implementing swf verification
ttguy
Post Thu Aug 30, 2012 1:40 pm
So the Wiki on Servio Plugins says "Some rtmp streams require swf verification (not implementing that usually means the stream is cut after a period of time, like 1 minute)"
And that is the stage I am at with my plugin development. I have my feeds all stopping after 2 mins or so.
Now with rtmpdump I can download the whole video
rtmpdump --rtmp rtmp://cp53909.edgefcs.net:1935 --app 'ondemand?auth=daEdSaLdkajbJavaLdodNbZcPaAaebPdabB-bqp17M-8-nks_rEAoK&aifp=v001' --playpath mp4:flash/playback/_definst_/catalyst_13_15.mp4 --swfUrl http://www.abc.net.au/iview/images/iview.jpg --swfVfy 1 --swfsize 2122 --swfhash 96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37 -o /home/god/Videos/catalyst2.mp4
Even though rtmpdump reports "ERROR: RTMP_HashSWF: couldn't contact swfurl 1 (HTTP error -1)" it downloads the whole video.
The URL my plugin constructs is of the form shown below
 rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdWbvbNc0a_dJcKdvbXccdYaebkbRaUai-bqp1Zr-8-rlm_AGtnI&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4
That form of the URL works with ffmpeg -i to get the metadata. But if I use it to try and download the video as shown below it works for a bit and stops - just like the stream does on my console with my plugin.
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdWbvbNc0a_dJcKdvbXccdYaebkbRaUai-bqp1Zr-8-rlm_AGtnI&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4"  ~/catalist2.mp4
So I figure I need to add some of the other parameters that my RTMP dump command uses.
If I try the swfhash option ffmpeg reports "Unknown option swfhash"
If I try the swfVfy=1 option ffmpeg reports "HandleCtrl: Ignoring SWFVerification request, use --swfVfy!"
If I try --swfVfy it also reports "HandleCtrl: Ignoring SWFVerification request, use --swfVfy!"
if I try swfVfy=true it also reports "HandleCtrl: Ignoring SWFVerification request, use --swfVfy!"
So how does one go about implementing this swf verification?
My feed items do require an auth string which you need to get each time. It gets supplied as the ?auth=<authstring> part of the URL. But my plug in does this. Is this what is meant by swf verification?
Help - I am so close to a working plugin I can smell it :x
linux/Humax HDR-3000T
Post Thu Aug 30, 2012 4:22 pm
Re: implementing swf verification
for swf add swfVfy=0 or swfUrl=http://www.abc.net.au/iview/images/iview.jpg to your plugin url
ttguy
Post Thu Aug 30, 2012 9:58 pm
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEckb4dXcZcMaFaJcFa5d4bRaWcgcZdFcs-bqp92D-8-jlr_AGspN&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=http://www.abc.net.au/iview/images/iview.jpg"
 libavutil      51. 70.100 / 51. 70.100
  libavcodec     54. 54.100 / 54. 54.100
  libavformat    54. 25.104 / 54. 25.104
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3. 11.101 /  3. 11.101
  libswscale      2.  1.101 /  2.  1.101
[image2 @ 0xaa74510] Could not find codec parameters for stream 0 (Video: mjpeg): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEckb4dXcZcMaFaJcFa5d4bRaWcgcZdFcs-bqp92D-8-jlr_AGspN&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=http://www.abc.net.au/iview/images/iview.jpg: could not find codec parameters
or
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdjdIdpbaaIcBdVbnapaTdDcDdad7dMcg-bqp94T-8-snp_wFrnJ&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=0"
  duration              1624.33
  moovPosition          36.00
  width                 640.00
  height                360.00
  videocodecid          avc1
  audiocodecid          mp4a
  avcprofile            77.00
  avclevel              31.00
  aacaot                2.00
  videoframerate        25.00
  audiosamplerate       44100.00
  audiochannels         2.00
trackinfo:
  length                974616.00
  timescale             600.00
sampledescription:
  sampletype            avc1
  length                71632858.00
  timescale             44100.00
sampledescription:
  sampletype            mp4a
  length                600.00
  timescale             600.00
sampledescription:
  length                600.00
  timescale             600.00
sampledescription:
Input #0, flv, from 'rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdjdIdpbaaIcBdVbnapaTdDcDdad7dMcg-bqp94T-8-snp_wFrnJ&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=0':
    moovPosition    : 36
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    videoframerate  : 25
    audiochannels   : 2
  Duration: 00:27:04.32, start: 0.000000, bitrate: N/A
    Stream #0:0: Video: h264 (Main), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 44100 Hz, stereo, s16
or if I try and save the stream with swfVfy=0 option I get "HandleCtrl: Ignoring SWFVerification request, use --swfVfy!"
