[SOLVED] Bravia 2014 does not play any TS containing 50fps
Lowlander
Post Thu Aug 21, 2014 9:07 am
I experience my KDL-42W829B not being able to play any TS containing 50fps video. Which is pretty nasty, because those are my DVB recordings and I'm not in the habit of editing and transcoding programs I don' t plan to archive anyway.
What happens on the TV is that mediaplayer does fire up, shows the videos's name, control buttons, the correct length of the video, but actual playback never starts and the counter stays at 0:00:00. The menu vanishes after a few seconds, leaving a black screen, and that's it. The TV doesn't show any error message, but is still responsive and playback attempts can be cancelled at any time.
My trusted 2011 KDL-24EX320 plays the very same files flawlessly.
Log looks like so:
2014-08-20 19:49:40,824 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.242, Profile=Sony Bravia TV (2013)'
2014-08-20 19:49:40,824 DEBUG [ResourceDeliveryProcessor] Request for resource 106978 and type 'MEDIA_ITEM' received
2014-08-20 19:49:40,824 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 106978 (local)
2014-08-20 19:49:40,824 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 106978)
2014-08-20 19:49:40,824 DEBUG [VideoDAOImpl] Reading a Video (id = 106978)
2014-08-20 19:49:40,824 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 106978, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2013)
2014-08-20 19:49:40,824 DEBUG [VideoDeliveryEngine] Delivering item '106978' for client 'Identifier=10.240.11.242, Profile=Sony Bravia TV (2013)'
2014-08-20 19:49:40,824 DEBUG [VideoDeliveryEngine] Delivering file 'Tatort 803 (HD) - Gestern war kein Tag (BR 2011) 140805.HDTV_fixed.ts' in native format
2014-08-20 19:49:40,824 DEBUG [MediaItemDAOImpl] Getting file of media item 106978
2014-08-20 19:49:40,824 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 106978) as read
2014-08-20 19:49:40,824 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-20 19:49:40,824 DEBUG [GETMethodProcessor] Stream entity has length: 6681814852
2014-08-20 19:49:40,824 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 6681814852,Date: Wed, 20 Aug 2014 17:49:40 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 25591808-6707406659/6707406660,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-20 19:49:41,512 DEBUG [ServiioHttpService] Incoming request from /10.240.11.242:55176: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-42W829B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-42W829B"; mv="1.7";,Host: 10.240.11.11:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 276,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"]]
2014-08-20 19:49:41,512 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.242
2014-08-20 19:49:41,512 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 10.240.11.242
2014-08-20 19:49:41,684 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-08-20 19:49:42,481 DEBUG [SearchManager] Committing search index
With my limited experience in reading logfiles, I think that Serviio is delivering the video in native format, doing so in good faith, unaware that the Bravia won't be able to cope with it.
Any ideas highly appreciated,
Low
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
Post Thu Aug 21, 2014 5:50 pm
Re: [Readme] Sony Bravia 2014
Hi Lowlander,
Could you provide information about your recorder files ? (see signature links) (ffmpeg and mediainfo tools)
Your file was delivered in native format with AVC_TS_HD_24_AC3_ISO mime-type. We will see if we can try with different mime-type values...
Lowlander
Post Sat Aug 23, 2014 9:04 am
Here you are. It's a pretty simple format, the only thing special is that it's in 50fps. As I said, my older Bravias were perfectly capable of playing those. Would a log of my KDL-24EX320 playing this be helpful?
