Post Sat Jul 06, 2019 11:36 am
Small updating rolling out.
=== 5.0.1 ===
*Fixed crash when sharing an image externally
*Improved handling of 1.x to 2.x server upgrades
*Various minor bug fixes
stevef9432203
Post Tue Jul 16, 2019 1:40 am
Been a User for quite a While. It is the best for Tablets.
AN Idea, How about this App for FireTV devices? Would be a great way to browse and Watch on a FireTV / Roku smart devices :mrgreen: :geek: :D :P :cry:
Post Tue Jul 16, 2019 12:14 pm
stevef9432203 wrote:Been a User for quite a While. It is the best for Tablets.
Fire TV may be possible, since it's Android. It would never work on a Roku, as they use a modified version of Linux, not Android.
Hey Will, you ever tried it on a Shield?
nutjoe
Post Tue Jul 16, 2019 1:23 pm
I'm curious if this is applicable to blockchain. Trading and blockchain platforms (like InstaForex) are now demanded for business.
Post Tue Jul 16, 2019 6:05 pm
This has nothing to do with Blockchain. The link in your post was deleted, as it has no application to this app or Serviio in general.
tmtd
Post Mon Aug 12, 2019 10:10 am
Finally i upgrade my serviio server to 2.0 and also ServiiGo on my Firestick with the latest version. Unfortunately I can't play any files, as soon as I click on "Play" Serviigo crash. Can someone help me? On Mediabrowser my files are reproduced correctly. Before on Serviio 1.10 and previous version of ServiiGo i don't have any problems.
** EDIT With ServiiGo 4.4.1 and Serviio 1.10 it works perfectly... Why?
Post Mon Aug 12, 2019 7:37 pm
tmtd wrote:Finally i upgrade my serviio server to 2.0 and also ServiiGo on my Firestick with the latest version. Unfortunately I can't play any files, as soon as I click on "Play" Serviigo crash. Can someone help me? On Mediabrowser my files are reproduced correctly. Before on Serviio 1.10 and previous version of ServiiGo i don't have any problems.
Hi, probably easiest to sort this via email, can you email me at the support address and confirm what devices you have used ServiiGo on?
tmtd
Post Tue Aug 13, 2019 1:24 pm
I don't find support mail on ServiiGo page, con you give it to me? Thank You
kiskouli
Post Wed Aug 14, 2019 8:18 am
Haven't found fresh topics on the subject so here it is.
I tried on both 1.9 and 2.0 serviio version the chromecast feature from the app (last version)
When clicking on the cast icon, it launch a "serviigo" stuff on the tv
Then starting to play a video file: an image of the video appears on the tv, and a progress bar continuously goes on the bottom.
Did i miss something to have it working?
Thank's
animaleyes76
Post Sun Aug 25, 2019 11:41 am
tmtd wrote:
will wrote:
serviigo.app@gmail.com
Post Tue Aug 27, 2019 5:14 pm
kiskouli wrote:Hi,
Thank's
Hi, What model chromecast do you have and what video quality are you using?
kiskouli
Post Thu Aug 29, 2019 9:17 am
will wrote:
kiskouli wrote:Hi,
Thank's
Hi will,
chromecast v2 (2015 model)
tried in low quality with all kind of files, only some 480p ones ok... all above ko.
ok with vlc for all though...
itsbranden
Post Sat Sep 07, 2019 1:22 am
kiskouli wrote:
will wrote:
kiskouli wrote:Hi,
Thank's
Hi will,
Hey - I am having the same issue, Serviio Pro v1.10.1, ServiiGo 5.0.2
Tried with External player and internal player, Casting just refuses to work beyond displaying the 'Ready to Cast' screen, and a Progress Bar + Movie artwork when you attempt to hit 'Play' on *any* media.
Pretty annoying, gonna try the older version of the app but I don't remember seeing the Cast button on there.
hd2o
Post Wed Nov 06, 2019 7:04 am
Hi. My ServiiGo app showst no content from wi-fi and lte. If i use another app it shows me all media , on wi-fi, but not on lte. What can i do ? Thank you
PS: Need setup advice with router. Forwarded both ports , but still not showing content only images when i go to actors section, very strange.
kaeh1058
Post Mon Dec 30, 2019 1:04 am
hd2o wrote:Hi. My ServiiGo app showst no content from wi-fi and lte. If i use another app it shows me all media , on wi-fi, but not on lte. What can i do ? Thank you
I have the same problem, any solution for this yet?
Dusha
Post Tue Feb 11, 2020 7:53 am
Hi Will,
Would be really great if you would consider adding Android Auto support to ServiiGo in the next update, I think many users will highly appreciate that.
As of my best knowledge this shouldn't be hard as AA api for music players is available.
Video playback is not supported over AA, but music works great.
Thank you!
bigdenver
Post Sun Mar 22, 2020 9:04 pm
Where on Earth is Serviigo? All links here direct you to Google Play, which does not have this app. I have been trying to find it for an hour.
Post Sun Mar 22, 2020 11:45 pm
bigdenver wrote:Where on Earth is Serviigo? All links here direct you to Google Play, which does not have this app. I have been trying to find it for an hour.
I believe that Serviigo is being reworked by the developer, who pulled the last version from the store because it didn't work correctly with Serviio 2.0. You might send a PM to Will and find out its status.
tmtd
Post Sun Mar 29, 2020 7:15 am
So even now ServiiGo 5.0.2 does not work with Serviio 2.0?
MikeDeadmonton
Post Wed Apr 08, 2020 12:03 am
:shock: I was using ServiioGo on an Android TV device which unfortunately, I corrupted with another bit of software so I reimaged the machine. I had just about everything installed when I went to install ServiioGo and found it wasn' t available.
I am still using Serviio 1.x as it meets my needs, so I guess it was pulled to try and make a working version for Serviio 1 and 2.
This was a really easy to use app, Any chance you could post the old ServiioGo?