and it saves for a while and then
"RTMP_ReadPacket, failed to read RTMP packet header:01:01.99"
god@DESKTOP-TOYROOM:/usr/bin/serviio-0.6.2$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEbXd8cZd5cxd6c3bwaVa8bybQbAddazcz-bqp.cS-8-snl_sHypI&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=0" ~/catalist4.mp4
  duration              1624.33
  moovPosition          36.00
  width                 640.00
  height                360.00
  videocodecid          avc1
  audiocodecid          mp4a
  avcprofile            77.00
  avclevel              31.00
  aacaot                2.00
  audiochannels         2.00
trackinfo:
  length                974616.00
  timescale             600.00
sampledescription:
  sampletype            avc1
  length                71632858.00
  timescale             44100.00
sampledescription:
  sampletype            mp4a
  length                600.00
  timescale             600.00
sampledescription:
  length                600.00
  timescale             600.00
sampledescription:
Input #0, flv, from 'rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEbXd8cZd5cxd6c3bwaVa8bybQbAddazcz-bqp.cS-8-snl_sHypI&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=0':
    moovPosition    : 36
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    videoframerate  : 25
    audiochannels   : 2
[libx264 @ 0x8f1bee0] using SAR=1/1
[libx264 @ 0x8f1bee0] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle Cache64
[libx264 @ 0x8f1bee0] profile High, level 3.0
[libx264 @ 0x8f1bee0] 264 - core 120 r2151 a3f4407 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to '/home/god/catalist4.mp4':
    moovPosition    : 36
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    videoframerate  : 25
    audiochannels   : 2
    encoder         : Lavf54.25.104
    Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=-1--1, 25 tbn, 25 tbc
    Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 44100 Hz, stereo, s16, 128 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (h264 -> libx264)
  Stream #0:1 -> #0:1 (aac -> libfaac)
RTMP_ReadPacket, failed to read RTMP packet header:01:01.99 bitrate= 601.8kbits/s dup=1 drop=0
frame= 1614 fps= 26 q=-1.0 Lsize=    4741kB time=00:01:04.48 bitrate= 602.3kbits/s dup=1 drop=0
video:3899kB audio:773kB subtitle:0 global headers:0kB muxing overhead 1.479152%
[libx264 @ 0x8f1bee0] frame I:34    Avg QP:17.46  size:  9237
[libx264 @ 0x8f1bee0] frame P:692   Avg QP:22.65  size:  4052
[libx264 @ 0x8f1bee0] frame B:888   Avg QP:26.27  size:   984
[libx264 @ 0x8f1bee0] consecutive B-frames: 18.3% 17.6% 22.5% 41.6%
[libx264 @ 0x8f1bee0] mb I  I16..4: 41.8% 37.4% 20.9%
[libx264 @ 0x8f1bee0] mb P  I16..4: 11.0% 13.1%  2.3%  P16..4: 36.9% 10.5%  4.0%  0.0%  0.0%    skip:22.1%
[libx264 @ 0x8f1bee0] mb B  I16..4:  0.7%  0.5%  0.1%  B16..8: 38.2%  3.3%  0.5%  direct: 1.3%  skip:55.3%  L0:38.9% L1:55.3% BI: 5.8%
[libx264 @ 0x8f1bee0] 8x8 transform intra:47.4% inter:72.7%
[libx264 @ 0x8f1bee0] coded y,uvDC,uvAC intra: 34.2% 60.4% 18.5% inter: 9.2% 16.1% 0.9%
[libx264 @ 0x8f1bee0] i16 v,h,dc,p: 46% 21% 13% 20%
[libx264 @ 0x8f1bee0] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 19% 30%  4%  4%  4%  4%  4%  5%
[libx264 @ 0x8f1bee0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 18% 16%  5%  7%  6%  6%  5%  4%
[libx264 @ 0x8f1bee0] i8c dc,h,v,p: 46% 21% 23% 10%
[libx264 @ 0x8f1bee0] Weighted P-Frames: Y:9.4% UV:9.2%
[libx264 @ 0x8f1bee0] ref P L0: 68.0% 11.0% 15.7%  5.2%  0.2%
[libx264 @ 0x8f1bee0] ref B L0: 87.5% 10.9%  1.6%
[libx264 @ 0x8f1bee0] ref B L1: 96.0%  4.0%
[libx264 @ 0x8f1bee0] kb/s:494.60
But I am wondering about the http://www.abc.net.au/iview/images/iview.jpg
When I use that as a --swfUrl parameter to rtmpdump rtmpdump reports "ERROR: RTMP_HashSWF: couldn't contact swfurl 1 (HTTP error -1)"
Which seems bad. But RTMPDUMP still manages to download the video.
If I browse to http://www.abc.net.au/iview/images/iview.jpg my browser reports "the image at http://www.abc.net.au/iview/images/iview.jpg cannot be displayed because it contains errors"
My guess is that they put data that is not a .jpg into a .jpg file as some sort of obsufaction technique.
I pulled the http://www.abc.net.au/iview/images/iview.jpg URL from an ABC TV downloader so I don't know if it is correct or not. The ABC TV downloader passes this URL to rtmpdump as the --swfUrl parameter.
So I am still at a loss here. rtmpdump can do the job but ffmpeg can not at this stage.
Post Thu Aug 30, 2012 11:42 pm
You need a url ending in .swf Use URL sniffer to see what the downloader uses.
ttguy
Post Fri Aug 31, 2012 7:46 am
I have run my rtmpdump in verbose mode to see what it is doing. I can run it without passing --swfsize and --swfhash parameters and under this it fails to complete the download. With --swfsize and --swfhash parameters the dowload completes.
When you look at the handshaking output from the -verbose mode you see a big difference between them
hand shaking WITHOUT the --swfsize --swfhash
DEBUG: timeout  : 30 sec
DEBUG: Setting buffer time to: 36000000ms
Connecting ...
DEBUG: RTMP_Connect1, ... connected, handshaking
DEBUG: HandShake: Type Answer   : 03
DEBUG: HandShake: Server Uptime : 912190918
DEBUG: HandShake: FMS Version   : 3.5.7.1
DEBUG: HandShake: Handshaking finished....