Complete name                            : U:\videos\neu\Krimis\Tatort\Tatort 842 (HD) - Borowski und der stille Gast (NDR 2012) 140817.HDTV_fixed.ts
Format                                   : MPEG-TS
File size                                : 3.02 GiB
Duration                                 : 1h 29mn
Overall bit rate                         : 4 829 Kbps
Menu ID                                  : 11100 (0x2B5C)
Format profile                           : High@L4.0
Format settings, ReFrames                : 3 frames
Format settings, GOP                     : M=4, N=32
Codec ID                                 : 27
Duration                                 : 1h 29mn
Bit rate                                 : 4 138 Kbps
Frame rate                               : 50.000 fps
Standard                                 : Component
Bits/(Pixel*Frame)                       : 0.090
Stream size                              : 2.59 GiB (86%)
Color primaries                          : BT.601 PAL
Transfer characteristics                 : BT.470 System B, BT.470 System G
Matrix coefficients                      : BT.601
Codec ID                                 : 6
Duration                                 : 1h 29mn
Bit rate                                 : 448 Kbps
Delay relative to video                  : -85ms
Stream size                              : 287 MiB (9%)
Language                                 : German
[h264 @ 036DDFA0] mmco: unref short failure
    Last message repeated 2 times
[mpegts @ 036C0060] max_analyze_duration 5000000 reached at 5000000 microseconds
Input #0, mpegts, from 'H:\Daten\mm3\videos\neu\Krimis\Tatort\Tatort 842 (HD) -
Borowski und der stille Gast (NDR 2012) 140817.HDTV_fixed.ts':
  Duration: 01:29:26.96, start: 7655.501700, bitrate: 4829 kb/s
  Program 11100
    Stream #0:0[0x13ed]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1
280x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
    Stream #0:1[0x13ee](deu): Audio: ac3 ([6][0][0][0] / 0x0006), 48000 Hz, ster
eo, fltp, 448 kb/s
Post Sat Aug 23, 2014 11:29 am
Lowlander wrote:Would a log of my KDL-24EX320 playing this be helpful?
Yes, could you check that the file is delivered in native format to your EX320 with the same mime-type ?
Lowlander
Post Sat Aug 23, 2014 2:21 pm
Thanks Illico for looking into my issue. Your help is highly appreciated!
Here is the log of the 24EX320 playing the same file as the 42W829B before. As far as I can see (and that's not very far if mime types and profiles are involved), in both cases the file's mime type of AVC_TS_MP_HD_AC3_ISO is presented to the TV as AVC_TS_HD_24_AC3_ISO.
2014-08-23 16:18:21,457 DEBUG [ServiioHttpService] Incoming request from /10.240.11.205:57188: HEAD /resource/106978/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 10.240.11.11:8895]]
2014-08-23 16:18:21,457 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.205
2014-08-23 16:18:21,457 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.205, Profile=Sony Bravia TV (2011)'
2014-08-23 16:18:21,457 DEBUG [ResourceDeliveryProcessor] Request for resource 106978 and type 'MEDIA_ITEM' received
2014-08-23 16:18:21,457 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 106978 (local)
2014-08-23 16:18:21,457 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 106978)
2014-08-23 16:18:21,457 DEBUG [VideoDAOImpl] Reading a Video (id = 106978)
2014-08-23 16:18:21,457 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 106978, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2014-08-23 16:18:21,457 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 6707406660,Date: Sat, 23 Aug 2014 14:18:21 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-23 16:18:21,473 DEBUG [ServiioHttpService] Incoming request from /10.240.11.205:57189: GET /resource/106978/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-24EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-24EX320"; mv="1.7";,Host: 10.240.11.11:8895]]
2014-08-23 16:18:21,473 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.205
2014-08-23 16:18:21,473 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.205, Profile=Sony Bravia TV (2011)'
2014-08-23 16:18:21,473 DEBUG [ResourceDeliveryProcessor] Request for resource 106978 and type 'MEDIA_ITEM' received
2014-08-23 16:18:21,473 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 106978 (local)
2014-08-23 16:18:21,473 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 106978)
2014-08-23 16:18:21,473 DEBUG [VideoDAOImpl] Reading a Video (id = 106978)
2014-08-23 16:18:21,473 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 106978, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2011)
2014-08-23 16:18:21,473 DEBUG [VideoDeliveryEngine] Delivering item '106978' for client 'Identifier=10.240.11.205, Profile=Sony Bravia TV (2011)'
2014-08-23 16:18:21,473 DEBUG [VideoDeliveryEngine] Delivering file 'Tatort 803 (HD) - Gestern war kein Tag (BR 2011) 140805.HDTV_fixed.ts' in native format
2014-08-23 16:18:21,473 DEBUG [MediaItemDAOImpl] Getting file of media item 106978
2014-08-23 16:18:21,473 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 106978) as read
2014-08-23 16:18:21,473 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-23 16:18:21,473 DEBUG [GETMethodProcessor] Stream entity has length: 6707406660
2014-08-23 16:18:21,473 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 6707406660,Date: Sat, 23 Aug 2014 14:18:21 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 0-6707406659/6707406660,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-23 16:18:23,239 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
I did try the 42W829B with the Sony 2011 profile, but with the 2011 profile, it wouldn't even play any of my archived MKV/AVC-720p25/AC3 files.
