support serie F (2013)
Manala
Post Thu Feb 06, 2014 7:14 pm
Re: support serie F (2013)
estux wrote:I think that serviio should create custom thumbnails for each client device, using the profile settings.
I think that would require senseless amounts of developing time, all taken away from more crucial matters. Those thumbnails look fine enough for me, it's not a photo gallery after all.
charsher47
Post Fri Feb 28, 2014 11:42 pm
I have a UN60F7500 running Serviio Pro 1.4 and any file that I transcode to play doesn't allow me to pause or seek, I just get "Not Available". Can anyone else with an F-Series confirm whether or not they can pause or seek transcoded material using the E/F profile?
shpak_evgen
Post Fri Mar 14, 2014 1:01 pm
finally!!! with latest serviio update (1.4.1) my samsung UE55F6400 works as well, as i want!!! it's just work!!!
the serviio is best, again!!!
Thanks! :-)
TheSwede86
Post Tue Apr 29, 2014 8:41 pm
I am having problems getting thumbnails to work.
Using SABnzbd w. Sickbeard and Couchpotato and just updated to Serviio 1.4.1.2 on my Zyxel NSA325 and it works great although it does not generate thumbnails on my UE46F6475 running F/W 1119 (latest as per 2014-04-29).
I have set the correct DLNA-profile "Samsung TV F-series" under "Status", checked the "Retrieve descriptive metadata" under "Library" and it does not generate any.
Under the "Metadata" tab everything is default, I tried forcing a metadata refresh and the log on my NAS only shows this:
"2014-04-29 20:25:51,850 INFO [LibraryManager] Forcing metadata update for 'VIDEO' media files"
and nothing else.
I have NOT downloaded the "dcraw" package if that is used by the NAS to generate thumbnails (if they are in RAW-format by default, if anybody knows that?).
Edit:
Another question which I might open a new post about is that when I try to play a certain movie (its only one out of perhaps 15?) then the TV RESTARTS haha?
It actually restarts, when I try to play it then it says "Loading" with a spinning circle and then the circle freezes and the restart occurs.
I have played file way bigger (in size) and it is the same file-format (or at least it says it is) as every other movie (x-matroska).
Any ideas why?
Here are somethings that might shed some light on the behavior in the log:
2014-04-29 20:05:07,013 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 1.2.1 Copyright (c) 2000-2013 the FFmpeg developers
2014-04-29 20:05:07,014 WARN  [FFMPEGWrapper] FFmpeg is not compiled with librtmp support, RTMP streaming will not work.
2014-04-29 20:05:07,015 WARN  [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2014-04-29 20:05:07,048 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
java.io.IOException: Cannot run program "dcraw": error=2, No such file or directory
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041)
   at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
   at java.lang.UNIXProcess.forkAndExec(Native Method)
   at java.lang.UNIXProcess.<init>(UNIXProcess.java:135)
   at java.lang.ProcessImpl.start(ProcessImpl.java:130)
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022)
   ... 1 more
2014-04-29 20:05:07,061 WARN  [MediaServer] DCRAW not found. Support for raw image files will be missing.
EDIT:
Solved it :D
"dcraw" is REQUIRED (I read it as optional for raw images but by default all images seem to be downloaded in that format OR
it was solved due to the fact that I changed the "DLNA profile" and SAVED. Earlier I forgot to "SAVE" the changes. Not sure what did it.
For users installing "dcraw" onto their Zyxel NSA325 this might be helpful:
http://forum.nas-central.org/viewtopic.php?f=249&t=14873&p=83455#p83455
Feri
Post Tue Oct 06, 2015 9:33 am
I have a problem playing an MKV file. I can play it correctly from USB-drive, but cannot via Serviio.
It lags and I cannot choose audio and subtitle track.
As I see the transcoding makes this problem. How do I update the F series profile to play the file?
mediainfo.txt
(5.49 KiB) Downloaded 748 times
bug.txt
(8.43 KiB) Downloaded 724 times
Post Tue Oct 06, 2015 12:39 pm
Feri wrote:I have a problem playing an MKV file. I can play it correctly from USB-drive, but cannot via Serviio.
There's no guarantee that a file that plays via USB will play via DLNA, particularly with older devices. I know, 2013 isn't that old ;)
I'm not home right now, so can't look at the F profile. My guess is you'll need to add a transcoding line to include MKV files, and if there's one already there it may need tweaking to match your specific video and/or audio codec inside the MKV file. Remember that MKV is only a container, and it's the codecs inside that determine if they can be played.
Feri
Post Fri Oct 23, 2015 9:42 pm
Can anybody help?
Post Sat Oct 24, 2015 2:18 am
Firstly determine whether you can play the file natively - switch to the Generic Profile on the Status tab of Serviio Console, press Save and restart your PC (can't remember if you have to restart but better to be safe). Play the file.
If it does play, try editing the Samsung TV / player (H-series) profile to change the stuff in red:
    <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="5.0" />
    <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="5.0" />
Save the profile and restart (definitely this time) your PC (or service if you know how). See if that works - if it does it may affect other files, so keep an eye on things.
If it doesn't play in the Generic Profile, you must transcode it. Set the number of cores on the Transcode tab in serviio Console to the maximum you have and see if that helps.
Previous
Users browsing this forum: Baidu [Spider] and 20 guests
