Small updating rolling out.
Been a User for quite a While. It is the best for Tablets.
AN Idea, How about this App for FireTV devices? Would be a great way to browse and Watch on a FireTV / Roku smart devices
stevef9432203 wrote:Been a User for quite a While. It is the best for Tablets.
AN Idea, How about this App for FireTV devices? Would be a great way to browse and Watch on a FireTV / Roku smart devices![]()
Fire TV may be possible, since it's Android. It would never work on a Roku, as they use a modified version of Linux, not Android.
Hey Will, you ever tried it on a Shield?
I'm curious if this is applicable to blockchain. Trading and blockchain platforms (like InstaForex) are now demanded for business.
This has nothing to do with Blockchain. The link in your post was deleted, as it has no application to this app or Serviio in general.
Finally i upgrade my serviio server to 2.0 and also ServiiGo on my Firestick with the latest version. Unfortunately I can't play any files, as soon as I click on "Play" Serviigo crash. Can someone help me? On Mediabrowser my files are reproduced correctly. Before on Serviio 1.10 and previous version of ServiiGo i don't have any problems.
** EDIT With ServiiGo 4.4.1 and Serviio 1.10 it works perfectly... Why?
tmtd wrote:Finally i upgrade my serviio server to 2.0 and also ServiiGo on my Firestick with the latest version. Unfortunately I can't play any files, as soon as I click on "Play" Serviigo crash. Can someone help me? On Mediabrowser my files are reproduced correctly. Before on Serviio 1.10 and previous version of ServiiGo i don't have any problems.
Hi, probably easiest to sort this via email, can you email me at the support address and confirm what devices you have used ServiiGo on?
will wrote:tmtd wrote:Finally i upgrade my serviio server to 2.0 and also ServiiGo on my Firestick with the latest version. Unfortunately I can't play any files, as soon as I click on "Play" Serviigo crash. Can someone help me? On Mediabrowser my files are reproduced correctly. Before on Serviio 1.10 and previous version of ServiiGo i don't have any problems.
I don't find support mail on ServiiGo page, con you give it to me? Thank You
Haven't found fresh topics on the subject so here it is.
I tried on both 1.9 and 2.0 serviio version the chromecast feature from the app (last version)
When clicking on the cast icon, it launch a "serviigo" stuff on the tv
Then starting to play a video file: an image of the video appears on the tv, and a progress bar continuously goes on the bottom.
Did i miss something to have it working?
Thank's
Thank's
serviigo.app@gmail.com
kiskouli wrote:Hi,
Thank's
Hi, What model chromecast do you have and what video quality are you using?
will wrote:kiskouli wrote:Hi,
Thank's
Hi will,
chromecast v2 (2015 model)
tried in low quality with all kind of files, only some 480p ones ok... all above ko.
ok with vlc for all though...
kiskouli wrote:will wrote:kiskouli wrote:Hi,
Thank's
Hi will,
Hey - I am having the same issue, Serviio Pro v1.10.1, ServiiGo 5.0.2
Tried with External player and internal player, Casting just refuses to work beyond displaying the 'Ready to Cast' screen, and a Progress Bar + Movie artwork when you attempt to hit 'Play' on *any* media.
Pretty annoying, gonna try the older version of the app but I don't remember seeing the Cast button on there.
Hi. My ServiiGo app showst no content from wi-fi and lte. If i use another app it shows me all media , on wi-fi, but not on lte. What can i do ? Thank you
PS: Need setup advice with router. Forwarded both ports , but still not showing content only images when i go to actors section, very strange.
hd2o wrote:Hi. My ServiiGo app showst no content from wi-fi and lte. If i use another app it shows me all media , on wi-fi, but not on lte. What can i do ? Thank you
I have the same problem, any solution for this yet?
Hi Will,
Would be really great if you would consider adding Android Auto support to ServiiGo in the next update, I think many users will highly appreciate that.
As of my best knowledge this shouldn't be hard as AA api for music players is available.
Video playback is not supported over AA, but music works great.
Thank you!
Thank you!
Where on Earth is Serviigo? All links here direct you to Google Play, which does not have this app. I have been trying to find it for an hour.
bigdenver wrote:Where on Earth is Serviigo? All links here direct you to Google Play, which does not have this app. I have been trying to find it for an hour.
I believe that Serviigo is being reworked by the developer, who pulled the last version from the store because it didn't work correctly with Serviio 2.0. You might send a PM to Will and find out its status.
atc98092 wrote:bigdenver wrote:Where on Earth is Serviigo? All links here direct you to Google Play, which does not have this app. I have been trying to find it for an hour.
So even now ServiiGo 5.0.2 does not work with Serviio 2.0?
I am still using Serviio 1.x as it meets my needs, so I guess it was pulled to try and make a working version for Serviio 1 and 2.
This was a really easy to use app, Any chance you could post the old ServiioGo?
Users browsing this forum: No registered users and 189 guests
