Can not communicate with the server, try again later
Lugosi
Post Sat Mar 07, 2015 7:57 pm
I've been using Serviio for some time now, never had a problem, until last week.
I recently downloaded and installed the latest version. (1.51)
I'm using my sony blu ray player.
When I browse to the Serviio server I can browse further into the folders, but when I want to select the folder containing the video file it see the message: 'Can not communicate with the server, try again later'.
I've noticed that there's a new folder in the new version 'Recent Unwatched'. I am able to play the video files in this folder. Apparently there is communication with the server when the files are accessed through this folder.
When I try to access the server with my Tablet via Skifta it says 'An Error Occurred Fetching The Media Items'. Again I can load the videos which I can open through the 'Recent Unwatched' Folder.
How can I solve this problem?
Post Sun Mar 08, 2015 4:35 pm
Re: Can not communicate with the server, try again later
post detailed log of this happening
Lugosi
Post Sun Mar 08, 2015 6:54 pm
2015-03-08 19:03:40,895 INFO  [ServiioConsole] Starting Serviio Console
2015-03-08 19:03:41,409 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-03-08 19:03:51,620 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2015-03-08 19:04:01,651 WARN  [ServiioConsole] Cannot connect to server: Connection Error (1000) - The connector failed to connect to the server
2015-03-08 19:04:01,660 INFO  [Messages] Loaded console message bundle for locale: en
2015-03-08 19:04:14,738 INFO  [ServiioConsole] Exitting Serviio Console
le
2015-03-08 19:04:07,366 INFO  [ServiioConsole] Exitting Serviio Console
2015-03-08 19:04:36,379 INFO  [ServiioConsole] Initializing Serviio Console
2015-03-08 19:04:36,422 INFO  [ServiioConsole] Starting Serviio Console
2015-03-08 19:04:36,539 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-03-08 19:04:46,674 WARN  [ServiioConsole] Cannot connect to the server to get DB initialization info
2015-03-08 19:04:56,706 WARN  [ServiioConsole] Cannot connect to server: Connection Error (1000) - The connector failed to connect to the server
2015-03-08 19:04:56,714 INFO  [Messages] Loaded console message bundle for locale: en
2015-03-08 19:08:56,644 INFO  [ServiioConsole] Exitting Serviio Console
2015-03-08 19:10:26,454 INFO  [MediaServer] ------------------------------------------------------------------------
2015-03-08 19:10:26,485 INFO  [MediaServer] Serviio DLNA media streaming server v 1.5.1 (rev. 9d3f18af690f)
2015-03-08 19:10:26,485 INFO  [MediaServer] Petr Nejedly 2009-2015
2015-03-08 19:10:26,485 INFO  [MediaServer] http://www.serviio.org
2015-03-08 19:10:26,485 INFO  [MediaServer] Java 1.8.0_31-Oracle Corporation x86
2015-03-08 19:10:26,485 INFO  [MediaServer] OS Windows 8 6.2
2015-03-08 19:10:26,485 INFO  [MediaServer] File encoding: windows-1252
2015-03-08 19:10:26,485 INFO  [MediaServer] Headless mode enabled: true
2015-03-08 19:10:26,485 INFO  [MediaServer] User: PCBENEDEN$
2015-03-08 19:10:26,485 INFO  [MediaServer] User home dir: C:\windows\system32\config\systemprofile
2015-03-08 19:10:26,485 INFO  [MediaServer] Temp dir: C:\windows\TEMP\
2015-03-08 19:10:26,485 INFO  [MediaServer] ------------------------------------------------------------------------
2015-03-08 19:10:26,751 INFO  [WebServer] Socket buffer set to 65535 bytes
2015-03-08 19:10:26,751 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-03-08 19:10:27,063 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-03-08 19:10:27,063 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-03-08 19:10:27,095 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-03-08 19:10:27,110 INFO  [DatabaseManager] Using DERBY database language
2015-03-08 19:10:29,173 INFO  [MediaServer] ------------------------------------------------------------------------
2015-03-08 19:10:29,173 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-03-08 19:10:29,548 INFO  [Device] Created UPnP Device with UUID: 92364609-eb74-3e48-a97f-fb1c988d0a03, bound address: 192.168.1.3
2015-03-08 19:10:30,095 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2015-03-08 19:10:30,157 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-03-08 19:10:30,173 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-03-08 19:10:30,173 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-03-08 19:10:30,173 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-03-08 19:10:30,173 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-03-08 19:10:30,173 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-03-08 19:10:30,188 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-03-08 19:10:30,204 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-03-08 19:10:30,220 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-03-08 19:10:30,251 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2015-03-08 19:10:30,251 INFO  [PluginCompilerThread] Started looking for plugins
2015-03-08 19:10:30,251 INFO  [UpdateChecker] Checking if a new version is available
2015-03-08 19:10:30,813 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-03-08 19:10:31,376 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-03-08 19:10:31,407 INFO  [WebServer] WebServer starting on port 8895
