View/edit metadata library
Elvis71
Post Wed Feb 24, 2010 10:44 am
I have some items that are incorrectly matched in the metadata process. I would like a feature that allows me to view and edit the metadata library. E.g. manually link a file with an imdb entry etc.
Thanks for your great work.
Nightless
Post Thu Feb 25, 2010 7:35 pm
Re: View/edit metadata library
I would like this too.
For example, an episode of Lost is called on my pc 'Lost S0601' but on serviio I get 'LA X (1)' as name.
I hope you'll find a way that I can disable this but for movies I still get the image from the internet.
Post Thu Feb 25, 2010 9:19 pm
Nightless wrote:For example, an episode of Lost is called on my pc 'Lost S0601' but on serviio I get 'LA X (1)' as name.
Did you try Lost S06E01 ?
Post Thu Feb 25, 2010 9:22 pm
I don't think this feature will be implemented, at least not in a near future. Serviio is not really a media management system and for 99% of your content it gets the proper metadata (if you follow the file naming conventions).
As a higher possibility I see integration with something like My Movies - those guys already have metadata management in place and Serviio could just read My Movies files instead of going online.
jvcs23
Post Fri Feb 26, 2010 7:44 am
That sounds like a great idea to me. Apart from my movies, could you look into a connection with Media Browser? http://www.mediabrowser.tv/
regards,
Jacques
fizze
Post Fri Feb 26, 2010 12:28 pm
Implementing "My Movies" but ignoring those XML files swisscenter provides, are we? ;)
:lol: :D
Intel SS4200 - Ubuntu Server 8.04
LG BD - 390
Post Fri Feb 26, 2010 2:27 pm
fizze wrote:Implementing "My Movies" but ignoring those XML files swisscenter provides, are we? ;)
:lol: :D
Add a feature request to the issue tracker and we'll see how it goes ;-) I haven't decided yet what kind of functionality will go into 0.5 :twisted:
Nightless
Post Fri Feb 26, 2010 4:54 pm
Sorry typ error, the name is indead S06E01 on my pc but on serviio 'LA X (1)'
Мир
Post Mon Mar 21, 2011 9:28 pm
Uhm... I'd like to be able to edit metadata too. I think one of the best way could be to use MySQL for storing all the data. Perhaps I'm asking too much...
chano
Post Tue Mar 29, 2011 10:14 pm
Мир wrote:I think one of the best way could be to use MySQL for storing all the data. Perhaps I'm asking too much...
So apart from installing serviio, you'd need to also install a complete MySQL server? Sounds pretty much overkill to me..
Post Wed Mar 30, 2011 8:38 am
Serviio uses SQL DB to store the data, Apache Derby. You can connect to it via a JDBC driver and edit the data manually if you wish. There will not be a proper metadata editor though.
Мир
Post Sun Apr 03, 2011 8:07 pm
chano wrote:So apart from installing serviio, you'd need to also install a complete MySQL server? Sounds pretty much overkill to me..
No, I don't think so. If you already have a running linux, to have or not to have MySQL installed it does not change a lot. MySQL is not resource-eating, unless you setup a server and give a lot of of job (I mean really a lot) to MySQL...
...Under Windows could be different...
Мир
Post Sun Apr 03, 2011 8:09 pm
zip wrote:Serviio uses SQL DB to store the data, Apache Derby. You can connect to it via a JDBC driver and edit the data manually if you wish. There will not be a proper metadata editor though.
Thanks, this is interesting.. I'll try...
Berny
Post Tue Apr 05, 2011 3:46 pm
Nightless wrote:Sorry typ error, the name is indead S06E01 on my pc but on serviio 'LA X (1)'
LAX (1) is the title of the episode 1 of the 6th season, LAX (2) the second, What Kate Does is the third, etc...
chromium
Post Mon Jul 11, 2011 12:47 pm
What's the best way to open the database file so I can edit it manually?
I want to fix some of the names of things.
I had Iron Man named Ironman, so it named it Lauf um Dein Leben - Vom Junkie zum Ironman
Is the only way to fix it through Serviio to name the file correctly and force it to grab the metadata for my entire collection again?
Also, I had Get Him To The Greek (Unrated) and it didn't find it online so now it doesn't appear in the Movies category. Is there any easy way of seeing what didn't get put into a category? It seems the only way I can find it is to trawl through the Titles category or go to the folder directly. Is there a better way of managing the metadata rather than letting Serviio do it directly? Could I use something that creates XBMC style info and get Serviio to use that?
Post Mon Jul 11, 2011 12:51 pm
Just rename the file to Iron Man and it'll get removed and added again with the correct title.
chromium
Post Mon Jul 11, 2011 12:53 pm
zip wrote:Just rename the file to Iron Man and it'll get removed and added again with the correct title.
Cool, I was hoping that would happen. What about stuff that doesn't get put into categories? I wish there was another presentation category called Unknown or something, then I could easily see what was missed and go and fix the filenames up.
If I could access the database I could find the files that are missing metadata and figure it out myself. What format is it in?
Post Mon Jul 11, 2011 1:10 pm
Apache Derby SQL database
chromium
Post Mon Jul 11, 2011 1:12 pm
zip wrote:Apache Derby SQL database
Thanks, any chance of adding a presentation category for files with missing metadata in a future release?
Awesome app btw :)
Post Mon Jul 11, 2011 1:39 pm
Not for now. You should be able to double check metadata via the Last Added category.
Return to Feature requests
