Problems with MKV / H.264 on Sony BDP-S370 Bluray-Player
Lowlander
Post Tue Jun 22, 2010 2:19 pm
@unbekannt:
You appear to have carried out extensive testing with the S370 and Serviio: Do have any results concerning subtitles?
@all:
If you choose the Serviio server from the player's video menu, another choice of Video, Images and Music appears. Do we have any option to get rid of this first level of folders and jump directly into the video tree structure?
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
unbekannt
Post Tue Jun 22, 2010 4:02 pm
Re: Problems with MKV / H.264 on Sony BDP-S370 Bluray-Player
I only have tested subtitles in MKVs and the following work fine: SRT und IDX/SUB. Multiple IDX-subtitles work, don't know about mulitple SRTs. A SUP from a BR can be converted to IDX/SUB with BDSup2Sub in a matter of seconds. Quality with IDX is way better than with SRT in my samples, but sadly not as superb as a real BR subtitle :cry:
Edit: Just ran into problems. I have to "resize" the subtitles in BDSup2Sub to 720p, if I choose 1080p or don't convert at all, than mainly glibberish is displayed. But that's only one additional click :)
Edit 2: Just tested again. Enabling an IDX subtitle when streaming will bring the stutter back :cry:
Regarding the folders: This is beeing discussed in a few thread in the forum (section "Feature Requests" for example). So far it doesn't seem possible to change how and if the folders are displayed.
unbekannt
scapman
Post Wed Jun 23, 2010 7:36 am
Hallo.
I have upgraded to 0.4.1 but myvideos still suffer from stuttering even without fast forwarding or jumping to other chapters.
I just select the file and the playing (audio and video) stutters....
unbekannt
Post Wed Jun 23, 2010 11:18 am
@scapman:
Is there an "DIVX" icon right under the file name when listing the folder contents on the player? Did you change the ID in the profile (0.4.1 has some additional profiles already in profiles.xml, so the ID needs to be incremented to 9, I think).
unbekannt
scapman
Post Wed Jun 23, 2010 4:30 pm
@ unbekannt:
There is a Divx icon under the file name.
I have reinstalled the 0.4.1 version and re-compiled the xml file.
Now it seems to work fine! :D
Just another issue; with DTS audio it says "audio file format not supported", even though I am still able to listen to the movie...
unbekannt
Post Wed Jun 23, 2010 5:38 pm
scapman wrote:Just another issue; with DTS audio it says "audio file format not supported", even though I am still able to listen to the movie...
Same here. I have connected the player to my A/V receiver which takes over the job of decoding from the player. That should explain it. Do you also use an A/V receiver?
unbekannt
scapman
Post Thu Jun 24, 2010 6:15 am
@ unbekannt:
Yes.
Ihave the BPD-S370 connected via HDMI to a Sony RHT-G950 Home Theater System, which is capable of deconding DTS though.
wisepass
Post Sat Jul 03, 2010 1:00 pm
Hey firstly can I just say big thanks I've just discovered Serviio after buying a Sony BDP-370 but its pretty great and simple..does exactly what I want it to and no messing so keep up the good work.
I've managed to get MKV's and any other file I throw at it working by doing the following. (Just in a nice list for anyone else to easily follow.
1. Installed the program opened the console and added my media files and then giver serviio some time to gather and compile the info it needs. I also set CPU's to 4.
2. Strangly my Sony BDP-370 automatically found serviio and it was just sitting there for me but I expect some people may need to search for the server on their player.
3. I edited the profiles file in C:\Program Files (x86)\Serviio\config and entered the following txt
<Profile id="7" name="Sony BDP-S370" extendsProfileId="1">
   <Detection>
      <X-AV-Client-Info>.*Blu-ray Disc Player.*</X-AV-Client-Info>
   </Detection>
   <MediaFormatProfiles>
      <MediaFormatProfile mime-type="video/divx">MATROSKA</MediaFormatProfile>
   </MediaFormatProfiles>
4. Reset my PC and serviio (well I reset the service, but it would be easier to restart) and then selected the Sony BDP-370 under the profiles selection on the console.
5. Played pretty much every movie file on my PC.
Extra notes. - Like has already been said I also get the audio not compatible issue like you guys when playing MKV's with DTS but I dont have my BDP-370 connected to an AV source like you guys do and still get the "issue" but it doesn't particually worry me personally. Also my videos are also all seemingly registered as the same format on the play, which also doesn't bother me and I've sure is related to the above profile.
Not seem any other issues but will report them if I do. I have a quad core PC, wired network throughout (anyone who trying to stream HD video over wireless should probably rethink things...the player's buffer a certain amount of data so initally they will appear to run smooth but then the data falls behide...there's simply not enough throughput on a Wireless G network, trust me I've tried it on a perfect connection).
Anyway big thanks and I'll keep trying to report any issues I have to hopefully help.
arman
Post Fri Jul 16, 2010 9:01 am
Hello dear friends,
I'm really new in this staff and I have a problem with serviio conection. The problem is that I can see the server under Photo and Music sections, but it is not under Video. I tried to uninstall servio and install it back, then I delete the serviio from the player and then scaned again, but still having same problem. Just cant see the server under Video section. The serviio version I have is 0.4.1 and the firmware on the Sony BDP-S370 Bluray-Player is M03.R.623
Please help!!! :(
bh4bama
Post Tue Jul 20, 2010 8:39 pm
I did the same changes that wisepass did to Serviio and still cannot get any of my videos to play. The BDP-S370 can see my PC, and I can view/play MPEG movies via Windows Media. When I go under BDP-S370's MUSIC folder and click on Serviio, I can then go under Movies folder and see my PC's folder structure. When I go into a folder to play a MKV or whatever, I get a popup stating "No playable files found". In fact, it doesn't even see my MPEGs either. Anyone could help, I would appreciate it.