DEBUG: RTMP_Connect1, handshaked
DEBUG: Invoking connect
INFO: Connected...
DEBUG: HandleServerBW: server BW = 1250000
DEBUG: HandleClientBW: client BW = 1250000 2
DEBUG: HandleCtrl, received ctrl. type: 26, len: 3
DEBUG: HandleCtrl, SWFVerification ping received:
ERROR: HandleCtrl: Ignoring SWFVerification request, use --swfVfy!
DEBUG: RTMP_ClientPacket, received: invoke 242 bytes
Handshaking WITH the --swfsize --swfhash in play
DEBUG: SWFSHA256:
DEBUG: 96 cc 76 f1 d5 38 5f b5 cd a6 e2 ce 5c 73 32 3a
DEBUG: 39 90 43 d0 bb 6c 68 7e dd 80 7e 5c 73 c4 2b 37
DEBUG: SWFSize  : 2122
Connecting ...
DEBUG: HandShake: Client type: 03
DEBUG: HandShake: Client digest offset: 430
DEBUG: HandShake: Initial client digest:
DEBUG: 79 65 42 b7 2d 62 8b 79 1e 12 be b7 c6 0d fb a7
DEBUG: 9b df bc 33 1e ba 65 35 75 42 15 39 c2 16 6b b7
DEBUG: HandShake: Server Uptime : 912375646
DEBUG: HandShake: Calculated digest key from secure key and server digest:
DEBUG: b1 c5 99 13 c4 3d 67 1b a4 ae b3 ec 9a c9 e4 63
DEBUG: 79 cb 4e 5c 04 4c e0 90 c2 3e 97 f8 76 c4 c4 64
DEBUG: HandShake: Client signature calculated:
DEBUG: d0 db 32 1f 86 e2 45 28 79 2f ac c6 cf 5e 85 59
DEBUG: 09 68 66 89 38 f2 2f 6c ff 19 e0 98 c7 0d ca 62
DEBUG: HandShake: Server sent signature:
DEBUG: 9c 1a 62 9c 6f eb 1e 8a 5e 85 25 db 7f cd 48 f1
DEBUG: 4e 42 59 3b 35 6a 7a ad 2b 4d ea 4b 73 51 e1 11
DEBUG: HandShake: Digest key:
DEBUG: bb de 65 ca ae 8f 30 31 da 5f 43 5b fe 6e fa 62
DEBUG: 80 c9 f4 5a d2 75 c4 57 57 f0 40 e7 09 5a 75 54
DEBUG: HandShake: Signature calculated:
DEBUG: HandShake: Genuine Adobe Flash Media Server
INFO: Connected...
DEBUG: sending ctrl. type: 0x001b
DEBUG: Sending SWFVerification response:
DEBUG: 00 1b 01 01 00 00 08 4a 00 00 08 4a bb bc 4b df
DEBUG: 73 6c 82 95 7a 31 af cd 61 ce da 06 3d ed 0e 08
DEBUG: bb 14 93 2b 07 53 89 d3 cd 5a 1b ac
So I think that I have to somehow get the info from --swfsize and --swfhash switches into the ffmpeg command
but swfhash is not a switch in ffmpeg
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEaHb8cfc8c6aFaIdXcybgc2cvavcSaDc4-bqp2b9-8-mll_wGrpN&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfhash=96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37"
ffmpeg does not seem to have teh same SWFverification facilities that RTMPDump has. Or I just don't know how to envoke them.
Post Fri Aug 31, 2012 8:46 am
Do you try with :
swfUrl=http://www.abc.net.au/iview/iview_383.swf
ttguy
Post Fri Aug 31, 2012 11:53 am
Illico wrote:Do you try with :
I have now. [I use it as swfVfy not swfUrl. With it as swfUrl it generates ERROR: RTMP_HashSWF: couldn't contact swfurl 1 (HTTP error -1) and the file stops download after 1 min ]
It has progressed things but not got me to the solution.
When I use this as swfVfy I get handshaking and no complaining about the URL but the file does not download at all.
I am slowly coming to understand what is going on here.
When I run the rtmpdump command that has the --swfsize and --swfhash parameters filled in I am overiding the need to supply the URL to the players .swf file. rtmpdump needs the URL to the players .swf file in order to calculate a swfhash and swfsize in order to perform some sort of verification hand shake with the server. But you can overide this need - if you have calcluated the swfhash and swfsize before hand and pass the values as parameters. I pulled the swfhash and swfsize parameters that work for me from python ABC iView downloader. The author of that app must have found the correct .swf .
Now when I run rtmpdump with the --swfVfy http://www.abc.net.au/iview/iview_383.swf instead of the swfhash and swfsize I see that it performs handshaking like it does when I do use the swfhash and swfsize parameter. However, I note that the SWFSize reported back from swfVfy http://www.abc.net.au/iview/iview_383.swf is 340960. And this is different to the 2122 size that I know works.
So perhaps http://www.abc.net.au/iview/iview_383.swf is not the real .swf file in use. Maybe I need to figure out what the real one is.
$ rtmpdump -V --rtmp rtmp://cp53909.edgefcs.net:1935 --app 'ondemand?auth=daEaBcMaVdidMdQcYckcfcIa1bFdEcFb3aG-bqqkbJ-8-qmt_yHzqN&aifp=v001' --playpath mp4:flash/playback/_definst_/catalyst_13_15.mp4 --swfVfy http://www.abc.net.au/iview/iview_383.swf  -o /home/god/Videos/catalyst3.mp4
RTMPDump v2.4
(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
DEBUG: Parsing...
