Serviio on Xbox 360 Not being found on portable router
jsnxbox
Post Mon Jul 07, 2014 10:46 pm
Hi, I know this question was asked a few times and i tried all the options within previous posts but I am lost with this one and could not find portable router questions within the forum.
As an overview I have a powerline setup at home and my xbox and pc where conected like that for quite a while and stream perfectly from one another but the issue arised when i required to move the powerline plug to another device so i bought an LB-Link portable router for the xbox. http://www.lb-link.cn/index.php/products/view?pid=59
The issue is that no matter what I do I can't seem to see serviio on the xbox now and serviio cannot see the xbox. The connection is there as I have xbox live but i can stream locally anymore from serviio.
Anyone had luck with portable routers? It has a bunch of settings to setup as all routers but the first thing i checked was the firewall tab and port forwarding as suggested in other posts but its all chinese for me :roll:
Thanks in advance.
grolschie
Post Sun Jul 13, 2014 3:33 am
Re: Serviio on Xbox 360 Not being found on portable router
More info about your network might be needed please. Some questions:
  • The PC is plugged into your main router via ethernet, but the Xbox 360 connects to same router via WiFi (specifically using the travel router, and not using built-in WiFi or an official Xbox 360 wireless adapter)?
  • Can you ping the Xbox 360 from the PC where Serviio is installed?
  • In your main router, is there some restriction of communication between wireless clients and wired clients (e.g. using a wireless "guest" network SSID)?
Users browsing this forum: Baidu [Spider] and 64 guests
