Hisense TV - DLNA Renderer not working
ttca
Post Fri Feb 07, 2014 2:08 pm
Hi
I am trying to get a 2013 Hisense TV working with a PC DLNA server , but had no real luck, even not with Serviio(v1.2.1).
Browsing files works fine for most DLNA servers. Playing media files mostly does not work (works with some mp3 files).
I tested with different profiles (per default: generic profile is choosen).
So I switched on serviio debug log. Here are the User-Agent strings:
For Browsing:
POST /serviceControl HTTP/1.1, headers = [Host: 192.168.100.110:8895,User-Agent: AwoX/1.1 UPnP/1.0 DLNADOC/1.50,SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse",Content-Type: text/xml; charset="utf-8",Content-Length: 463]]
For Rendering:
GET /resource/30485/MEDIA_ITEM/MPEG_PS_PAL-0/ORIGINAL HTTP/1.1, headers = [Connection: TE, close,TE: trailers,Host: 192.168.100.110:8895,User-Agent: GStreamer neonhttpsrc,icy-metadata: 1]]
2014-02-05 23:21:29,975 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.122
2014-02-05 23:21:40,272 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
It seems, that serviio even delivers the video, but the player has problems ??
Has anyone a working profile or other solution for these User-Agents/Hisense TV?
xr5adam
Post Tue Feb 11, 2014 10:10 am
Re: Hisense TV - DLNA Renderer not working
I know it is not much help, But I also have the same TV and whilst not working perfectly I can stream all content to the TV with the profile Vizio TV, the only downside I find with this profile is I can not fast forward more than 2x, there is no time display and as such I can not use the time skip feature. I have experimented with other profiles and and some will allow the display of time and correct searching etc, not all formats will play, even though if I use the same format via USB stick it will play.
The server is connected by Ethernet so bandwidth is not an issue. I have tried countless times to create a profile with no luck
Post Tue Feb 11, 2014 10:41 am
Are you able to get sink information for the device: see viewtopic.php?f=5&t=19
xr5adam
Post Tue Feb 11, 2014 1:45 pm
Here it is
_________________________________________
http-get:*:audio/wav:*,http-get:*:audio/wave:*,http-get:*:audio/x-wav:*,http-get:*:audio/mpeg:*,http-get:*:audio/x-mpeg:*,http-get:*:audio/mp1:*,http-get:*:audio/aac:*,http-get:*:audio/flac:*,http-get:*:audio/x-flac:*,http-get:*:audio/m4a:*,http-get:*:audio/mp4:*,http-get:*:audio/x-m4a:*,http-get:*:audio/vorbis:*,http-get:*:audio/ogg:*,http-get:*:audio/x-ogg:*,http-get:*:audio/x-scpls:*,http-get:*:audio/L16;rate=11025;channels=1:*,http-get:*:audio/L16;rate=22050;channels=1:*,http-get:*:audio/L16;rate=44100;channels=1:*,http-get:*:audio/L16;rate=48000;channels=1:*,http-get:*:audio/L16;rate=88200;channels=1:*,http-get:*:audio/L16;rate=96000;channels=1:*,http-get:*:audio/L16;rate=176400;channels=1:*,http-get:*:audio/L16;rate=192000;channels=1:*,http-get:*:audio/L16;rate=11025;channels=2:*,http-get:*:audio/L16;rate=22050;channels=2:*,http-get:*:audio/L16;rate=44100;channels=2:*,http-get:*:audio/L16;rate=48000;channels=2:*,http-get:*:audio/L16;rate=88200;channels=2:*,http-get:*:audio/L16;rate=96000;channels=2:*,http-get:*:audio/L16;rate=176400;channels=2:*,http-get:*:audio/L16;rate=192000;channels=2:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/mpeg2:*,http-get:*:video/mp2t:*,http-get:*:video/mpeg:*,http-get:*:video/x-m4v:*,http-get:*:video/mp4v-es:*,http-get:*:video/mp4:*,http-get:*:video/quicktime:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-ms-asf:*,http-get:*:video/x-ms-video:*,http-get:*:video/divx:*,http-get:*:video/vnd.divx:*,http-get:*:video/x-divx:*,http-get:*:video/x-ms-avi:*,http-get:*:video/avi:*,http-get:*:video/x-msvideo:*,http-get:*:video/x-mkv:*,http-get:*:video/mkv:*,http-get:*:video/x-matroska:*,http-get:*:video/ogg:*,http-get:*:video/3gpp:*,http-get:*:video/webm:*,http-get:*:video/x-flv:*,http-get:*:video/flv:*,http-get:*:video/wtv:*,http-get:*:application/vnd.rn-realmedia-vbr:*,http-get:*:video/vnd.rn-realvideo:*,http-get:*:application/vnd.rn-realmedia:*,http-get:*:image/mpo:*,http-get:*:image/bmp:*,http-get:*:image/gif:*,http-get:*:image/jpeg:*,http-get:*:image/png:*,http-get:*:image/jpg:*
_____________________________________________
Makes no sense at all to me...
Users browsing this forum: Baidu [Spider], Google [Bot] and 30 guests
