format error for mkv on sumsung devices
• Page 1 of 1
theres a problem in the profile for Sumsung devices on mkv files, should not be trans-coding issue being that samsungs are compatible,. It does work using the PS3 profile however unsure if this causes any problems , Ill check into the profile further later have any of you already seen this? Seen similar problem with tversity earlier the forums were claiming its a problem with sumsungs header
Re: format error for mkv on sumsung devices
what series profile are you talking about? Most MKV's are not transcoded indeed.
Petr
Help translate Serviio
played a little more, sumsung profiles work for me but I must disable trans-coding all rtogether , which is fine for the tv all mine are mp4, mpeg 2, and mkv, kinda odd though because the ps3 profile is transcoding so what really going on?
sorry bout that itsa C series
Petr
• Page 1 of 1
