TV3Play (Estonia)
DMXXX
Post Sat Oct 01, 2011 10:59 am
TV3Play (Estonia)
Saw that there was a plugin for tv3play.se and wish that someone would make one for tv3play.ee.
Thanks!
Post Sat Oct 01, 2011 11:15 am
Re: TV3Play (Estonia)
they should work the same with same plugin.
DMXXX
Post Sat Oct 01, 2011 11:20 am
Hmm.. You sure? I tried one stream from tv3play.se and the vids showed up immediately but any feeds from tv3play.ee don't seem to work.
Post Sat Oct 01, 2011 11:21 am
yer i theory but i dont think they have got it work correctly yet.
EDIT: ah ok i see how hes done it try this plugin
Tv3Play(EE).groovy
(2.6 KiB) Downloaded 830 times
DMXXX
Post Sat Oct 01, 2011 11:36 am
Unfortunately it doesn't work. Thanks for the effort though!
Post Sat Oct 01, 2011 11:38 am
DMXXX wrote:Unfortunately it doesn't work. Thanks for the effort though!
do you get any errors in the log file ?
EDIT: nope found the error i think try this one.
Tv3Play(EE).groovy
(2.6 KiB) Downloaded 783 times
DMXXX
Post Sat Oct 01, 2011 11:40 am
Indeed there are a bunch of errors there.
2011-10-01 14:39:49,694 WARN  [PluginCompilerThread] Plugin Tv3Play(EE).groovy failed to compile: startup failed:
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 16: unable to resolve class FeedItemUrlExtractor
 @ line 16, column 1.
   class Tv3Play extends FeedItemUrlExtractor {
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 28: unable to resolve class PreferredQuality
 @ line 28, column 47.
   ntainer extractUrl(Map links, PreferredQ
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 28: unable to resolve class ContentURLContainer
 @ line 28, column 5.
       ContentURLContainer extractUrl(Map links, PreferredQuality requestedQuality) {
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 66: unable to resolve class ContentURLContainer
 @ line 66, column 16.
           return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: contentUrl, thumbnailUrl: thumbUrl)
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 80: unable to resolve class ContentURLContainer
 @ line 80, column 29.
           ContentURLContainer result = extractor.extractUrl(links, PreferredQuality.MEDIUM)
5 errors
2011-10-01 14:39:59,734 WARN  [PluginCompilerThread] Plugin Tv3Play(EE).groovy failed to compile: startup failed:
EDIT: I'll try the new one.
Post Sat Oct 01, 2011 11:43 am
yer i fix the class error i change a line i didnt mean to :oops:
DMXXX
Post Sat Oct 01, 2011 11:52 am
Now there are new errors in the log:
2011-10-01 14:47:32,606 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450841. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
   at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
   ... 1 more
2011-10-01 14:47:38,059 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450840. It might not play.
   ... 1 more
2011-10-01 14:47:43,500 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450839. It might not play.
   ... 1 more
2011-10-01 14:47:49,013 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450838. It might not play.
   ... 1 more
2011-10-01 14:47:54,447 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424311. It might not play.
   ... 1 more
2011-10-01 14:47:59,879 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424310. It might not play.
   ... 1 more
2011-10-01 14:48:08,047 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424309. It might not play.
   ... 1 more
2011-10-01 14:48:13,470 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424308. It might not play.
   ... 1 more
2011-10-01 14:48:18,891 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424307. It might not play.
   ... 1 more
2011-10-01 14:48:24,327 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424306. It might not play.
   ... 1 more
2011-10-01 14:48:29,736 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424305. It might not play.
   ... 1 more
2011-10-01 14:48:35,163 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424304. It might not play.
   ... 1 more
2011-10-01 14:48:40,576 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424303. It might not play.
   ... 1 more
2011-10-01 14:48:46,001 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424302. It might not play.
   ... 1 more
2011-10-01 14:48:51,459 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424301. It might not play.
   ... 1 more
2011-10-01 14:48:56,892 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424300. It might not play.
   ... 1 more
2011-10-01 14:49:02,301 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398457. It might not play.
   ... 1 more
2011-10-01 14:49:05,635 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-10-01 14:49:05,735 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2011-10-01 14:49:05,839 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-10-01 14:49:05,839 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-10-01 14:49:07,739 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398456. It might not play.
   ... 1 more
2011-10-01 14:49:13,173 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398455. It might not play.
   ... 1 more
2011-10-01 14:49:18,600 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398454. It might not play.
   ... 1 more
2011-10-01 14:49:24,033 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450841. It might not play.
   ... 1 more
2011-10-01 14:49:29,472 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450840. It might not play.
   ... 1 more
2011-10-01 14:49:34,905 WARN  [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450839. It might not play.
   ... 1 more
Post Sat Oct 01, 2011 12:02 pm
nope sry guess its not gunna work, ah well worth a try but this is one for someone smarter than me.
DMXXX
Post Sat Oct 01, 2011 12:06 pm
Oh well. Thanks for the help!
FlamingLizard
Post Sat Oct 01, 2011 2:16 pm
It seems that tv3play.ee uses some sort of verification of the player running the file, or at least that's how I read it...
C:\Program Files (x86)\Serviio\lib>ffmpeg -i rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/k2limehed/season3/451492
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-li
bmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enab
le-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
rtmp server sent error
rtmp server requested close
rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/k2limehed/season3/451492: Operation not permitted
I am allowed to watch the show on the site though, so shouldn't be a country-filter thing... Ideas anyone?
Tomas
Samsung LE46B650
Serviio 0.6 on Win7x64 ultimate
Post Sat Oct 01, 2011 3:24 pm
ah ok thanks for confirming lizard, so taht a no go on this one then sorry
Post Sun Oct 09, 2011 2:21 pm
most likely a swf verification. Needs to be done similar to iPlayer, capture the required parameters using rtmpserver as described in the link in the feed dev guide
Ruff
Post Sun Dec 30, 2012 11:39 am
More than year later!
I replaced all tv3play.se with tv3play.ee in original tv3play.groovy file without renaming the file and all seem to work with media browser. Didn't work with dierent filename.
Return to Plugin requests
