Movie files play with interruption.
thailand
Post Sun Jan 25, 2015 4:01 pm
Hello ,
Since i installed the 1.5 version of serviio i cannot play a movie file. It does not matter if its avi or MKV .. nothing plays good
After 10 minutes or so the movie freezes and after a while it restarts again.
Then it plays again for a short time.
I deleted the 1.5 version of Serviio and reinstalled 1.4.1.2 but the problem is still here.
I did a full reinstall and deleted also Java... Nothing helps ..
I give you also my log file
I Use the Telenet Yelo TV profile
Please help....
(436.31 KiB) Downloaded 342 times
thailand
Post Sun Jan 25, 2015 4:14 pm
Re: Movie files play with interruption.
I see that there is anothe logfile in that same map ...
Maybe it helps to find a solution.....
(441.92 KiB) Downloaded 326 times
derby.log
(3.02 KiB) Downloaded 340 times
Post Sun Jan 25, 2015 5:04 pm
It's probably related to your network / router - as you're seeing the same problem with the older version too now. So check the quality of your network (wifi)
http://serviio.org/component/content/article?id=21#q12
viewtopic.php?f=5&t=10289
thailand
Post Sun Jan 25, 2015 6:23 pm
My router is connected thru LAN and its fast ... 160 Mb/s
I changed the profiles file and now it works for me..
I give you the profile file that i adjusted .. Its for BELGIUM TELENET custumors only ....
profiles.xml
(14.06 KiB) Downloaded 478 times