Post Tue Jul 20, 2010 9:26 pm
Can you post the log to see if your video files have been added to the library?
arman
Post Wed Jul 21, 2010 4:54 am
Please, please, anybody I need your help on this. I post this question but never got any answers yet.
I'm really new in this staff and I have a problem with serviio connection. The problem is that I can see the server under Photo and Music sections, but it is not under Video. I tried to uninstall servio and install it back, then I delete the serviio from the player and then scaned again, but still having same problem. Just can’t see the server under Video section. I also tried to
Delete server in player setting
Stop server, shutdown player
Start player, wait till it has loaded
Start server. But still nothing under Video section.
Thanks!!!
rmaffeo
Post Wed Jul 21, 2010 5:10 pm
For what it's worth, I have the same problem with the Serviio server not appearing under the video section of the BDP-S370, and am not sure why. I'm beginning to suspect an issue with the firmware.
I've extended the default profile in the config XML as described in this thread, and here are relevant parts of the log (I see this repeated about 3 times):
2010-07-17 19:47:01,585 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.32:62878
2010-07-17 19:47:01,586 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-07-17 19:47:01,683 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.32:62878
2010-07-17 19:47:01,684 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-07-17 19:47:01,784 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.1.32:62878
2010-07-17 19:47:01,785 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-07-17 19:47:01,864 DEBUG [WebServer] Incoming connection from /192.168.1.32:63243
2010-07-17 19:47:02,011 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 204683ed-9f48-3c47-b70d-0da4ab7276fa from UPnP/1.0
2010-07-17 19:47:02,016 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Sony BDP-S370'
2010-07-17 19:47:02,101 DEBUG [WebServer] Incoming connection from /192.168.1.32:63244
2010-07-17 19:47:02,199 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2010-07-17 19:47:02,225 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-07-17 19:47:02,442 DEBUG [WebServer] Incoming connection from /192.168.1.32:63245
2010-07-17 19:47:02,584 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-07-17 19:47:02,622 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-07-17 19:47:02,924 DEBUG [WebServer] Incoming connection from /192.168.1.32:63246
2010-07-17 19:47:03,018 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from UPnP/1.0 DLNADOC/1.50:
2010-07-17 19:47:03,227 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-07-17 19:47:03,327 DEBUG [WebServer] Incoming connection from /192.168.1.32:63247
2010-07-17 19:47:03,424 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ConnectionManager:1#GetProtocolInfo"' from UPnP/1.0 DLNADOC/1.50:
2010-07-17 19:47:03,633 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
Any ideas appreciated...
Post Wed Jul 21, 2010 6:36 pm
This is all ok, the player just gets descriptions of Serviio's services. Not sure what your problem is, it seems to work for some.. ?
Begall
Post Wed Jul 21, 2010 8:19 pm
Been having a problem using Serviio & the S370 with subtitled MKV's. Was a little confused to begin with, because some would play fine while others did not, but I've narrowed it down to the unsupported MKV's having subtitles. I don't really care about having subtitles, so is there someway of transcoding this in serviio?
Post Wed Jul 21, 2010 8:28 pm
You could try this (which will remux all MKV files into mpeg2ts with the same audio/video streams):
or if it's not playable, this (which will transcode MKV files into mpeg2ts with mpeg2 video and ac3 audio):
Begall
Post Wed Jul 21, 2010 8:54 pm
Hmm, adding either of those to a profile results in the service refusing to start with the logged error message:
ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-complex-type.2.4.a: Invalid content was found starting with element 'Video'. One of '{ContentDirectoryMessageBuilder, ProtocolInfo, DeviceDescription, ResourceTransportProtocolHandler, ContentDirectoryDefinitionFilter, Transcoding, LimitImageResolution, SubtitlesMimeType}' is expected.
Strangely, in some of the other pre-set profiles, the same structure is used with no problem.
EDIT: Whoops, my bad! Forgot the transcoding tags
Begall
Post Wed Jul 21, 2010 9:31 pm
Ok, from further testing.
The first profile will remove all mkv's from the menu, both with and without the earlier code which makes the player see them as DivX files.
The second profile will display mkv's as M2TS files, but then all MKV's (subtitled or not) became Corrupt/Unsupported.
I also did a further test of removing the subtitles stream using an MKV editor. This caused the player to hang while loading the file, and I had to pull the plug to fix it :( Tested the stripped file in WMP too and that just gave the unsupported message rather then hanging.
Hope there's some useful information in there, I think I must be doing something wrong.
Post Wed Jul 21, 2010 10:45 pm
YOu can turn on detailed logging and see what ffmpeg command is invoked when transcoding. You can then try tweaking it to produce a file that your player can play (without further transcoding). If you come up with something I'll be glad to incorporate it into a future version, if possible.
Begall
Post Wed Jul 21, 2010 11:12 pm
My solution in the end was unrelated to subtitles. Turns out it was a problem with the profile levels of certain files. Edited them to level 4 and now they're working fine. Guess that's a problem with the player, so sorry for wasting your time :)
Users browsing this forum: No registered users and 98 guests