DEBUG: Parsed protocol: 0
DEBUG: Parsed host    : cp53909.edgefcs.net
WARNING: No application or playpath in URL!
DEBUG: Protocol : RTMP
DEBUG: Hostname : cp53909.edgefcs.net
DEBUG: Port     : 1935
DEBUG: Playpath : mp4:flash/playback/_definst_/catalyst_13_15.mp4
DEBUG: tcUrl    : rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEaBcMaVdidMdQcYckcfcIa1bFdEcFb3aG-bqqkbJ-8-qmt_yHzqN&aifp=v001
DEBUG: swfUrl   : http://www.abc.net.au/iview/iview_383.swf
DEBUG: app      : ondemand?auth=daEaBcMaVdidMdQcYckcfcIa1bFdEcFb3aG-bqqkbJ-8-qmt_yHzqN&aifp=v001
DEBUG: live     : no
DEBUG: SWFSHA256:
DEBUG: 98 70 a8 0f 1c 38 df 14 e5 9f a1 fa 08 8b 39 55
DEBUG: 6c dd 26 38 a7 fc f4 a4 66 28 ce 8d d2 a5 a3 38
DEBUG: SWFSize  : 340960
Connecting ...
DEBUG: 2f 52 d5 4c 6d 5d f9 1b e6 99 5b 81 86 ea e3 5f
DEBUG: ef 46 d7 09 18 80 d3 31 fc 43 07 46 4a c1 0a f9
DEBUG: HandShake: Server Uptime : 926994537
DEBUG: 2d 34 26 7e 4a 8c 5b 59 be 5c 50 ae 8f 80 fb a9
DEBUG: f8 2f 46 11 50 fa 7a 3a 80 8c df 30 b3 a8 7e c0
DEBUG: ef d5 d2 9d 24 c0 2b 6e c3 9c 5b e8 1b 51 5a 46
DEBUG: 7b 1b e4 b1 f9 8b c5 1b 05 3e 18 da c0 8e 44 fb
DEBUG: 67 2c 40 a1 31 3d eb 57 57 06 08 9b 72 3f 40 1e
DEBUG: c7 39 d6 37 a4 e7 fc 83 31 83 36 03 1c e0 5f a7
DEBUG: 5a da 0f fe a4 63 34 c6 4e 79 8d 60 b8 33 5b 69
DEBUG: 88 e7 72 e6 f3 67 a0 da 1f 63 a2 37 e9 f1 d2 e4
INFO: Connected...
DEBUG: 00 1b 01 01 00 05 33 e0 00 05 33 e0 6a b9 1a 4b
DEBUG: 54 79 75 bb ee b9 c8 c8 e7 46 86 a4 e9 ef 20 f7
DEBUG: e2 e1 13 a8 f3 d1 75 59 79 d1 47 4d
DEBUG: (object begin)
DEBUG: Property: <Name:             fmsVer, STRING:   FMS/3,5,7,7024>
DEBUG: Property: <Name:       capabilities, NUMBER:   127.00>
DEBUG: Property: <Name:               mode, NUMBER:   1.00>
DEBUG: (object end)
DEBUG: Property: <Name:              level, STRING:   status>
DEBUG: Property: <Name:               code, STRING:   NetConnection.Connect.Success>
DEBUG: Property: <Name:        description, STRING:   Connection succeeded.>
DEBUG: Property: <Name:     objectEncoding, NUMBER:   0.00>
DEBUG: Property: <Name:               data, OBJECT>
DEBUG: Property: <Name:            version, STRING:   3,5,7,7024>
DEBUG: (object end)
DEBUG: (object end)
DEBUG: (object end)
DEBUG: HandleInvoke, server invoking <_result>
DEBUG: HandleInvoke, received result for method call <connect>
DEBUG: sending ctrl. type: 0x0003
DEBUG: Invoking createStream
DEBUG: RTMP_ClientPacket, received: invoke 21 bytes
DEBUG: Property: NULL
DEBUG: (object end)
DEBUG: HandleInvoke, server invoking <onBWDone>
DEBUG: Invoking _checkbw
DEBUG: RTMPSockBuf_Fill, recv returned -1. GetSockError(): 104 (Connection reset by peer)
ERROR: RTMP_ReadPacket, failed to read RTMP packet header
DEBUG: Closing connection.
ttguy
Post Fri Aug 31, 2012 12:18 pm
So I went back to my old URL of http://www.abc.net.au/iview/images/iview.jpg - which is not really a jpeg.
But this time I used it as swfVfy (as suggested previously - but last time I only tried it with ffmpeg and it did not work).
But this time I used it with rtmpdump and with out the --swfsize --swfhash values. And this does download the complete file. And rtmpdump reports a SWFSize of 2122 - the same value I was passing in before. So it seems to me that this iview.jpg is really the file to verify on for the iView application.
rtmpdump -V --rtmp rtmp://cp53909.edgefcs.net:1935 --app 'ondemand?auth=daEcFbsaNajcBbxc3c0d3dmczbRaNaucaa5-bqqkDZ-8-klt_AEApM&aifp=v001' --playpath mp4:flash/playback/_definst_/catalyst_13_15.mp4 --swfVfy http://www.abc.net.au/iview/images/iview.jpg  -o /home/god/Videos/catalyst3.mp4
DEBUG: SWFSHA256:
Connecting ...
