format error for mkv on sumsung devices
peters.jeffrey36
Post Wed Mar 16, 2011 9:39 pm
theres a problem in the profile for Sumsung devices on mkv files, should not be trans-coding issue being that samsungs are compatible,. It does work using the PS3 profile however unsure if this causes any problems , Ill check into the profile further later have any of you already seen this? Seen similar problem with tversity earlier the forums were claiming its a problem with sumsungs header
Post Wed Mar 16, 2011 9:41 pm
Re: format error for mkv on sumsung devices
what series profile are you talking about? Most MKV's are not transcoded indeed.
peters.jeffrey36
Post Wed Mar 16, 2011 9:56 pm
played a little more, sumsung profiles work for me but I must disable trans-coding all rtogether , which is fine for the tv all mine are mp4, mpeg 2, and mkv, kinda odd though because the ps3 profile is transcoding so what really going on?
peters.jeffrey36
sorry bout that itsa C series
Post Wed Mar 16, 2011 10:00 pm
you have not provided any info on which we can help.
viewtopic.php?f=5&t=1123
viewtopic.php?f=5&t=7
