twitch.tv on PS3 Help!
opportune
Post Tue Mar 18, 2014 4:51 am
Hey everyone!
I've spent a large portion of today reading forum posts and watching videos on how to get twitch.tv to work on your PS3 via Serviio. As you might have guessed, after all this I'm still unsuccessful. I'm not very tech-savvy and my research skills could use some work, however I did try my best to not have to resort to creating a new topic for this issue, so please forgive me. Basically, no matter what I do, on my PS3 it always goes Serviio -> Video -> Online -> (Display name of twitch channel) -> "there are no files."
Yes, I've installed plugins. I got mine from http://forum.serviio.org/viewtopic.php?f=20&t=3820
Then I went to library -> Online resources -> Add (web resource, and the correct twitch.tv/channel address)
I did restart serviio, and once I restarted my pc as well, still nothing.
I did the above using the latest version of Serviio, which is i believe 1.4.1.1, at first. Then I read a reddit post where someone had the same problem with me but they fixed the problem because they said that twitch seems to only work with version 1.1, so I went and downloaded that but I ended up with the same results.
If anyone can help me that would be greatly appreciated. Thanks in advance.
LadInLondon
Post Tue Mar 18, 2014 7:31 pm
Re: twitch.tv on PS3 Help!
Also having same problem since downloading new Serviio -
opportune
Post Tue Mar 18, 2014 9:32 pm
Sorry to hear, Lad. Hopefully someone can help us soon. I'm still searching around for a solution, if I find anything (though I doubt it) I'll be sure to post it here.
Post Fri Mar 21, 2014 6:47 pm
Contact the plugin dev: viewtopic.php?f=20&t=9216
Users browsing this forum: Baidu [Spider] and 35 guests