DEBUG: 66 62 f8 ea cc 1a cf 9d 03 ee 56 de 9b 20 3d b6
DEBUG: 5a 52 36 6b cd 59 cd 92 b2 f8 55 96 55 f9 9f fb
DEBUG: HandShake: Server Uptime : 928811811
DEBUG: 24 7e d6 9f 9d 54 11 20 7e c9 12 fb be 19 8e 06
DEBUG: 41 17 c0 46 72 39 86 df 3c bb de 34 1a 7e a3 85
DEBUG: 81 8f 68 94 1b 98 b7 44 a5 13 19 9f 13 6b 33 a5
DEBUG: 57 0d cd 9e 67 ee 27 a7 ab d3 af 3f c5 6c 27 7a
DEBUG: 12 b3 90 5b 57 ff 6b 3f 7e a7 28 f4 65 c2 8f af
DEBUG: a9 5e 88 cd 81 3d aa 95 3d 91 bc 18 8d 4f ed 24
DEBUG: 12 e8 35 37 bf db 21 92 e6 54 dd 7f f6 83 19 57
DEBUG: 34 f4 80 31 d1 6f e3 ce 0b f5 ac 9c 8d 94 0b 25
INFO: Connected...
DEBUG: 00 1b 01 01 00 00 08 4a 00 00 08 4a 2d 55 ec 2b
DEBUG: cf c3 11 0d a7 69 49 17 11 ec 30 72 c8 bf 9e c2
DEBUG: a5 83 7f c5 d8 10 63 74 a3 a0 cf 81
So armed with this I look again at ffmpeg and sending it swfVfy=http://www.abc.net.au/iview/images/iview.jpg
And here is the result
$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdNc.cyagbNcRa8cZcubYa4cUaLdmcnd7-bqqkIQ-8-smn_vExoO&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=http://www.abc.net.au/iview/images/iview.jpg" ~/catalyst5.mp4
ffmpeg version 0.11.1.git Copyright (c) 2000-2012 the FFmpeg developers
  built on Aug 22 2012 00:01:08 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
  configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-pthreads --disable-mmx --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-version3 --enable-librtmp --pkg-config=pkg-config
[image2 @ 0x9c15510] Could not find codec parameters for stream 0 (Video: mjpeg): unspecified size
rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdNc.cyagbNcRa8cZcubYa4cUaLdmcnd7-bqqkIQ-8-smn_vExoO&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=http://www.abc.net.au/iview/images/iview.jpg: could not find codec parameters
It seems to me that it not able to handle the non .swf file as the swfVfy file. It looks like it is trying to dow some decoding of it maybe.
So am I screwed - save for recoding ffmpeg ?
Post Fri Aug 31, 2012 1:36 pm
swfVfy is boolean..a switch.. equal to 0 or 1 or true or false. swfUrl is the parameter for the .swf url. And as I said above You need a url ending in .swf so use URL sniffer to see what the downloader uses.
ttguy
Post Fri Aug 31, 2012 2:38 pm
jhb50 wrote:swfVfy is boolean..a switch.. equal to 0 or 1 or true or false. swfUrl is the parameter for the .swf url. And as I said above You need a url ending in .swf so use URL sniffer to see what the downloader uses.
Well from the rtmpdump -h
--swfVfy|-W url URL to player swf file, compute hash/size automatically
--swfUrl|-s url URL to player swf file
But you see that if I use swfVfy as a URL in rtmpdump and I point it to the http://www.abc.net.au/iview/images/iview.jpg it all works.
And I know what the downloader uses - it envokes rtmpdump with these options.
--swfhash 96cc76f1d5385fb5cda6e2ce5c73323a399043d0bb6c687edd807e5c73c42b37 --swfsize 2122 --swfUrl http://www.abc.net.au/iview/images/iview.jpg
So it does not use swfVfy to compute hash/size automatically. It supplies them.
But from some help returned from a failed ffmpeg run:
swfVfy boolean Perform SWF Verification
Interesting (and anoying) how swfVfy means two different things to rtmpdump and ffmpeg.
I reckon I need to pass swfhash and swfsize to ffmpeg. The man page at http://ffmpeg.org/ffmpeg.html#rtmp says " the following parameters can be set via command line options (or in code via AVOptions):
‘rtmp_swfhash’ SHA256 hash of the decompressed SWF file (32 bytes).
‘rtmp_swfsize’ Size of the decompressed SWF file, required for SWFVerification.
‘rtmp_swfurl’ URL of the SWF player for the media. By default no value will be sent.
‘rtmp_swfverify’ URL to player swf file, compute hash/size automatically.
But when I try and use rtmp_swfhash it complains about no such option. Interesting too how rtmp_swfverify is a URL not a boolean.
Anyone know how to envoke these ffmpeg parameters ?
Here is the output using ffmpeg with swfVfy as a boolean switch (swfVfy=1) and supplying the player as swfUrl. Yes I know is is not a .swf file. But it is the file that rtmpdump can verify against so I am pretty sure it is the one.
