No support for kdl-52W700A
emaarkhan
Post Tue Sep 09, 2014 9:30 am
I bought new tv 2 days before and i had serviio installed, the dropdown menu in serviio didn't had 2014 models. So i saw the net for my model kdl-52W700A but didn't find anything. which made me think twice if my bravia is fake. Today before posting the forum, i went through README for Bravia and i didn't find the model there too, on backside it says kdl-52W700A January 2014. What should i do? How can i connect it to serviio?
Post Tue Sep 09, 2014 10:44 am
Re: No support for kdl-52W700A
What is your country? There is nothing about this model on web... ?!
Are you sure your device is DLNA compliant ? could you provide format supported b your device ? see signature link...
emaarkhan
Post Tue Sep 09, 2014 10:47 am
I m from Pakistan, the device is supported for divX HD, DLNA and many other feature.
emaarkhan
Post Tue Sep 09, 2014 11:02 am
Illico wrote:What is your country? There is nothing about this model on web... ?!
Post Tue Sep 09, 2014 12:47 pm
Could you use INTEL tool to check format supported by your device ?
http://wiki.serviio.org/doku.php?id=device_sf
emaarkhan
Post Tue Sep 09, 2014 2:37 pm
Illico wrote:Could you use INTEL tool to check format supported by your device ?
I use mac, i think mac tool for that isn't available. btw how does serviio knows about my device format if its not connected or doesn't list my model. Is my model really not available on internet?
