TV can't find Serviio server.
Stomp
Post Thu Jun 19, 2014 11:25 am
Hello, after using Serviio from several months suddenly after change of residence it stopped working - My Panasonic TV can't find Serviio server. On Serviio's console I can see my TV, my TV is connected with wireless connection on the same router which is my pc connected to. My TV is connected to internet [I've ran connection test on my TV]. Tried restarting my rooter. Any idea how to fix this?
Post Thu Jun 19, 2014 8:58 pm
Re: TV can't find Serviio server.
Need to work out what changed during the change of residence. Was the TV previously connected to the router by wired or wireless? Did the router model change? Did the server change? If you connect the TV by wired if possible, does it work? Alternatively, if you connect PC by wireless does it work?
If any of the above, let me know the router model. Also, remove the TV from the status list in Serviio and refresh it? Does it find it again (and on same IP).
Stomp
Post Sat Jun 21, 2014 9:57 pm
Kind of late reply, but the next day after creating this post I just switched on TV and out of sudden Serviio's server was visible. Didn't do anything, but one thing that I previously forgot to try was restarting Serviio service which could have fixed it.
Users browsing this forum: Baidu [Spider] and 49 guests
