Can't play music on Xbox 360 or WDTV Live
I think I did the whole debugging and found the log correctly, but seeing as I'm barely computer literate, I can't make heads or tails of any of it and I'm not sure what is relevant to post here.
snowflake7 wrote:Have the same issue.
All was working with v1.4.1. Upgraded to v1.4.1.1 and can't play any mp3s with WDTV Live. Servigo and Media Browser are fine. Symptoms: Using WDTV browser select a folder (album); select a mp3 file. It quickly scrolls thru each song and then reports that the files are not in an appropriate format consult the user manual for supported formats. These are the same files that I have been using for some time. There have been no firmware upgrades on the WDTV between v1.4.1 and v1.4.1.1. And none available or applied subsequently.
The attached log shows the start up of serviio, the attempt to play a folder of mp3s on the WDTV (which fails) and then playing a small snipet of a .mpg (works fine). I then shut down serviio.
grolschie wrote:I have made the switch to Linux and installed 1.4.1.1 today. Videos play on Xbox 360, but no music. I'm getting the status code 19-04-80070032. I have compiled ffmpeg from the link on the Serviio download page. I installed lame and rtmpdump from Debian (stable) since these are similar versions. Is something broken in this release?
billregal wrote:... With the 360, you can see the music files but they are labelled with "no symbols" and will bring up an error message after a while. ...
I'm going to go back to v.1.4.0 but hopefully this can be sorted out for v1.4.1 and future releases.
014-03-22 14:59:25,526 INFO [ServiioConsole] Initializing Serviio Console
2014-03-22 14:59:25,556 INFO [ServiioConsole] Starting Serviio Console
2014-03-22 14:59:26,367 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2014-03-22 14:59:30,805 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2014-03-22 14:59:34,830 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused
2014-03-22 14:59:34,843 INFO [Messages] Loaded console message bundle for locale: en
2014-03-22 14:59:37,842 INFO [ServiioConsole] Exitting Serviio Console
2014-03-22 14:59:55,104 INFO [MediaServer] ------------------------------------------------------------------------
2014-03-22 14:59:55,106 INFO [MediaServer] Serviio DLNA media streaming server v 1.4.1.2 (rev. 3753eff81a2f+)
2014-03-22 14:59:55,106 INFO [MediaServer] Petr Nejedly 2009-2014
2014-03-22 14:59:55,106 INFO [MediaServer] http://www.serviio.org
2014-03-22 14:59:55,106 INFO [MediaServer] Java 1.6.0_27-Sun Microsystems Inc.
2014-03-22 14:59:55,107 INFO [MediaServer] OS Linux i386 3.2.0-4-686-pae
2014-03-22 14:59:55,107 INFO [MediaServer] File encoding: UTF-8
2014-03-22 14:59:55,107 INFO [MediaServer] Headless mode enabled: true
2014-03-22 14:59:55,108 INFO [MediaServer] User: serviio
2014-03-22 14:59:55,108 INFO [MediaServer] User home dir: /home/pc5dczcbl5yt
2014-03-22 14:59:55,108 INFO [MediaServer] Temp dir: /tmp
2014-03-22 14:59:55,108 INFO [MediaServer] ------------------------------------------------------------------------
2014-03-22 14:59:55,348 INFO [WebServer] Socket buffer set to 65535 bytes
2014-03-22 14:59:55,352 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2014-03-22 14:59:55,426 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2014-03-22 14:59:55,427 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2014-03-22 14:59:55,449 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-03-22 14:59:55,468 INFO [DatabaseManager] Using DERBY database language
2014-03-22 14:59:55,978 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to create database 'db', see the next exception for details.
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.Driver20.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:620)
at java.sql.DriverManager.getConnection(DriverManager.java:222)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:59)
at org.serviio.MediaServer.main(MediaServer.java:116)
Caused by: java.sql.SQLException: Failed to create database 'db', see the next exception for details.
... 20 more
Caused by: java.sql.SQLException: Directory /media/ntfsdrive/serviio/library//media/ntfsdrive/serviio/library/db already exists.
... 17 more
Caused by: ERROR XBM0J: Directory /media/ntfsdrive/serviio/library//media/ntfsdrive/serviio/library/db already exists.
at org.apache.derby.impl.services.monitor.StorageFactoryService$10.run(Unknown Source)
at org.apache.derby.impl.services.monitor.StorageFactoryService.createServiceRoot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.createPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.createPersistentService(Unknown Source)
... 17 more
2014-03-22 14:59:57,987 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
at org.serviio.MediaServer.main(MediaServer.java:116)2014-03-22 15:35:38,400 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
creation_time : 2027-07-11 14:25:11
Stream mapping:
Stream #0:1 -> #0:0 (mjpeg -> ?)
Stream #0:0 -> #0:1 (aac -> ?)
Encoder (codec none) not found for output stream #0:0
2014-03-22 15:35:48,290 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:49)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:151)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:132)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:196)
ffmpeg -i ../iTunes/Music/John\ Goulart/Aranjuez/02\ Concierto\ de\ Aranjuez\ _\ II.\ Adagi.m4a
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
built on Mar 22 2014 13:53:00 with gcc 4.7 (Debian 4.7.2-5)
configuration:
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x9becdc0] stream 0, timescale not set
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x9becdc0] max_analyze_duration 5000000 reached at 5015510 microseconds
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '../iTunes/Music/John Goulart/Aranjuez/02 Concierto de Aranjuez _ II. Adagi.m4a':
major_brand : M4A
minor_version : 0
compatible_brands: M4A mp42isom
title : Concierto de Aranjuez : II. Adagio
artist : John Goulart
album_artist : John Goulart
album : Aranjuez
genre : Classical
track : 2/10
disc : 1/1
gapless_playback: 0
date : 2009-12-17T08:00:00Z
copyright : ℗ 2009 Independent
media_type : 1
Duration: 00:11:04.58, start: 0.000000, bitrate: 273 kb/s
Stream #0:0(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 265 kb/s
Stream #0:1: Video: mjpeg, yuvj444p, 600x600 [SAR 72:72 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
grolschie wrote:billregal wrote:... With the 360, you can see the music files but they are labelled with "no symbols" and will bring up an error message after a while. ...
I see the same symbols for music files. Please let us know if reverting to an earlier version solves this.
Users browsing this forum: No registered users and 88 guests
