Wide Screen w/New Profile
mjb_i
Post Wed Mar 26, 2014 9:26 pm
I installed the new update to 1.4.1. Under the older version, I modified the profile based on your initial unofficial Panasonic 2013 VT60. The new update and profile have added features in the options category (which did not work previously) but on one of my older movies, the widescreen feature cannot be invoked. It remains in the 16/9 format. The widescreen can be invoked and other formats on other movies. Was something changed in the new format to restrict it on the following video? I have included the media information for this movie.
Unique ID : 177447311429149355743133956105597485185 (0x857F1BEB918BA1FD887249A611BE0081)
Complete name : C:\Users\M.J. Bennicelli\Videos\The Final Countdown (1980).mkv
Format : Matroska
Format version : Version 1
File size : 1.37 GiB
Duration : 1h 42mn
Overall bit rate : 1 906 Kbps
Encoded date : UTC 2008-11-12 11:48:48
Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 42mn
Bit rate : 1 519 Kbps
Width : 1 056 pixels
Height : 448 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.134
Stream size : 1.06 GiB (78%)
Writing library : x264 core 65 r1024M 2652abe
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=4 / nr=0 / decimate=0 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1519 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 42mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 282 MiB (20%)
Default : Yes
Forced : No
mjb_i
Post Fri Mar 28, 2014 11:39 am
Re: Wide Screen w/New Profile
I think I found the error. In my original profile before it was overwritten by the new program update, DLNAMaster requested that I add the following line to the prerelease Panasonic 2013 profile:
<Matches container="matroska" vCodec="h264" profile="high" />
This line was not included in your updated profile. How would I modify the profile for a similar problem with an AVI file?
How do your profiles work? Are they uploaded at program start? Also, it appears that program updates overwrite the old profile. Is that correct?
Post Tue Apr 01, 2014 8:44 am
Yes. Any changes you make to profiles.xml require the Serviio service (or your PC) to be restarted.
Yes. Any mods you make have to be redone after each update.
It would be unusual for an AVI to have the same problem. What symptoms are you having. If its only one file, I'd remux it first as this often fixes AVI problems. If that doesn't work, post the MediaInfo details for the AVI file.
Return to Panasonic
Users browsing this forum: Baidu [Spider] and 13 guests
