Switched from LAN to WIFI - TV does not see Serviio anymore
chaddictive
Post Thu Jun 12, 2014 7:04 am
I am running Serviio since 2 years now in my home network via LAN/Power-Lan. All fine so far.
Now I had to switch to a WIFI connection (from Server to router) and Serviio does not show up on my Samsung TV. Did I miss any connection setup which is special for wifi?
- Connection to same router established (just switched from LAN to Wifi)
- Firewall is deactivated
- Serviio finds my TV
- TV even finds the windows 7 server, but just not Serviio
Any ideas what I could try?
Cheers,
Chaddictive
Post Thu Jun 12, 2014 10:47 am
Re: Switched from LAN to WIFI - TV does not see Serviio anym
In your router look for options related to IGMP - IGMP forwarding, IGMP snooping or IGMP proxy options - and change their state. Let me know if that fixes the issue - if not, what is your router model?
