Watch dvr-ms on Panasonic Viera TC-P50X3
RobJV
Post Wed Feb 22, 2012 11:38 pm
Not sure if I should have started a new thread but here goes:
Is there a way to watch the ms-dvr files over serviio to the viera TC-P50X3?
RobJV
Post Thu Feb 23, 2012 12:39 am
Re: Panasonic Viera TC-P50X3 Config Profile (AVI, FLV, WMV O
(Should have said "dvr-ms")
PMI
Post Thu Feb 23, 2012 1:29 am
RobJV wrote:Not sure if I should have started a new thread ...
Probably, ;)
RobJV wrote:Is there a way to watch the ms-dvr files over serviio to the viera TC-P50X3?
Yes, assuming you have selected a profile that has an entry for dvr-ms format (look for something like <Matches container="asf" /> in the profile you are using. If you are using any one of the Panasonic profiles posted here,
viewtopic.php?f=13&t=5119
it should be included.
Peter
Post Thu Feb 23, 2012 1:22 pm
RobJV wrote:Not sure if I should have started a new thread but here goes:
yep but will get this one split ths time. :)
As far as i know no not currently but a feature request could be added to request support ( zip will comment if they are supported and i just havent seen them )
Return to Panasonic
