Subtitles not working
Post Tue Feb 14, 2012 11:04 am
Re: Subtitles not working
dumen wrote:..What I did was, As per the link which was provided by Illico copy and paste the srt file to the window on the web page. And save the file as a new file with the same name as the movie file.
Cool.
Could you provide the two srt files, I will compare them, to understand ?
dumen
Post Thu Feb 16, 2012 11:16 am
Hi, Below is the two files. Due to some restriction the site wont me to upload the srt files. So i rename them to txt. The file with the QQQ is the original and other one is the created one.
One correction. There was a small issue with the corrected file after the timing 10:00:00. The correction software added some addtional "0" inbetween the Hour sequence "HH" so My TV stop playing the subtitles after the 10:00:00 but I sow that ant copied the entire subtitles after 10:00:00 from the original file to the created file. Then with no issues its continue to display the subs.
You can see it by your self by looking at " 3Idiots_Generated_By_DotSUB SRT.txt." file
Tag is 106
Cheers
(159.48 KiB) Downloaded 691 times
3Idiots.txt
(151.56 KiB) Downloaded 727 times
3IdiotsQQQ.txt
(302.29 KiB) Downloaded 717 times
Previous
Return to Panasonic
