Online Resources
hatton33
Post Sat Feb 15, 2014 12:19 am
Online Resources
Hi
When are we going to see the development on the plugins section get up to date? I bought and used serviio originally not just for media located at home but also for web resources. The forum now shows that pretty much all plugins are dead and all of them which were popular have reached a dead end as no developers can use the streams available.
The improvements made to serviio over the last year are good, but for me, it's got to a point where the things that are broken are not being fixed / updated. There are many alternatives to serviio which offer the same current working functionality. I just don't understand why the plugins area isn't one area being looked at when surely it was one of its main selling points.
Iveky
Post Sat Feb 15, 2014 6:41 am
Re: Online Resources
in order to keep some plugin working, author need constant time for it, he had once that time (and made it) but now not, can you accept it?
time=money (he need for living)
Post Sat Feb 15, 2014 6:16 pm
I'm trying to look at those written by me, but otherwise plugins are a community effort, so if someone wants to pick up fixing then, it's obviously encouraged.
hatton33
Post Sun Feb 16, 2014 12:44 pm
Sure, understood. But a look at each thread, most of them have a comment from JHB50 to say that in order to work, they "requires a modified version of librtmp that Serviio's ffmpeg does not include." So what I'm requesting is that this is included so that we can start looking at these plugins. To be honest, I've looked at the guidance and I struggle with writing groovy files.
Post Sun Feb 16, 2014 12:52 pm
AFAIK, the updated librtmp might have some code, that is not entirely legal (copyright), so I cannot distribute it.
hatton33
Post Sun Feb 16, 2014 7:30 pm
Fair enough - is the any way we could do this as users without you distributing it? I've had a look and can't see anywhere where it is stated is copyrighted but in addition, software like XBMC are using these files without any issues as far as I can tell.
Iveky
Post Sun Feb 16, 2014 9:41 pm
this below is ffmpeg from fedora 20, is this version capable to receive rtmp://address:port from internet?
ffmpeg version 2.1.3 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jan 25 2014 15:11:42 with gcc 4.8.2 (GCC) 20131212 (Red Hat 4.8.2-7)
  configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-frei0r --enable-gnutls --enable-libass --enable-libcdio --enable-libcelt --enable-libdc1394 --disable-indev=jack --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-openal --enable-libopencv --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab --enable-avfilter --enable-avresample --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect
  libavutil      52. 48.101 / 52. 48.101
  libavcodec     55. 39.101 / 55. 39.101
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libavresample   1.  1.  0 /  1.  1.  0
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
hatton33
Post Tue Feb 18, 2014 7:42 am
It's more the file from here I believe.
http://www.ffmpeg.org/doxygen/trunk/lib ... ource.html
Zip - I've hunted high and low and cannot find anything to back up your claims of it breaching copyright or being illegal in any way. Is this just a route you do not want to look at?
Post Tue Feb 18, 2014 5:16 pm
Perhaps it's a different issue. There is a build of librtmp around that has some dodgy code in it, but is not a part of the main librtmp repository. Not sure if this is the case here or it's actually completely different code.
hatton33
Post Tue Feb 18, 2014 9:30 pm
Are you happy to look at including this then?
Xmantium
Post Thu Feb 20, 2014 12:56 am
Theres an unnoffical build thats makes Handshake 10 work but Adobe have deemed it to be not legal and have taken down most download repo/sources with it.
Its been covered here - viewtopic.php?f=22&t=3995&start=40#p44729
The legal source can be found here git://git.ffmpeg.org/rtmpdump
Post Thu Feb 20, 2014 2:55 am
Using a modified version of librtmp will not fix the problem. Most of the webpages providing these streams, fund their stream capture servers with advertising revenue, which they lose when plugins hijack the streams and circumvent the webpages. As a result when they see such activity they make changes to further hide their streams causing the plugins to break again. Many of these changes require further changes to librtmp, or the use of other utilities to determine new algorithms or keys. The plugin maintenance load is never ending so many authors have simply been unable to keep up, or have evolved solutions for their own use that are simply to complex to explain and support for the average Serviio user.
The solution for the average user is to use the wiki method http://wiki.serviio.org/doku.php?id=stream_pc and stream the web page to via Serviio to your TV. That way, you get the stream, they get the revenue, and the plugin author can take a break. Of course you can always put in a bit of effort and learn to write your own plugins, and maintain them each day, for the benefit of all the other users :-)
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 18 guests
