[SOLVED] Sony 60w605b live streams playback issue
mypaxep
Post Mon Nov 03, 2014 11:29 am
Hello everyone.
Can anyone clarify if it's possible to watch streamed videos on Sony TVs? (I'm aware that the built-in player is extremely picky)
So far I've had no luck getting anything streamed through Serviio:
1) Twitch - I'm able to see the quality options, but whenever I select either the player starts up and there is nothing but a black screen.
2) Youtube - similar issue, videos can be selected but are not played.
3) IPTV streams - visible, Serviio says that the URL is correct, but there is no playback.
Tried both with and without transcoding, Bravia 2013 profile selected. No visible errors in the log.
Post Mon Nov 03, 2014 2:08 pm
Re: Sony 60w605b live streams playback issue
Do you try with other Sony profiles (2012/2011 or 2010) ?
What are plugins used and could you provide serviio link example ?
mypaxep
Post Mon Nov 03, 2014 9:41 pm
I did some more research and found these settings viewtopic.php?p=94549#p94549 Now everything seems to be working fine. Thanks for your time.
Post Tue Nov 04, 2014 8:16 am
OK, Thanks.
As you can read, a ticket was opened.
This will be included in next serviio release.
https://bitbucket.org/xnejp03/serviio/i ... pport-2014
Users browsing this forum: Bing [Bot] and 19 guests
