Problem with online content
lockone
Post Sat Aug 18, 2012 4:38 pm
I've read several threads but haven't seen anything about my problem.
I am playing a stream via Sopcast and have added it to my online sources in Serviio (127.0.0.1:8903) as video and live stream.
I have a Sharp LCD-TV (LC-60LE841S) and when I try to play my stream under VIDEO MODE > VIDEO > ONLINE it says the folder is empty. I've checked the stream URL in Serviio and it's fine.
What am I doing wrong?
Post Sun Aug 19, 2012 11:12 am
Re: Problem with online content
try
ffmpeg -i 127.0.0.1:8903
lockone
Post Sun Aug 19, 2012 2:19 pm
zip wrote:try
Thanks for your reply!
But where should I input this?
lockone
Post Sun Aug 19, 2012 3:30 pm
This is what I got:
g-config
127.0.0.1:8902: Protocol not found
Post Sun Aug 19, 2012 3:50 pm
use http://127.0.0.1:8903 and make sure sopcast is running first.
lockone
Post Sun Aug 19, 2012 3:56 pm
Ok, this time I get:
C:\Program Files\Serviio\lib>ffmpeg -i http://127.0.0.1:8902
g-config
[NULL @ 0003F340] non-existing PPS referenced
[h264 @ 0003F340] non-existing PPS 0 referenced
[h264 @ 0003F340] decode_slice_header error
[h264 @ 0003F340] no frame!
[h264 @ 0003F340] non-existing PPS referenced
[mpeg @ 0003BCE0] max_analyze_duration 5000000 reached at 5016000
[mpeg @ 0003BCE0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpeg, from 'http://127.0.0.1:8902':
Duration: N/A, start: 58885.922189, bitrate: 192 kb/s
Stream #0:0[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0:1[0x1e0]: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9]
, 32.37 fps, 25 tbr, 90k tbn, 50 tbc
Post Sun Aug 19, 2012 8:01 pm
it's weird, it looks like mpeg (ps) with h264, which is not a valid DLNA format, not is configured for transcoding anywhere. Any chance to stream in mpegts?
Post Mon Aug 20, 2012 1:30 am
I am having similar problems, as are a number of other threads.
This morning I set out to add SOPCAST to my HAHASPORTS groovy. Looks at the wiki and found I needed to start up SOPCAST with its link sop://broker.sopcast.com:3912/124646 and then add http://127.0.0.1:8902
to Serviio as a livestream.
In my case ffpmeg -i http://127.0.0.1:8902 gives me an mpegts stream
Input #0, mpegts, from 'http://127.0.0.1:8902':
  Duration: N/A, start: 36800.171189, bitrate: 96 kb/s
  Program 1
    Stream #0:0[0x56](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, mono,
s16, 96 kb/s
    Stream #0:1[0x57]: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001
B), yuv420p, 646x396 [SAR 128:117 DAR 20672:11583], 62 fps, 25 tbr, 90k tbn, 50
tbc
but when I add http://127.0.0.1:8902 to Serviio as a live stream and try to play it , the TV says file format not supported which usually means there is no input and mediaplayer just spins.
