View/edit metadata library
Thanks for your great work.
Nightless wrote:For example, an episode of Lost is called on my pc 'Lost S0601' but on serviio I get 'LA X (1)' as name.
fizze wrote:Implementing "My Movies" but ignoring those XML files swisscenter provides, are we?
zip wrote:Nightless wrote:For example, an episode of Lost is called on my pc 'Lost S0601' but on serviio I get 'LA X (1)' as name.
Did you try Lost S06E01 ?
Мир wrote:I think one of the best way could be to use MySQL for storing all the data. Perhaps I'm asking too much...
chano wrote:So apart from installing serviio, you'd need to also install a complete MySQL server? Sounds pretty much overkill to me..
zip wrote:Serviio uses SQL DB to store the data, Apache Derby. You can connect to it via a JDBC driver and edit the data manually if you wish. There will not be a proper metadata editor though.
Nightless wrote:Sorry typ error, the name is indead S06E01 on my pc but on serviio 'LA X (1)'
zip wrote:Just rename the file to Iron Man and it'll get removed and added again with the correct title.
zip wrote:Apache Derby SQL database
