[mac][37LE5500] Subtitles not playing
morphi
Post Wed Aug 03, 2011 8:47 pm
I own a LG 37LE5500 and I using serviio on a mac 0sx 10.6.8. It is the best solution, I have found so far - thank for your effort in putting it together.
Only issue is that subtitles are not playing.
Looking into the forum, I found that it could help to change the default profile of the client to solve some problems but I couldn't find where the value is to be set in the mac console.
So I have edited the file manually and added the line related to tex/srt in the generic profile but it doesn't work (Sorry I know it written in big - DO NOT EDIT) :-)
I am playing file 12AngryMen.avi which is stored along 12AngryMen.srt.
It is playing just fine but without the subtiltes.
Would you be able to point me to the right direction, I enclose the log for your information. There is an error and no mention of retrieving a srt file.
Thanks,
francois
logs - Startup then playing 12AngryMen.avi:
2011-08-03 22:41:27,902 INFO  [WebServer] WebServer starting on port 8895
2011-08-03 22:41:27,903 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-03 22:41:27,903 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 10.0.0.141, timeout = 0
2011-08-03 22:41:27,903 INFO  [EventDispatcher] Starting EventDispatcher
2011-08-03 22:41:27,903 INFO  [RendererSearchSender] Searching for Renderer devices
2011-08-03 22:41:27,903 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-03 22:42:01,696 WARN  [ContentDirectory] Browse for object id V_F#FOL_R1$F2/12AngryMen.avi failed with exception: null
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.getObjectValueForAttribute(GenericDLNAMessageBuilder.java:301)
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.getObjectValue(GenericDLNAMessageBuilder.java:284)
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeAttribute(GenericDLNAMessageBuilder.java:240)
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeAttribute(GenericDLNAMessageBuilder.java:257)
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeItemFields(GenericDLNAMessageBuilder.java:152)
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeObjectNode(GenericDLNAMessageBuilder.java:128)
   at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.buildXML(GenericDLNAMessageBuilder.java:102)
   at org.serviio.upnp.service.contentdirectory.ContentDirectory.setupSuccessfulResult(ContentDirectory.java:377)
   at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:209)
   at sun.reflect.GeneratedMethodAccessor21.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
   at java.lang.reflect.Method.invoke(Method.java:597)
   at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
   at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
   at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:73)
2011-08-03 22:42:01,717 WARN  [ContentDirectory] Browse for object id V_F#FOL_R1$F2/12AngryMen.avi failed with exception: null
Post Wed Aug 03, 2011 8:55 pm
Re: [mac][37LE5500] Subtitles not playing
next to your device is a drop down menu click on it and then you can set the correct profile.
morphi
Post Thu Aug 04, 2011 4:50 pm
yes got it !!
thanks
With the LG profile given on this forum, the subtitles are now working just fine.
Cheers
Post Thu Aug 04, 2011 5:39 pm
morphi wrote:yes got it !!
thanks
Cheers
your welcome..
Return to LG
