Serviio 1.2.1-1.4.1 Xbox360 file problem
sonicman
Post Sun Mar 16, 2014 8:50 am
Currently I started tagging (iTunes type)my files and inserting moov faststart(sp) for my very mixed environment Macs, Linux PCs, (windows7/8.1) Xbox360 frontends
Here is the Debug file that pertains to the file. It shows its in the Library! But, on the Xbox360 all I see is the Folder for the Movie.
2014-03-16 04:35:57,568 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /var/lib/mythtv/videos/Film/After The Dark (2013)
2014-03-16 04:35:57,573 DEBUG [LibraryAdditionsCheckerThread] Found file 'After The Dark.mp4', checking if it's already in the Library
2014-03-16 04:35:57,573 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item After The Dark.mp4
2014-03-16 04:35:57,573 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /var/lib/mythtv/videos/Film/After The Dark (2013)/After The Dark.mp4, ignore case: false
2014-03-16 04:35:57,587 INFO [PluginCompilerThread] Added Web Resouce plugin CONECTATE (CONECTATE.groovy), version: 1
2014-03-16 04:35:57,587 DEBUG [PluginCompilerThread] Starting plugin APVideo.groovy compilation
2014-03-16 04:35:57,589 DEBUG [MediaItemDAOImpl] Media item After The Dark.mp4 already exists in DB
Here are the Results for ffmpeg -i
owner@DataHD:~/videos/Film/After The Dark (2013)$ ffmpeg -i "After The Dark.mp4"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Apr 29 2013 12:35:41 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid --enable-libass --enable-libfdk_aac --enable-libspeex
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
libpostproc 52. 2.100 / 52. 2.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x3484540] stream 0, timescale not set
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x3484540] max_analyze_duration 5000000 reached at 5000000
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'After The Dark.mp4':
major_brand : isom
minor_version : 1
compatible_brands: isomavc1
title : After The Dark
genre : Drama, Fantasy, Science Fiction, Thriller
date : 2013-07-06
encoder : MDH:After.the.Dark.2013.720p.BluRay.x264.YIFY.mp4
hd_video : 1
media_type : 9
description :
synopsis : At an international school in Jakarta, a philosophy teacher challenges his class of twenty graduating seniors to choose which ten of them would take shelter underground and reboot the human race in the event of a nuclear apocalypse.
creation_time : 2014-02-20 22:14:32
Duration: 01:46:38.78, start: 0.000000, bitrate: 1068 kb/s
Stream #0:0: Video: mjpeg, yuvj420p, 1000x1500 [SAR 100:100 DAR 2:3], 90k tbr, 90k tbn, 90k tbc
Stream #0:1(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x534 [SAR 1:1 DAR 640:267], 966 kb/s, 24 fps, 24 tbr, 24k tbn, 48 tbc
handler_name : video.264#trackID=1:fps=24 - Imported with GPAC 0.5.0-rev
Stream #0:2(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 93 kb/s
creation_time : 2014-02-20 22:14:40
handler_name : GPAC ISO Audio Handler
Any Help from the super Gurus
sonicman
sonicman
Post Sun Mar 16, 2014 8:56 am
Re: Serviio 1.2.1-1.4.1 Xbox360 file problem
Adding the Mediainfo Text information also,
Complete name : /Volumes/videos-2/Film/After The Dark (2013)/After The Dark.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 815 MiB
Duration : 1h 46mn
Overall bit rate : 1 068 Kbps
Movie name : After The Dark
Genre : Drama, Fantasy, Science Fiction, Thriller
Recorded date : 2013-07-06
Encoded date : UTC 2014-02-20 22:14:32
Tagged date : UTC 2014-03-13 17:00:02
Writing application : MDH:After.the.Dark.2013.720p.BluRay.x264.YIFY.mp4
Cover : Yes
iTunEXTC : None
iTunMOVI : <?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict> / <key>cast</key><array> / <dict><key>name</key><string>James D'Arcy</string></dict> / <dict><key>name</key><string>Sophie Lowe</string></dict> / <dict><key>name</key><string>Sophie Lowe</string></dict> / <dict><key>name</key><string>Freddie Stroma</string></dict> / <dict><key>name</key><string>Rhys Wakefield</string></dict> / </array> / <key>screenwriters</key><array> / <dict><key>name</key><string>John Huddles</string></dict> / </array> / <key>directors</key><array> / <dict><key>name</key><string>John Huddles</string></dict> / </array> / <key>producers</key><array> / </array> / </dict></plist>
hdvd : 1
stik : 9
ldes : At an international school in Jakarta, a philosophy teacher challenges his class of twenty graduating seniors to choose which ten of them would take shelter underground and reboot the human race in the event of a nuclear apocalypse.
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 46mn
Bit rate : 966 Kbps
Maximum bit rate : 5 360 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.059
Stream size : 737 MiB (90%)
Writing library : x264 core 135 r2 f0c1c53
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=966 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Tagged date : UTC 2014-02-20 22:14:42
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 46mn
Bit rate mode : Variable
Bit rate : 93.6 Kbps
Maximum bit rate : 104 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 71.4 MiB (9%)
Language : English
Encoded date : UTC 2014-02-20 22:14:40
Thanks sonicman
sonicman
Post Sun Mar 16, 2014 9:42 am
Ok and here is the File that is visible on the Xbox360 before using my automated script!
owner@DataHD:/var/lib/mythtv/videos/Film/After The Dark (2013)$ ffmpeg -i "After The Dark.mp4"
major_brand : isom
minor_version : 1
Duration: 01:46:38.78, start: 0.000000, bitrate: 1063 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1280x534 [SAR 1:1 DAR 640:267], 966 kb/s, 24 fps, 24 tbr, 24k tbn, 48 tbc
Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 93 kb/s
sonicman
Post Sun Mar 16, 2014 9:50 am
And the Results of the Mediainfo text output.
Format : MPEG-4
Codec ID : isom
File size : 811 MiB
Duration : 1h 46mn
Overall bit rate : 1 064 Kbps
Tagged date : UTC 2014-02-20 22:14:32
Format : AVC
Codec ID : avc1
Duration : 1h 46mn
Bit rate : 966 Kbps
Height : 534 pixels
Color space : YUV
Bit depth : 8 bits
Stream size : 737 MiB (91%)
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 46mn
Language : English
Again this file works with serviio and Xbox360 this is before Faststart Moov ITunes Tagging automated scripting.
sonicman
Post Tue Mar 18, 2014 6:55 pm
Looks like the script inserts a new video track (perhaps a cover?) on the first position, which is the only one Serviio checks. It's doesn't see the h264 video stream.
Users browsing this forum: Google [Bot] and 23 guests
