size, I stripped it down to the point where the music file is being requested.
I'm using Serviio 1.4 Pro on Windows Server 2003 R2 SP2, Java 6 U45.
Another issue I have when logging off from Windows: Serviio console doesn't close and Windows asks me if I want to kill the task. To avoid this behavior, I need to quit the Serviio console manually first.
Thanks,
SH
(4.83 KiB) Downloaded 362 times
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Post Fri Jan 24, 2014 5:27 pm
Re: Issues with Denon CEOL Piccolo
Search is not supported in Serviio.
Pause should work, so it seems like the device's problem.
Sheriff Hobbes
Post Sun Jan 26, 2014 10:04 am
Hi zip,
according to Denon they support it also:
http://denon.custhelp.com/app/answers/detail/a_id/1760
Sorry, didn't find this page in English.
Did you implement the pause function according to the DLNA specification?
Did you have a look at the log?
Thanks,
SH
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Sheriff Hobbes
Post Mon Jan 27, 2014 5:15 pm
I tested my device with Mezzmo today, which worked perfectly on the PAUSE function. This is a Serviio issue, please fix it!
-engagement ring
-wedding ring
-suffering
H. L. Mencken