The log for the TV playback is
2012-08-19 23:57:26,366 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.22
2012-08-19 23:57:26,367 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.22, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 23:57:26,367 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 23:57:26,368 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 23:57:26,368 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 23:57:26,369 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000760001, format AVC_TS_MP_SD_AC3_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 23:57:26,369 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://127.0.0.1:8902
2012-08-19 23:57:26,369 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: AVC_TS_MP_SD_AC3_ISO
2012-08-19 23:57:26,369 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 23:57:26,369 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 20 Aug 2012 03:57:26 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-08-19 23:57:26,382 DEBUG [WebServer] Incoming connection from /192.168.1.22:35220
2012-08-19 23:57:26,382 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.22
2012-08-19 23:57:26,383 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000760001/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.1.10:8895]]
2012-08-19 23:57:26,383 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.22
2012-08-19 23:57:26,384 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.22, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 23:57:26,384 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 23:57:26,384 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 23:57:26,384 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 23:57:26,385 DEBUG [VideoDeliveryEngine] Delivering item '1000000000760001' for client 'IPAddress=/192.168.1.22, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 23:57:26,385 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902' using transcoding
2012-08-19 23:57:26,386 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-1000000000790001-7-ORIGINAL.stf', will stop the job
2012-08-19 23:57:26,386 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1000000000790001-7-ORIGINAL.stf'
2012-08-19 23:57:26,386 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-621,5,main]
2012-08-19 23:57:26,386 DEBUG [ProcessUtils] Killing the Windows process: 8112
2012-08-19 23:57:26,419 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-19 23:57:26,422 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.22, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 23:57:26,422 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://127.0.0.1:8902
2012-08-19 23:57:26,423 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i http://127.0.0.1:8902 -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 96k -ac 1 -map 0:1 -map 0:0 -sn -f mpegts pipe:
2012-08-19 23:57:26,559 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-19 23:57:26,559 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-19 23:57:26,561 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 22)
2012-08-19 23:57:26,561 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 43)
2012-08-19 23:57:26,566 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 50)
2012-08-19 23:57:26,574 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 23:57:26,574 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 77)
2012-08-19 23:57:26,575 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 78)
2012-08-19 23:57:26,575 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 79)
2012-08-19 23:57:27,046 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.10:63995
2012-08-19 23:57:27,046 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-19 23:57:27,950 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-08-19 23:57:27,950 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-08-19 23:57:41,022 DEBUG [NonClosingPipedInputStream] Closing piped input stream and closing related feeder process
2012-08-19 23:57:41,672 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net4 (Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC) and address 192.168.1.10, timeout = 0
2012-08-19 23:57:41,673 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65
2012-08-19 23:57:43,473 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:55
2012-08-19 23:57:49,573 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-19 23:57:49,573 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-19 23:57:49,574 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-19 23:57:52,926 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2012-08-19 23:57:52,926 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: AVC_TS_MP_SD_AC3_ISO
2012-08-19 23:57:52,926 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 23:57:52,926 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 23:57:52,927 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 20 Aug 2012 03:57:52 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=18000000;]]
2012-08-19 23:57:57,657 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:8dee68fe-0370-3fc8-a5f5-ae4a1fb10a65 from address /192.168.1.22:1025
2012-08-19 23:57:57,657 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.22
2012-08-19 23:57:57,658 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.22:1025
2012-08-19 23:57:57,715 DEBUG [WebServer] Incoming connection from /192.168.1.22:37543
2012-08-19 23:57:57,715 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.22
2012-08-19 23:57:57,716 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000760001/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-08-19 23:57:57,716 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.22
2012-08-19 23:57:57,717 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.22, Profile=Samsung TV / player (C/D/E-series)'
2012-08-19 23:57:57,717 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 23:57:57,717 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 23:57:57,717 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 23:57:57,718 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000760001, format AVC_TS_MP_SD_AC3_ISO and profile Samsung TV / player (C/D/E-series)
2012-08-19 23:57:57,718 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://127.0.0.1:8902
2012-08-19 23:57:57,719 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: AVC_TS_MP_SD_AC3_ISO
2012-08-19 23:57:57,719 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-08-19 23:57:57,719 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 20 Aug 2012 03:57:57 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
The log for mediaplayer shows an ffmpeg error. But why does it send the file back when there is no file to send?