$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEaVdEaAcOdcdYaFaEdld3dRcDaHbXcIdL-bqqmOJ-8-qnl_xGrqH&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=1 swfUrl=http://www.abc.net.au/iview/images/iview.jpg"  ~/catalyst5.mp4
[image2 @ 0x99f0510] Could not find codec parameters for stream 0 (Video: mjpeg): unspecified size
rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEaVdEaAcOdcdYaFaEdld3dRcDaHbXcIdL-bqqmOJ-8-qnl_xGrqH&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=1 swfUrl=http://www.abc.net.au/iview/images/iview.jpg: could not find codec parameters
Like I said - I think ABC iView is validating on the .jpg file (that is not a jpg). When RTMPDUMP verifies on that file it reports the same SWFSize as I know works to make RTMPDUMP work without a url to automatically compute hash sizes. So it really is that .jpg file. You might be right that ffmpeg requires it to be a .swf file. But that to me reveals a bug in ffmpeg. Or at least an enhancment request for ffmpeg.
ttguy
Post Fri Aug 31, 2012 3:01 pm
So for ffmpeg swfVfy is a switch. And 0 means true right? And the .swf file could be http://www.abc.net.au/iview/iview_383.swf
So this command could do the job. Except I get this Ignoring SWFVerification request, use --swfVfy
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdOcVbvagdCatazajaCazcidcdgb4cdcj-bqqm22-8-jms_sExqN&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=0 swfUrl=http://www.abc.net.au/iview/iview_383.swf"  ~/catalyst5.mp4
But if I try and use a --swfVfy or a -swfVfy option it complains about it not being recognised. So maybe the above would work if only I could tell it to not ignore the SWFVerification request.
$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEaGaucxaHbMbBavaJbVcJdecQdWc5cMa4-bqqncC-8-lkl_uEuoN&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/iview_383.swf" -swfVfy 0 ~/catalyst5.mp4
  timescale             600.00
sampledescription:
Input #0, flv, from 'rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEaGaucxaHbMbBavaJbVcJdecQdWc5cMa4-bqqncC-8-lkl_uEuoN&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/iview_383.swf':
Unrecognized option 'swfVfy'
Failed to set value '0' for option 'swfVfy'
Post Fri Aug 31, 2012 4:40 pm
swfVfy=0 means false just as in any programming language and the parameter must be part of the url. ie: within the quotes. When you assign swfVfy=http:// etc, it is being interpreted as either true or false, probably false. If you don't want to try and find the correct .swf by sniffing, I can do no more to help you.
Post Fri Aug 31, 2012 6:45 pm
ttguy wrote:So it really is that .jpg file. You might be right that ffmpeg requires it to be a .swf file. But that to me reveals a bug in ffmpeg. Or at least an enhancment request for ffmpeg.
Post your result to ffmpeg forum. It seems to be a bug with ffmpeg.
Post Fri Aug 31, 2012 8:30 pm
Yeesh. I give up. First you set svfVfy=0 which means ignore and it tells you it is ignored, and then you use -swfVfy 0 which is invalid and it tells you so and in the absense of a valid .swf file it tells you verification is ignored again. Isn't it reasonable to expect you to get it after being told multiple times? Get a sniffer and get the valid swfUrl which will compute the hash. That's the way ffmpeg works should you choose to read its documentation.
ttguy
Post Fri Aug 31, 2012 10:01 pm
jhb50 wrote:Yeesh. I give up. First you set svfVfy=0 which means ignore and it tells you it is ignored, and then you use -swfVfy 0 which is invalid and it tells you so and in the absense of a valid .swf file it tells you verification is ignored again. Isn't it reasonable to expect you to get it after being told multiple times? Get a sniffer and get the valid swfUrl which will compute the hash. That's the way ffmpeg works should you choose to read its documentation.
I do sincerly thank you for trying to help out here. And I understand your frustrations. I still have a lot to learn about all this.
Yes I thought =0 probably meant false. But
kinda implied it meant true. So I tried it. I have tried it = 1 as shown below.
And yes I tried -swfVfy because right in the output from ffmpeg it said try --swfVfy.
And yes you have suggested sniffing my downloader. And I have. But there is no point sniffing the downloader because it is a python script and I can see eactly what it is doing - it using RTMPDUMP with --swfUrl http://www.abc.net.au/iview/images/iview.jpg
And my experiments with rtmpdump tell me that the swfUrl for validation (which in rtmpdump you can supply via the swfVfy parmamter) is a .jpeg file.
Can you explain why your think my conclusions about what the correct file is from rtmpdump are wrong?
If I use that file rtmpdump downloads the stream. If I use hash and size based on that file rtmpdump downloads the stream.
$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdqb5dpa8cha_bzarcjc.awcTc1c4bGa3-bqqs_h-8-pls_wErpM&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=1 swfUrl=http://www.abc.net.au/iview/images/iview.jpg"  ~/catalyst5.mp4
[image2 @ 0xa32d510] Could not find codec parameters for stream 0 (Video: mjpeg): unspecified size
rtmp://cp53909.edgefcs.net:1935/ondemand?auth=daEdqb5dpa8cha_bzarcjc.awcTc1c4bGa3-bqqs_h-8-pls_wErpM&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfVfy=1 swfUrl=http://www.abc.net.au/iview/images/iview.jpg: could not find codec parameters
Illico wrote:Post your result to ffmpeg forum. It seems to be a bug with ffmpeg.
Will do. Thanks Illico.