Post Sat Aug 23, 2014 6:38 pm
I don't know what is the problem...
Serviio offers several mime-type "AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO" for this AVC_TS_MP_HD_AC3_ISO video type.
And then this is the TV that select the proper one (first in the list?) AVC_TS_HD_24_AC3_ISO .
You can try to edit the 2013 profile by removing other mime-type and only set AVC_TS_HD_50_AC3_ISO (50 fps) in the list (test A/), or change list order with AVC_TS_HD_50_AC3_ISO first (test B/)
A/
<MediaFormatProfile mime-type="video/mpeg" name=AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
B/
<MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
You have to restart serviio service (not server) for profile reload, or reboot PC.
Could you provide the supported formats of a device ? see my signature link)
Lowlander
Post Sat Aug 23, 2014 9:30 pm
Yeah, maybe, but you solved it anyway. :lol: Brilliant! I tried test B first, and it instantly worked. Thank you so much, you really saved me a LOT of encoding hassle.
Here is what happened in the log:
2014-08-23 23:16:11,300 DEBUG [ResourceDeliveryProcessor] Request for resource 106978 and type 'MEDIA_ITEM' received
2014-08-23 23:16:11,300 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 106978 (local)
2014-08-23 23:16:11,300 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 106978)
2014-08-23 23:16:11,300 DEBUG [VideoDAOImpl] Reading a Video (id = 106978)
2014-08-23 23:16:11,300 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 106978, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2013)
2014-08-23 23:16:11,300 DEBUG [VideoDeliveryEngine] Delivering item '106978' for client 'Identifier=10.240.11.242, Profile=Sony Bravia TV (2013)'
2014-08-23 23:16:11,300 DEBUG [VideoDeliveryEngine] Delivering file 'Tatort 803 (HD) - Gestern war kein Tag (BR 2011) 140805.HDTV_fixed.ts' in native format
2014-08-23 23:16:11,300 DEBUG [MediaItemDAOImpl] Getting file of media item 106978
2014-08-23 23:16:11,300 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 106978) as read
2014-08-23 23:16:11,316 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-23 23:16:11,316 DEBUG [GETMethodProcessor] Stream entity has length: 6707406660
2014-08-23 23:16:11,316 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 6707406660,Date: Sat, 23 Aug 2014 21:16:11 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 0-6707406659/6707406660,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-23 23:16:11,487 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-08-23 23:16:11,534 DEBUG [ServiioHttpService] Incoming request from /10.240.11.242:57174: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-42W829B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-42W829B"; mv="1.7";,Host: 10.240.11.11:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 440,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"]]
2014-08-23 23:16:11,534 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.242
2014-08-23 23:16:11,534 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 10.240.11.242
2014-08-23 23:16:11,691 DEBUG [ContentDirectory] Browse() called for renderer KDL-42W829B (profile sony2013) with parameters: objectID = V_LV^V_106978, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2014-08-23 23:16:11,691 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2014-08-23 23:16:11,691 DEBUG [VideoDAOImpl] Reading a Video (id = 106978)
2014-08-23 23:16:11,691 DEBUG [MediaItemDAOImpl] Getting file of media item 106978
2014-08-23 23:16:11,691 DEBUG [GenreDAOImpl] Reading a Genre (id = 88)
2014-08-23 23:16:11,691 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 106978 and profile Sony Bravia TV (2013)
2014-08-23 23:16:11,691 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 120099)
2014-08-23 23:16:11,691 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_resetafterplay), returning it
2014-08-23 23:16:11,691 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-08-23 23:16:12,800 DEBUG [ServiioHttpService] Incoming request from /10.240.11.242:57175: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-42W829B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-42W829B"; mv="1.7";,Host: 10.240.11.11:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 276,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"]]
