[mac][37LE5500] Subtitles not playing
I own a LG 37LE5500 and I using serviio on a mac 0sx 10.6.8. It is the best solution, I have found so far - thank for your effort in putting it together.
Only issue is that subtitles are not playing.
Looking into the forum, I found that it could help to change the default profile of the client to solve some problems but I couldn't find where the value is to be set in the mac console.
So I have edited the file manually and added the line related to tex/srt in the generic profile but it doesn't work (Sorry I know it written in big - DO NOT EDIT)
I am playing file 12AngryMen.avi which is stored along 12AngryMen.srt.
It is playing just fine but without the subtiltes.
Would you be able to point me to the right direction, I enclose the log for your information. There is an error and no mention of retrieving a srt file.
Thanks,
francois
logs - Startup then playing 12AngryMen.avi:
Thanks,
francois
- Code:
2011-08-03 22:41:27,902 INFO [WebServer] WebServer starting on port 8895
2011-08-03 22:41:27,903 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-03 22:41:27,903 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 10.0.0.141, timeout = 0
2011-08-03 22:41:27,903 INFO [EventDispatcher] Starting EventDispatcher
2011-08-03 22:41:27,903 INFO [RendererSearchSender] Searching for Renderer devices
2011-08-03 22:41:27,903 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-03 22:42:01,696 WARN [ContentDirectory] Browse for object id V_F#FOL_R1$F2/12AngryMen.avi failed with exception: null
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.getObjectValueForAttribute(GenericDLNAMessageBuilder.java:301)
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.getObjectValue(GenericDLNAMessageBuilder.java:284)
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeAttribute(GenericDLNAMessageBuilder.java:240)
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeAttribute(GenericDLNAMessageBuilder.java:257)
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeItemFields(GenericDLNAMessageBuilder.java:152)
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.storeObjectNode(GenericDLNAMessageBuilder.java:128)
at org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder.buildXML(GenericDLNAMessageBuilder.java:102)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.setupSuccessfulResult(ContentDirectory.java:377)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:209)
at sun.reflect.GeneratedMethodAccessor21.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:73)
2011-08-03 22:42:01,717 WARN [ContentDirectory] Browse for object id V_F#FOL_R1$F2/12AngryMen.avi failed with exception: null
