Rewind and Fast Forward
I am using Serviio with my PS3. I cant seem to fast forward or rewind my content. Is this normal? Is there something I can do to fix this?
DenyAll wrote:One thing I forgot to mention - for me the biggest issue is mkv files. If you are keen you can repackage these into an mp4 container using ffmpeg by running the command:"C:\Program Files\Serviio\lib\ffmpeg.exe" -i srcfile.mkv -vcodec copy -acodec copy destfile.mp4
substituting srcfile and destfile for your file name (and check that ffmpeg is located in the same folder as mine, or adjust accordingly). This is a reasonably quick process that then gives you a new mp4 file that supports full scanning on the PS3 (without any quality loss). Works with my mkv files (but I won't guarantee it will work with all - depends on what video and audio codecs are being used, and subtitles etc in the mkv's).