Post Sat Sep 01, 2012 1:32 am
OK. Seems strange but try these two command forms:
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app='ondemand?auth=daEcFbsaNajcBbxc3c0d3dmczbRaNaucaa5-bqqkDZ-8-klt_AEApM&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand token=daEcFbsaNajcBbxc3c0d3dmczbRaNaucaa5-bqqkDZ-8-klt_AEApM&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
ttguy
Post Sat Sep 01, 2012 6:47 am
jhb50 wrote:OK. Seems strange but try these two command forms:
Result:
$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app='ondemand?auth=daEbncNcAc.bUb2cZanb_aYaWbid9bDbIao-bqqA1f-8-mmu_xGtoL&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
rtmp server sent error
rtmp server requested close
rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app='ondemand?auth=daEbncNcAc.bUb2cZanb_aYaWbid9bDbIao-bqqA1f-8-mmu_xGtoL&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1: Unknown error occurred
jhb50 wrote:ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand token=daEcFbsaNajcBbxc3c0d3dmczbRaNaucaa5-bqqkDZ-8-klt_AEApM&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
result:
$ ffmpeg -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand token=daEdVaHdXcTcmaGbld2aSaZcMc_d9dsdgcL-bqqA4j-8-qko_AGwpH&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand token=daEdVaHdXcTcmaGbld2aSaZcMc_d9dsdgcL-bqqA4j-8-qko_AGwpH&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1: Unknown error occurred
I think the iView service has just renamed a .swf file to .jpg to obsufacte a bit. And I think ffmpeg has a bug that is revealed by this situation.
Will follow it up on ffmpeg forums or with a bug report.
ttguy
Post Sat Sep 01, 2012 12:08 pm
Running one of the jhb50 suggested commands with the -report parameter - gives a bit more info on the error. I am getting AccessManager.Reject ] : Access denied! but rtmpdump works !
 ffmpeg -report -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app='ondemand?auth=daEbQaza1aTbSa7dZbXdTavcLa9dVcEdhdX-bqqFHH-8-lkq_uEwoJ&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
Parsing...
Parsed protocol: 0
Parsed app     : mp4:flash/playback
09 9c a6 eb be 35 92 4f 3f e9 e8 ee c9 02 69 73
32 5c 46 b7 00 1a 92 43 25 d9 ba db 52 95 3c d1
HandShake: Server Uptime : 1015081557
ad 2f 28 53 92 36 bc 18 7e 3a 05 ae 4a 2e 6b 87
25 cb 7b 34 3e 95 25 40 60 38 47 0d e0 6c d4 be
c5 10 d6 4a 9e 2c 5d 0c 9f 66 53 86 93 7a 9d 35
1e 81 e7 41 8d c5 0e a6 24 ab 61 df e5 fe 64 15
2a d8 8c 13 fe c6 4d cb 33 9f bd 48 e2 b6 d8 4c
33 aa 61 3e 22 8c 30 ea 4b 81 b6 97 f4 f3 63 0b
68 67 12 7c 40 dc 3a 7f b1 44 6c dc 3f 71 17 cf
5d 55 5d 3f ac 75 d0 68 34 bf 0d 49 39 d1 57 a7
Invoking connect
RTMP_ClientPacket, received: invoke 134 bytes
(object begin)
Property: <Name:           no-name., STRING:   _error>
Property: <Name:           no-name., NUMBER:   1.00>
Property: NULL
Property: <Name:           no-name., OBJECT>
(object begin)
Property: <Name:              level, STRING:   error>
Property: <Name:               code, STRING:   NetConnection.Connect.Rejected>
Property: <Name:        description, STRING:   [ AccessManager.Reject ] : Access denied!>
(object end)
(object end)
HandleInvoke, server invoking <_error>
RTMP_ClientPacket, received: invoke 18 bytes
(object begin)
Property: <Name:           no-name., STRING:   close>
Property: <Name:           no-name., NUMBER:   0.00>
Property: NULL
(object end)
HandleInvoke, server invoking <close>
rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app='ondemand?auth=daEbQaza1aTbSa7dZbXdTavcLa9dVcEdhdX-bqqFHH-8-lkq_uEwoJ&aifp=v001' playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1: Unknown error occurred
Post Sat Sep 01, 2012 1:32 pm
Remove the single quote after v001. My error.
ttguy
Post Sat Sep 01, 2012 2:34 pm
jhb50 wrote:Remove the single quote after v001. My error.
jhb50 you legend - almost. I had to remove two single quotes.
ffmpeg -report -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand?auth=daEdzaBaJaNdmcyd3d0b9aIataUbEc8a7av-bqqHkc-8-oks_wEAqH&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
And then ... it downloads 17 mins of the file and then stops. But before it would only download 1 min.
I dunno why it stopped. Maybe just some network error or something. I am also trying this syntax in my plugin. And it appears to be working. Have 15 mins of a 30 min program to still watch from my plugin.
So it looks like I need a playpath in the rtrmp url and a playpath parameter and an app parameter. Very tricky to get this syntax right !!.
So thanks for persisting with me. !!
$ ffmpeg -report -i "rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand?auth=daEdzaBaJaNdmcyd3d0b9aIataUbEc8a7av-bqqHkc-8-oks_wEAqH&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1" /home/god/Videos/catalyst3.mp4
ffmpeg started on 2012-09-01 at 23:51:05
Report written to "ffmpeg-20120901-235105.log"
Parsing...
