Wireless stream of 3D movies
• Page 1 of 2 • 1, 2
Is wireless streaming of 3D movies worth it? i mean do you loose video quality? i tried streaming one and during the full movie i saw a loading bar once... it didn't seem corrupted or pixelated.. is there a way to check the bandwidth/rate at which the movie is being transfer??
Re: Wireless stream of 3D movies
it's streamed as the TV requests it, so there will be no quality reduction
Petr
Help translate Serviio
zip wrote:it's streamed as the TV requests it, so there will be no quality reduction
Cool thanks... Now few of the movies that i have, they come with the regular .mkv file and also have a .srt file... If i keep both of them in the same folder will servo merge them and my tv will play both of them at the same time???
Rename the srt file to the same name as your movie (keeping it in the same directory) and if your player supports it you will able to see subtitles.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
YTMY wrote:Rename the srt file to the same name as your movie (keeping it in the same directory) and if your player supports it you will able to see subtitles.
thxs
also i can't fast forward... why is that? I can pause, stop , play but can't fast forward
use right and left buttons (not fast forward and rewind).
YTMY wrote:use right and left buttons (not fast forward and rewind).
Ya tried those and no go
One of the movies i was washing it stops at the same point (15min) every time i play it, if i play it using vnc it plays fine.. any idea?
SuperMiguel wrote:YTMY wrote:use right and left buttons (not fast forward and rewind).
Tried few more .mkv movies and all of them stop at certain point of the movie... one after 2 seconds, other after 5 min, other 6, etc
SuperMiguel wrote:SuperMiguel wrote:YTMY wrote:use right and left buttons (not fast forward and rewind).
server installed on an 2011 iMac
any one??
Could you check videobitrate of your movie, must be <20-25Mbps?
Do you have library auto refresh enabled, a refresh during movie streaming need CPU and network bandwidth?
We also need information about your mkv file, provide "ffmpeg -i" and MediaInfo result ? (see signature links)
Illico wrote:Could you check videobitrate of your movie, must be <20-25Mbps?
This movie is Tron 3d, it last about 2 seconds before it stops, library auto refresh is enabled,
Videobitrate:
Mediainfo:
ffmpeg -i:
- Code:
Miguels-iMac:MacOS Miguel$ ./ffmpeg -i ~/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv
ffmpeg version 0.8.git, Copyright (c) 2000-2011 the FFmpeg developers
built on Aug 14 2011 22:07:26 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
/Users/Miguel/Volumes/Macintosh: No such file or directory
try to change h264 level from 5.1 to 4.1 using viewtopic.php?f=17&t=2118
Petr
Videobitrate:
- result is strange, Total time is 5s !!, this mkv file should be corrupted, do you try with VLC or MediaPlayer Classic on your MacOS ?
Mediainfo:
- Please provide in text output format
ffmpeg -i:
retry with " " around file path
In fact h264 Level 5.1 is not supported, must be less than 4.1.
Try with Zip link.
Mediainfo:
ffmpeg -i:
Try with Zip link.
Illico wrote:Videobitrate:
Yup VLC plays it fine..
- Code:
Miguels-iMac:MacOS Miguel$ ./ffmpeg -i "/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv"
[matroska,webm @ 0x116b000] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv':
title : TRON_LEGACY
Duration: 02:05:08.31, start: 0.000000, bitrate: 1536 kb/s
Chapter #0.0: start 0.000000, end 247.163000
title : (01)00:00:00:000
Chapter #0.1: start 247.163000, end 884.133000
title : (02)00:04:07:163
Chapter #0.2: start 884.133000, end 1395.602000
title : (03)00:14:44:133
Chapter #0.3: start 1395.602000, end 1612.694000
title : (04)00:23:15:602
Chapter #0.4: start 1612.694000, end 2172.211000
title : (05)00:26:52:694
Chapter #0.5: start 2172.211000, end 2315.980000
title : (06)00:36:12:211
Chapter #0.6: start 2315.980000, end 2812.726000
title : (07)00:38:35:980
Chapter #0.7: start 2812.726000, end 3183.763000
title : (08)00:46:52:726
Chapter #0.8: start 3183.763000, end 3894.181000
title : (09)00:53:03:763
Chapter #0.9: start 3894.181000, end 4427.422000
title : (10)01:04:54:181
Chapter #0.10: start 4427.422000, end 4740.944000
title : (11)01:13:47:422
Chapter #0.11: start 4740.944000, end 4960.455000
title : (12)01:19:00:944
Chapter #0.12: start 4960.455000, end 5150.895000
title : (13)01:22:40:455
Chapter #0.13: start 5150.895000, end 5291.828000
title : (14)01:25:50:895
Chapter #0.14: start 5291.828000, end 5502.413000
title : (15)01:28:11:828
Chapter #0.15: start 5502.413000, end 6193.061000
title : (16)01:31:42:413
Chapter #0.16: start 6193.061000, end 6498.033000
title : (17)01:43:13:061
Chapter #0.17: start 6498.033000, end 6888.381000
title : (18)01:48:18:033
Chapter #0.18: start 6888.381000, end 7083.659000
title : (19)01:54:48:381
Chapter #0.19: start 7083.659000, end 7508.319999
title : (20)01:58:03:659
Chapter #0.20: start 7508.417000, end 7508.319999
title : (21)02:05:08:417
Stream #0.0: Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 48003.07 tbn, 47.95 tbc (default)
Stream #0.1(eng): Audio: dca (DTS-HD MA), 48000 Hz, 5.1, s16, 1536 kb/s (default)
Try with Zip link.
Did this and same result
Then your video really is 5.1 and will not play with Serviio until you reencode it to level 4.1
jhb50 wrote:Then your video really is 5.1 and will not play with Serviio until you reencode it to level 4.1
ummm
Users browsing this forum: Baidu [Spider] and 3 guests
