KDL-46W5500 2009 : remanence/persistence
Gilles
Post Sun Mar 23, 2014 3:44 pm
It seems that the quality of the movies that I read on my TV is decreasing. My TV is 5 years old now. Maybe it is the reason.
I have watched an old cartoon yesterday and each time that someone moves, the original position is not "refreshed" and keeps the former color.
I run Serviio 1.4.1.2 with the profile Sony Bravia TV(2009)
Below are the logs (ffmpeg + mediainfo).
Can you help ?
BTW, sometime ago, I had opened a subject on this forum and I had to change the profile I use ( to be able to see MKV and mp4 files). I don't know if this profile may still be used and I think that it has been replaced by the new Serviio versions instalaltions. Would be it possible to have a profile including all the updates needed for a Sony KDL-46W5500 ?
Thanks,
Gilles
C:\Program Files\Serviio\lib>ffmpeg.exe -i "d:\Mint\Films\La Belle Et Le Clochard.avi"
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-libr
config --enable-libfreetype --enable-zlib --enable-libx264 --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --ena
tect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
Input #0, avi, from 'd:\Mint\Films\La Belle Et Le Clochard.avi':
Duration: 01:13:24.80, start: 0.000000, bitrate: 1311 kb/s
Stream #0:0: Video: mpeg4 (Simple Profile) (XVID / 0x44495658), yuv420p, 640x304 [SAR 1:1 DAR 40:19], 25 tbr, 25 tbn, 25 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16p, 128 kb/s
Complete name : D:\Mint\Films\La Belle Et Le Clochard.avi
Format : AVI
File size : 688 MiB
Duration : 1h 13mn
Overall bit rate : 1 311 Kbps
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 13mn
Source duration : 1h 13mn
Bit rate : 1 171 Kbps
Width : 640 pixels
Height : 304 pixels
Display aspect ratio : 2.105
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.241
Stream size : 615 MiB (89%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 13mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : 26ms
Stream size : 67.2 MiB (10%)
Alignment : Split accross interleaves
Interleave, duration : 26 ms (0.65 video frame)
Writing library : LAME3.96.1
Post Sun Mar 23, 2014 6:02 pm
Re: KDL-46W5500 2009 : remanence/persistence
I did not have problem with my 2010 model.
No changes are done on 2009/2010/2011 profiles.
Could you enable detailed logging and check the ffmpeg command line used ?
Gilles
Post Sun Mar 23, 2014 7:56 pm
I have attached the log:
Gilles
log.txt
Log.txt
(36.65 KiB) Downloaded 659 times
Gilles
Post Sun Mar 30, 2014 9:26 pm
any idea on what is going wrong with it ?
Gilles