2014-08-23 23:16:12,800 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.242
2014-08-23 23:16:12,800 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 10.240.11.242
2014-08-23 23:16:12,987 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-08-23 23:16:13,003 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2014-08-23 23:16:13,003 DEBUG [ServiioHttpService] Incoming request from /10.240.11.242:57176: GET /resource/106978/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=21397504-,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-42W829B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-42W829B"; mv="1.7";,Host: 10.240.11.11:8895]]
2014-08-23 23:16:13,003 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.242
2014-08-23 23:16:13,003 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=10.240.11.242, Profile=Sony Bravia TV (2013)'
2014-08-23 23:16:13,003 DEBUG [ResourceDeliveryProcessor] Request for resource 106978 and type 'MEDIA_ITEM' received
2014-08-23 23:16:13,003 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 106978 (local)
2014-08-23 23:16:13,003 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 106978)
2014-08-23 23:16:13,003 DEBUG [VideoDAOImpl] Reading a Video (id = 106978)
2014-08-23 23:16:13,003 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 106978, format AVC_TS_MP_HD_AC3_ISO and profile Sony Bravia TV (2013)
2014-08-23 23:16:13,003 DEBUG [VideoDeliveryEngine] Delivering item '106978' for client 'Identifier=10.240.11.242, Profile=Sony Bravia TV (2013)'
2014-08-23 23:16:13,003 DEBUG [VideoDeliveryEngine] Delivering file 'Tatort 803 (HD) - Gestern war kein Tag (BR 2011) 140805.HDTV_fixed.ts' in native format
2014-08-23 23:16:13,003 DEBUG [MediaItemDAOImpl] Getting file of media item 106978
2014-08-23 23:16:13,003 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 106978) as read
2014-08-23 23:16:13,003 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-08-23 23:16:13,003 DEBUG [GETMethodProcessor] Stream entity has length: 6686009156
2014-08-23 23:16:13,003 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 6686009156,Date: Sat, 23 Aug 2014 21:16:13 GMT,Server: Windows 2003, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 21397504-6707406659/6707406660,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-08-23 23:16:14,190 DEBUG [ServiioHttpService] Incoming request from /10.240.11.242:57177: POST /serviceControl HTTP/1.1, headers = [X-AV-Physical-Unit-Info: pa="BRAVIA KDL-42W829B";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-42W829B"; mv="1.7";,Host: 10.240.11.11:8895,User-Agent: UPnP/1.0 DLNADOC/1.50,Content-Length: 276,Content-Type: text/xml; charset="utf-8",SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"]]
2014-08-23 23:16:14,190 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 10.240.11.242
2014-08-23 23:16:14,190 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 10.240.11.242
2014-08-23 23:16:14,300 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2014-08-23 23:16:26,878 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
Don't know what will happen to 25fps TS though, as I haven't got any at the moment.
For future reference, here is Intel Device Spy's output anyway, Bravia 42W829B firmware is PKG2.204EUA:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-mp2t-mphl-188:*,
http-get:*:image/jpeg:*,
http-get:*:audio/mpeg:*,
http-get:*:audio/L16:*,
http-get:*:audio/x-ms-wma:*,
http-get:*:audio/mp4:*,
http-get:*:audio/x-m4a:*,
http-get:*:video/mpeg:*,
http-get:*:video/vnd.dlna.mpeg-tts:*,
http-get:*:video/mp4:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/avi:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/3gpp:*,
http-get:*:video/3gpp2:*,
http-get:*:audio/3gpp:*,
http-get:*:audio/3gpp2:*,
http-get:*:video/x-mkv:*,
http-get:*:video/x-matroska:*,
http-get:*:video/webm:*,
http-get:*:video/quicktime:*,
http-get:*:video/x-avi:*,
http-get:*:video/x-xvid:*,
http-get:*:application/x-mpegURL:*,
http-get:*:application/vnd.apple.mpegURL:*
Post Sat Sep 27, 2014 3:30 pm
Re: [SOLVED] Bravia 2014 does not play any TS containing 50f
