TV3Play (Estonia)
Thanks!
DMXXX wrote:Unfortunately it doesn't work. Thanks for the effort though!
2011-10-01 14:39:49,694 WARN [PluginCompilerThread] Plugin Tv3Play(EE).groovy failed to compile: startup failed:
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 16: unable to resolve class FeedItemUrlExtractor
@ line 16, column 1.
class Tv3Play extends FeedItemUrlExtractor {
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 28: unable to resolve class PreferredQuality
@ line 28, column 47.
ntainer extractUrl(Map links, PreferredQ
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 28: unable to resolve class ContentURLContainer
@ line 28, column 5.
ContentURLContainer extractUrl(Map links, PreferredQuality requestedQuality) {
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 66: unable to resolve class ContentURLContainer
@ line 66, column 16.
return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: contentUrl, thumbnailUrl: thumbUrl)
C:\Program Files (x86)\Serviio\plugins\Tv3Play(EE).groovy: 80: unable to resolve class ContentURLContainer
@ line 80, column 29.
ContentURLContainer result = extractor.extractUrl(links, PreferredQuality.MEDIUM)
5 errors
2011-10-01 14:39:59,734 WARN [PluginCompilerThread] Plugin Tv3Play(EE).groovy failed to compile: startup failed:
2011-10-01 14:47:32,606 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450841. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:188)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:93)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:318)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:68)
at org.serviio.library.online.metadata.FeedUpdaterThread.updateLazyLoadedProperties(FeedUpdaterThread.java:169)
... 1 more
2011-10-01 14:47:38,059 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450840. It might not play.
... 1 more
2011-10-01 14:47:43,500 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450839. It might not play.
... 1 more
2011-10-01 14:47:49,013 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450838. It might not play.
... 1 more
2011-10-01 14:47:54,447 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424311. It might not play.
... 1 more
2011-10-01 14:47:59,879 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424310. It might not play.
... 1 more
2011-10-01 14:48:08,047 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424309. It might not play.
... 1 more
2011-10-01 14:48:13,470 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424308. It might not play.
... 1 more
2011-10-01 14:48:18,891 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424307. It might not play.
... 1 more
2011-10-01 14:48:24,327 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424306. It might not play.
... 1 more
2011-10-01 14:48:29,736 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424305. It might not play.
... 1 more
2011-10-01 14:48:35,163 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424304. It might not play.
... 1 more
2011-10-01 14:48:40,576 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424303. It might not play.
... 1 more
2011-10-01 14:48:46,001 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424302. It might not play.
... 1 more
2011-10-01 14:48:51,459 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424301. It might not play.
... 1 more
2011-10-01 14:48:56,892 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season4/424300. It might not play.
... 1 more
2011-10-01 14:49:02,301 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398457. It might not play.
... 1 more
2011-10-01 14:49:05,635 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-10-01 14:49:05,735 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2011-10-01 14:49:05,839 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-10-01 14:49:05,839 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-10-01 14:49:07,739 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398456. It might not play.
... 1 more
2011-10-01 14:49:13,173 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398455. It might not play.
... 1 more
2011-10-01 14:49:18,600 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/398454. It might not play.
... 1 more
2011-10-01 14:49:24,033 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450841. It might not play.
... 1 more
2011-10-01 14:49:29,472 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450840. It might not play.
... 1 more
2011-10-01 14:49:34,905 WARN [FeedUpdaterThread] Failed to retrieve feed item information for rtmp://mtgfs.fplive.net/mtg/mp4:flash/estonia/tv3/katte/season5/450839. It might not play.
... 1 more
