jerky mkv videos
mib182
Post Mon Dec 01, 2014 5:13 pm
jerky mkv videos
With serviio when I watch a .MKV video on my samsung TV (UE46ES7000) The video has mini stop and hash, the videos are jerking. but .avi .mp4, m4v, wmv or mpg no problem.
I'm using Serviio 1.4.1.2-0026 on a Synology DS414
cpu : MARVELL Armada XP MV78230
2 cores
1024Mb of memory
DSM 5.1-5004 update 2
ffmpeg : 2.0.2
fmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
built on Nov 6 2014 15:46:31 with gcc 4.6.4 (Linaro GCC branch-4.6.4. Marvell GCC Dev 201310-2126.3d181f66 64K MAXPAGESIZE ALIGN)
configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=a rm --target-os=linux --cross-prefix=/usr/local/arm-marvell-linux-gnueabi/bin/arm -marvell-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-p ic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonf ree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disab le-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swsc ale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable -libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disa ble-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/ arm-marvell-linux-gnueabi/bin/arm-marvell-linux-gnueabi-ccache-gcc
Java 1.7.0_71-0029
Does someone have an idea, what is the problème ?
Many thanks.
Christophe.
Post Tue Dec 02, 2014 1:11 am
Re: jerky mkv videos
A Serviio installation on a NAS is going to be marginal for any file that needs transcoding. I am not familiar with your particular TV, but if MKV files will not play native, that's likely your issue. I have two Serviio machines, one for main use and one for testing profile changes and updates. The test machine has far less power than my main machine. Even though it's still a full PC and not a NAS, I still occasionally encounter issues when files must be transcoded. Fortunately most of my players can handle almost everything I have without transcoding, but that might be your issue here.