2012-08-19 20:49:02,517 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-08-19 20:49:02,517 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 20:49:02,517 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 20:49:02,517 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 20:49:02,517 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 20:49:02,518 DEBUG [VideoDeliveryEngine] Delivering item '1000000000760001' for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 20:49:02,518 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902' using transcoding
2012-08-19 20:49:02,519 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 20:49:02,519 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://127.0.0.1:8902
2012-08-19 20:49:02,520 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://127.0.0.1:8902 -y -copyts -c:v flv -sameq -vf scale=708:396,setsar=1 -r 24000/1001 -g 15 -c:a libmp3lame -b:a 96k -ar 44100 -ac 1 -map 0:1 -map 0:0 -sn -f flv pipe:
2012-08-19 20:49:02,860 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2012-08-19 20:49:02,860 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-08-19 20:49:24,389 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.10:57538
2012-08-19 20:49:24,390 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.10
2012-08-19 20:49:24,391 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.10:57538
2012-08-19 20:49:29,020 DEBUG [StreamBasedTranscodingDeliveryStrategy] Transcoded stream is empty, connection may have been lost
2012-08-19 20:49:29,020 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: FLV
2012-08-19 20:49:29,021 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: FLV
2012-08-19 20:49:29,021 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 20:49:29,021 DEBUG [ResourceDeliveryProcessor] Sending file back
In a separate test the log shows it plays
2012-08-19 22:16:06,384 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-08-19 22:16:06,384 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:06,384 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 22:16:06,385 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 22:16:06,385 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 22:16:06,385 DEBUG [VideoDeliveryEngine] Delivering item '1000000000760001' for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:06,386 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902' using transcoding
2012-08-19 22:16:06,386 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:06,387 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://127.0.0.1:8902
2012-08-19 22:16:06,388 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i http://127.0.0.1:8902 -y -copyts -c:v flv -sameq -vf scale=708:396,setsar=1 -r 24000/1001 -g 15 -c:a libmp3lame -b:a 96k -ar 44100 -ac 1 -map 0:1 -map 0:0 -sn -f flv pipe:
2012-08-19 22:16:07,390 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: FLV
2012-08-19 22:16:07,392 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 22:16:07,392 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 22:16:07,484 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-08-19 22:16:07,485 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:07,485 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 22:16:07,485 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 22:16:07,485 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 22:16:07,486 DEBUG [VideoDeliveryEngine] Delivering item '1000000000760001' for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:07,486 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902' using transcoding
2012-08-19 22:16:07,487 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:07,487 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: FLV
2012-08-19 22:16:07,487 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 22:16:07,487 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-19 22:16:07,684 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-08-19 22:16:07,685 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:07,685 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000760001 and type 'MEDIA_ITEM' received
2012-08-19 22:16:07,685 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000760001 (online)
2012-08-19 22:16:07,685 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 76)
2012-08-19 22:16:07,686 DEBUG [VideoDeliveryEngine] Delivering item '1000000000760001' for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:07,686 DEBUG [VideoDeliveryEngine] Delivering file 'http://127.0.0.1:8902' using transcoding
2012-08-19 22:16:07,686 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/127.0.0.1, Profile=Flash player'
2012-08-19 22:16:08,738 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://127.0.0.1:8902: FLV
2012-08-19 22:16:08,738 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-19 22:16:08,738 DEBUG [ResourceDeliveryProcessor] Sending file back
but Mediaplayer spins and says:
Error: 200, Stream not found, NetStream.Play.StreamNotFound, clip: '[Clip] 'http://localhost:23424/cds/resource/1000000000760001/MEDIA_ITEM/FLV-0/ORIGINAL,flv_player?authToken=322c43a3ec5046e7af5e5355832250a6''
   at org.flowplayer.view::Launcher/doHandleError()
   at org.flowplayer.view::Launcher/onClipError()
   at EventListener/notify()
   at org.flowplayer.model::EventDispatcher/_dispatchEvent()
   at org.flowplayer.model::EventDispatcher/http://flowplayer.org/core/internal::doDispatchErrorEvent()
   at org.flowplayer.model::EventDispatcher/http://flowplayer.org/core/internal::doDispatchEvent()
   at org.flowplayer.model::Clip/onClipEvent()
   at org.flowplayer.model::ClipEventDispatcher/dispatchError()
   at org.flowplayer.controller::NetStreamControllingStreamProvider/_onNetStatus()
And I get the same when I try to play it again. Seems it cannot find the previous transcoded file.
While all this is going on i can play the stream natively with ffplay or as a native stream with Serviigo, so the problem is in the Serviio transcoding. Seems it fails in transcoding but then continues to try and send the empty file to the client which then cannot find it.
If I run the transcoding command for mediaplayer by itself and create an output flv file it plays on my pc as a valid file.