2015-03-08 19:10:32,360 INFO  [Device] Updated bound IP address of Device with UUID: 92364609-eb74-3e48-a97f-fb1c988d0a03, bound address: 192.168.1.3
2015-03-08 19:10:32,407 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-03-08 19:10:32,407 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-03-08 19:10:32,407 INFO  [EventDispatcher] Starting EventDispatcher
2015-03-08 19:10:32,414 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2015-03-08 19:10:32,620 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth1 (Realtek PCIe GBE Family Controller) and address 192.168.1.3, timeout = 0
2015-03-08 19:10:32,652 INFO  [RendererSearchSender] Searching for Renderer devices
2015-03-08 19:10:58,671 INFO  [FeedUpdaterWorker] Started looking for information about online resources
2015-03-08 19:10:58,750 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2015-03-08 19:10:58,795 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-03-08 19:11:32,312 INFO  [ServiioConsole] Initializing Serviio Console
2015-03-08 19:11:32,375 INFO  [ServiioConsole] Starting Serviio Console
2015-03-08 19:11:32,712 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-03-08 19:11:33,358 INFO  [Messages] Loaded console message bundle for locale: en
2015-03-08 19:11:38,785 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2015-03-08 19:11:39,293 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2015-03-08 19:15:28,200 ERROR [ContainerNode] Cannot retrieve results of action command: Cannot execute library command for list: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
   at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:160)
   at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:249)
   at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItems(ActionNode.java:142)
   at org.serviio.upnp.service.contentdirectory.ContentDirectoryEngine.browse(ContentDirectoryEngine.java:102)
   at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:157)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at java.lang.reflect.Method.invoke(Method.java:483)
   at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
   at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
   at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:66)
   at org.apache.http.protocol.HttpService.doService(HttpService.java:423)
   at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:78)
   at org.apache.http.protocol.HttpService.handleRequest(HttpService.java:341)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:204)
Caused by: java.lang.IllegalArgumentException: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
   at java.lang.Enum.valueOf(Enum.java:238)
   at org.serviio.library.local.metadata.MPAARating.valueOf(MPAARating.java:17)
   at org.serviio.library.dao.VideoDAOImpl.initVideo(VideoDAOImpl.java:1420)
   at org.serviio.library.dao.VideoDAOImpl.mapResultSet(VideoDAOImpl.java:1357)
   at org.serviio.library.dao.VideoDAOImpl.retrieveVideosForFolder(VideoDAOImpl.java:349)
   at org.serviio.library.local.service.VideoService.getListOfVideosForFolder(VideoService.java:347)
   at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.getItemsForMediaType(AbstractListObjectsByFSHierarchyCommand.java:256)
   at org.serviio.upnp.service.contentdirectory.command.AbstractListObjectsByFSHierarchyCommand.retrieveList(AbstractListObjectsByFSHierarchyCommand.java:124)
   at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItemList(AbstractCommand.java:154)
   ... 16 more
2015-03-08 19:15:28,203 WARN  [ContentDirectory] Browse for object id V_F^FOL_R1$F131 failed with exception: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
java.lang.RuntimeException: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
   at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeListAction(ContainerNode.java:252)
Caused by: org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for list: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
   ... 15 more
   ... 16 more
Post Sun Mar 08, 2015 8:14 pm
There was probably a problem with update of your library. I'd suggest a clean reinstall.
Lugosi
Post Mon Mar 09, 2015 7:30 pm
A clean re-install solved the problem.
Thanx.
Eldesro
Post Mon Mar 16, 2015 11:54 pm
Hi, I have a similar problem but with my Xbox one since a install the 1.51 update it first tell me "try again later" on each video I try to play... so I try a lot of things reboot every things, I reintall the media player apps on my Xbox and now It wont detect a all the serviio server.
What does you mean by "clean reinstall"
Sorry I usualy speak french
Thank you for your help!!
Eldesro
Post Tue Mar 17, 2015 12:57 pm
Eldesro wrote:Hi, I have a similar problem but with my Xbox one since a install the 1.51 update it first tell me "try again later" on each video I try to play... so I try a lot of things reboot every things, I reintall the media player apps on my Xbox and now It wont detect a all the serviio server.
Eldesro
Clean re-install means to completely uninstall Serviio, reboot the computer, make sure the install folder is completely gone, and install it again.
Users browsing this forum: Google [Bot] and 38 guests
