Walkthrough instalation on Ubuntu 12.04 desktop [Solved]
vawaver
Post Sun Aug 05, 2012 7:16 pm
Hello there,
I would like to kindly ask somebody who has installed successfully Serviio 1.0 on Ubuntu 12.04 desktop 64 bit to write necessary steps to be done.
For the moment I have downloaded package for Linux from here http://www.serviio.org/download and I have tried to run it.
I found out a problem because content of mapped folder(/home/user/Videos/) is not showed as I wanted.
Please what to do and how? What should I check?
Thank you for a answer.
Post Sun Aug 05, 2012 7:59 pm
Re: Walkthrough instalation on Ubuntu 12.04 desktop
There is installation guide on the wiki. Getting started guide is on the website.
vawaver
Post Mon Aug 06, 2012 6:11 am
Thank you very much for your answer. Can you be more specific and tell me what particular wiki tutorials are necessary ?
I apologise, I am Linux beginner and I will be happy for your assistance.
Thank you for your reply.
Odoslané z GT-I9100 cez Tapatalk 2
Post Mon Aug 06, 2012 1:37 pm
vawaver
Post Wed Aug 08, 2012 9:49 am
Re: Walkthrough instalation on Ubuntu 12.04 desktop [Solved]
Thank you very much for information.
Serviio is just working fine
I had to install JAVA 1.7.0 - Tutorial here - http://www.devsniper.com/ubuntu-12-04-i ... n-jdk-6-7/
After that I have made every particular step from here - http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
Thank you.
Users browsing this forum: No registered users and 218 guests