Complete name                    : D:\test.flv
Format                           : Flash Video
File size                        : 85.8 MiB
Duration                         : 4mn 8s
Overall bit rate                 : 2 895 Kbps
Writing application              : Lavf54.11.100
Format                           : Sorenson Spark
Codec ID                         : 2
Duration                         : 4mn 8s
Bit rate                         : 195 Kbps
Width                            : 708 pixels
Height                           : 396 pixels
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.029
Stream size                      : 5.79 MiB (7%)
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Codec ID                         : 2
Codec ID/Hint                    : MP3
Duration                         : 4mn 8s
Bit rate mode                    : Variable
Bit rate                         : 93.8 Kbps
Channel(s)                       : 1 channel
Sampling rate                    : 44.1 KHz
Delay relative to video          : -108ms
Stream size                      : 2.78 MiB (3%)
lockone
Post Mon Aug 20, 2012 8:53 am
zip wrote:it's weird, it looks like mpeg (ps) with h264, which is not a valid DLNA format, not is configured for transcoding anywhere. Any chance to stream in mpegts?
Does that mean I have to re-stream via VLC and choose a different format?
lockone
Post Mon Aug 20, 2012 11:29 am
On the other hand, I also added a few of the RSS from the video streams part of the forum.
None of them show up on my TV either.
Post Mon Aug 20, 2012 12:34 pm
You need to post more info.. What Sopcast stream gave you the PS stream. What RSS's don't work. What does the debug log show. What profile are you using. Have you ever streamed anything successfully?
Post Mon Aug 20, 2012 2:18 pm
I have opened a new thread subsequent to my problem posted above which addresses the failure of http stream playbacks in media browser. It does not however address the ffmpeg failures noted above.
viewtopic.php?f=5&t=7138
lockone
Post Mon Aug 20, 2012 3:45 pm
jhb50 wrote:You need to post more info.. What Sopcast stream gave you the PS stream. What RSS's don't work. What does the debug log show. What profile are you using. Have you ever streamed anything successfully?
Ok, now I managed to get a Sopcast stream to work - so I won't fiddle any more with what. :)
But the RSS is still bugging me, I've added these three:
https://sites.google.com/site/serviiors ... Sports.rss
https://sites.google.com/site/serviiors ... Movies.rss
Isn't it as simple as just adding them in Serviio under online sources and online rss/atom feed? It shows up on my tv, but the folders are empty.
EDIT: The last RSS, LiveFeeds_TV_Sports.rss, gave three streams when clicking the folder. None of them worked though.
DeanosBeano
Post Sun Sep 23, 2012 1:55 pm
I am also having the same issue streaming sopcast with certain channels namely Bloodzeed. I have had other streams through Sopcast working so I know my setup is sound albeit get the same problem occasionally where my Panasonic ST50 simply says cannot read file. This is after many force refreshes. I have sopcast setup in two ways, one setup as a live stream with URL http://localhost:8902
and secondly as a webresource using URL http://www.sopcast.com?port=8902&items=1 with a sopcast.grovy plugin provided on this site to auto refresh stream channels.
Sadly neither seem to work with bloodzeed channel with the cannot read file error although the channel does obviously appear in my online folder on the tv, the output from command line using ffmpeg -i http://localhost:8902 is this:
C:\Program Files\Serviio\lib>ffmpeg -i http://localhost:8902
configuration: --enable-static --disable-shared --disable-ffplay --disable-ff
erver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs=
-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --ena
le-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=p
g-config
[NULL @ 01A8E740] non-existing PPS referenced
[h264 @ 01A8E740] non-existing PPS 0 referenced
[h264 @ 01A8E740] decode_slice_header error
[h264 @ 01A8E740] no frame!
[h264 @ 01A8E740] non-existing PPS referenced
[mpeg @ 01A8C3E0] max_analyze_duration 5000000 reached at 5015467
[mpeg @ 01A8C3E0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpeg, from 'http://localhost:8902':
Duration: N/A, start: 34121.988833, bitrate: 80 kb/s
Stream #0:0[0x1e0]: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9
, 29.52 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x1c0]: Audio: mp3, 44100 Hz, stereo, s16, 80 kb/s
Not seeing anything in the serviio log although I i think i need to change the logging level to DEBUG in the config to get anything there?
Any ideas?
Post Sun Sep 23, 2012 5:28 pm
Only that there seems to be a lot of problems with this stream. Currently SOPCAST starts to buffer it and then it hangs up SOPCAST with a (not responding). I do not have similar problems with any other SOPCAST channel.
Users browsing this forum: Google [Bot] and 12 guests
