Wireless stream of 3D movies
SuperMiguel
Post Tue Nov 29, 2011 1:51 am
Is wireless streaming of 3D movies worth it? i mean do you loose video quality? i tried streaming one and during the full movie i saw a loading bar once... it didn't seem corrupted or pixelated.. is there a way to check the bandwidth/rate at which the movie is being transfer??
SuperMiguel
Post Tue Nov 29, 2011 11:34 am
Re: Wireless stream of 3D movies
bump
Post Tue Nov 29, 2011 1:44 pm
it's streamed as the TV requests it, so there will be no quality reduction
SuperMiguel
Post Tue Nov 29, 2011 4:31 pm
zip wrote:it's streamed as the TV requests it, so there will be no quality reduction
Cool thanks... Now few of the movies that i have, they come with the regular .mkv file and also have a .srt file... If i keep both of them in the same folder will servo merge them and my tv will play both of them at the same time???
YTMY
Post Tue Nov 29, 2011 4:48 pm
Rename the srt file to the same name as your movie (keeping it in the same directory) and if your player supports it you will able to see subtitles.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
SuperMiguel
Post Tue Nov 29, 2011 6:22 pm
YTMY wrote:Rename the srt file to the same name as your movie (keeping it in the same directory) and if your player supports it you will able to see subtitles.
thxs
SuperMiguel
Post Tue Nov 29, 2011 6:55 pm
also i can't fast forward... why is that? I can pause, stop , play but can't fast forward
YTMY
Post Tue Nov 29, 2011 7:09 pm
use right and left buttons (not fast forward and rewind).
SuperMiguel
Post Tue Nov 29, 2011 7:50 pm
YTMY wrote:use right and left buttons (not fast forward and rewind).
Ya tried those and no go :(
One of the movies i was washing it stops at the same point (15min) every time i play it, if i play it using vnc it plays fine.. any idea?
SuperMiguel
Post Wed Nov 30, 2011 12:39 am
Tried few more .mkv movies and all of them stop at certain point of the movie... one after 2 seconds, other after 5 min, other 6, etc
SuperMiguel
Post Wed Nov 30, 2011 2:42 am
server installed on an 2011 iMac
SuperMiguel
Post Wed Nov 30, 2011 6:39 am
any one??
Post Wed Nov 30, 2011 8:21 am
Could you check videobitrate of your movie, must be <20-25Mbps?
Do you have library auto refresh enabled, a refresh during movie streaming need CPU and network bandwidth?
We also need information about your mkv file, provide "ffmpeg -i" and MediaInfo result ? (see signature links)
SuperMiguel
Post Wed Nov 30, 2011 11:14 am
Illico wrote:Could you check videobitrate of your movie, must be <20-25Mbps?
This movie is Tron 3d, it last about 2 seconds before it stops, library auto refresh is enabled,
Videobitrate:
Mediainfo:
ffmpeg -i:
Miguels-iMac:MacOS Miguel$ ./ffmpeg -i ~/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv
ffmpeg version 0.8.git, Copyright (c) 2000-2011 the FFmpeg developers
  built on Aug 14 2011 22:07:26 with gcc 4.0.1 (Apple Inc. build 5493)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
/Users/Miguel/Volumes/Macintosh: No such file or directory
Post Wed Nov 30, 2011 1:17 pm
try to change h264 level from 5.1 to 4.1 using viewtopic.php?f=17&t=2118
Post Wed Nov 30, 2011 1:44 pm
Videobitrate:
- result is strange, Total time is 5s !!, this mkv file should be corrupted, do you try with VLC or MediaPlayer Classic on your MacOS ?
Mediainfo:
- Please provide in text output format
ffmpeg -i:
retry with " " around file path
Miguels-iMac:MacOS Miguel$ ./ffmpeg -i "~/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv"
In fact h264 Level 5.1 is not supported, must be less than 4.1.
Try with Zip link.
SuperMiguel
Post Wed Nov 30, 2011 1:58 pm
Illico wrote:Videobitrate:
Yup VLC plays it fine..
ffmpeg -i:
Miguels-iMac:MacOS Miguel$ ./ffmpeg -i "/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv"
[matroska,webm @ 0x116b000] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/Volumes/Macintosh HD 2/Movies Serviio/TRON_LEGACY_3D/TRON_LEGACY_3D.mkv':
    title           : TRON_LEGACY
  Duration: 02:05:08.31, start: 0.000000, bitrate: 1536 kb/s
    Chapter #0.0: start 0.000000, end 247.163000
      title           : (01)00:00:00:000
    Chapter #0.1: start 247.163000, end 884.133000
      title           : (02)00:04:07:163
    Chapter #0.2: start 884.133000, end 1395.602000
      title           : (03)00:14:44:133
    Chapter #0.3: start 1395.602000, end 1612.694000
      title           : (04)00:23:15:602
    Chapter #0.4: start 1612.694000, end 2172.211000
      title           : (05)00:26:52:694
    Chapter #0.5: start 2172.211000, end 2315.980000
      title           : (06)00:36:12:211
    Chapter #0.6: start 2315.980000, end 2812.726000
      title           : (07)00:38:35:980
    Chapter #0.7: start 2812.726000, end 3183.763000
      title           : (08)00:46:52:726
    Chapter #0.8: start 3183.763000, end 3894.181000
      title           : (09)00:53:03:763
    Chapter #0.9: start 3894.181000, end 4427.422000
      title           : (10)01:04:54:181
    Chapter #0.10: start 4427.422000, end 4740.944000
      title           : (11)01:13:47:422
    Chapter #0.11: start 4740.944000, end 4960.455000
      title           : (12)01:19:00:944
    Chapter #0.12: start 4960.455000, end 5150.895000
      title           : (13)01:22:40:455
    Chapter #0.13: start 5150.895000, end 5291.828000
      title           : (14)01:25:50:895
    Chapter #0.14: start 5291.828000, end 5502.413000
      title           : (15)01:28:11:828
    Chapter #0.15: start 5502.413000, end 6193.061000
      title           : (16)01:31:42:413
    Chapter #0.16: start 6193.061000, end 6498.033000
      title           : (17)01:43:13:061
    Chapter #0.17: start 6498.033000, end 6888.381000
      title           : (18)01:48:18:033
    Chapter #0.18: start 6888.381000, end 7083.659000
      title           : (19)01:54:48:381
    Chapter #0.19: start 7083.659000, end 7508.319999
      title           : (20)01:58:03:659
    Chapter #0.20: start 7508.417000, end 7508.319999
      title           : (21)02:05:08:417
    Stream #0.0: Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 48003.07 tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: dca (DTS-HD MA), 48000 Hz, 5.1, s16, 1536 kb/s (default)
SuperMiguel
Post Wed Nov 30, 2011 1:59 pm
Try with Zip link.
Did this and same result
Post Wed Nov 30, 2011 7:06 pm
Then your video really is 5.1 and will not play with Serviio until you reencode it to level 4.1
SuperMiguel
Post Wed Nov 30, 2011 8:02 pm
jhb50 wrote:Then your video really is 5.1 and will not play with Serviio until you reencode it to level 4.1
ummm