Parsed protocol: 0
b5 7b bb ee a5 af 85 94 a6 e9 93 e5 51 3a ed 85
db 80 0b d5 34 70 a8 f8 d6 a8 69 a9 5d ed 6a 90
HandShake: Server Uptime : 1021779178
87 f6 d0 7f 50 4c 7d 48 f6 71 d1 e3 88 19 7a ef
2a a9 16 01 ca be 16 a7 41 42 6c 9f 59 59 1b d3
67 11 5e 11 2d a7 bc 21 48 2d b8 79 9a 90 3c e1
51 a7 a6 8f 0b 35 37 92 62 2d 15 b2 d3 f6 71 2a
73 8c 07 8a 68 f8 85 3a ba 5e 0d cc f4 2c 84 fb
6f b9 b8 33 40 fe 58 23 37 2c d7 6d df 1a 96 e5
26 db 5f 5f b8 f9 93 75 ce 95 2b a4 8c f5 e3 ee
b3 ab e2 c7 e1 6e f6 98 48 c1 a3 be 46 17 c2 3a
Invoking connect
00 1b 01 01 00 00 08 4a 00 00 08 4a 44 bc e1 25
c2 09 32 83 07 83 6a 78 a0 91 0f 9d f5 a5 50 8f
51 78 f9 8b 63 fb a8 ac 20 dc a1 e3
(object begin)
Property: <Name:           no-name., STRING:   _result>
(object begin)
(object end)
(object begin)
(object begin)
(object end)
(object end)
(object end)
(object begin)
Property: <Name:           no-name., STRING:   onBWDone>
Property: NULL
(object end)
Invoking _checkbw
RTMP_ClientPacket, received: invoke 29 bytes
(object begin)
Property: <Name:           no-name., NUMBER:   2.00>
Property: NULL
(object end)
HandleInvoke, received result for method call <createStream>
SendPlay, seekTime=0, stopTime=0, sending play: mp4:flash/playback/_definst_/catalyst_13_15.mp4
Invoking play
RTMP_ClientPacket, received: invoke 10275 bytes
(object begin)
Property: <Name:           no-name., STRING:   _onbwcheck>
Property: <Name:           no-name., NUMBER:   2147492160.00>
Property: NULL
Property: <Name:           no-name., STRING:   : ) b I D 5 ( c @ A j / | s 2 ; ( Y r ; l E 8 3 p q z A 4 C " 5 h 9 $ 7 $ u z ]   ! , 3 \ - . ' H g 4 9 . { j s 2 O < ? T = > K H 7 ~ + $ K Z #   ! v 1 < m N % h 9 n G t % J M p 1 f # t % ^ u ( I ^ ) < 5 : ? @ a V O < S n [ * y N y T e * 3 P 1 F >
(object end)
HandleInvoke, server invoking <_onbwcheck>
Invoking _result
RTMP_ClientPacket, received: invoke 57 bytes
(object begin)
Property: NULL
(object end)
RTMP_ClientPacket, received: invoke 20 bytes
(object begin)
Property: NULL
(object end)
HandleInvoke, received result id 0 without matching request
HandleChangeChunkSize, received: chunk size change to 4096
HandleCtrl, received ctrl. type: 4, len: 6
HandleCtrl, Stream IsRecorded 1
HandleCtrl, received ctrl. type: 0, len: 6
HandleCtrl, Stream Begin 1
RTMP_ClientPacket, received: invoke 228 bytes
(object begin)
Property: <Name:           no-name., STRING:   onStatus>
Property: NULL
(object begin)
Property: <Name:               code, STRING:   NetStream.Play.Reset>
Property: <Name:        description, STRING:   Playing and resetting flash/playback/_definst_/catalyst_13_15.mp4.>
Property: <Name:            details, STRING:   flash/playback/_definst_/catalyst_13_15.mp4>
Property: <Name:           clientid, STRING:   R1ZAIEhx>
(object end)
(object end)
HandleInvoke, server invoking <onStatus>
HandleInvoke, onStatus: NetStream.Play.Reset
RTMP_ClientPacket, received: invoke 222 bytes
(object begin)
Property: NULL
(object begin)
Property: <Name:               code, STRING:   NetStream.Play.Start>
Property: <Name:        description, STRING:   Started playing flash/playback/_definst_/catalyst_13_15.mp4.>
(object end)
(object end)
HandleInvoke, onStatus: NetStream.Play.Start
RTMP_ClientPacket, received: notify 24 bytes
(object begin)
Property: <Name:           no-name., STRING:   |RtmpSampleAccess>
Property: <Name:           no-name., BOOLEAN:   FALSE>
(object end)
ignoring too small audio packet: size: 0
RTMP_ClientPacket, received: notify 44 bytes
(object begin)
(object begin)
Property: <Name:               code, STRING:   NetStream.Data.Start>
(object end)
(object end)
RTMP_ClientPacket, received: notify 592 bytes
(object begin)
Property: <Name:           no-name., STRING:   onMetaData>
(object begin)
Property: <Name:           duration, NUMBER:   1624.33>
Property: <Name:       moovPosition, NUMBER:   36.00>
Property: <Name:              width, NUMBER:   640.00>
Property: <Name:             height, NUMBER:   360.00>
Property: <Name:       videocodecid, STRING:   avc1>
Property: <Name:       audiocodecid, STRING:   mp4a>
Property: <Name:         avcprofile, NUMBER:   77.00>
Property: <Name:           avclevel, NUMBER:   31.00>
Property: <Name:             aacaot, NUMBER:   2.00>
Property: <Name:     videoframerate, NUMBER:   25.00>
Property: <Name:    audiosamplerate, NUMBER:   44100.00>
Property: <Name:      audiochannels, NUMBER:   2.00>
Property: <Name:          trackinfo, OBJECT>
(object begin)
(object begin)
Property: <Name:             length, NUMBER:   974616.00>
Property: <Name:          timescale, NUMBER:   600.00>
Property: <Name:  sampledescription, OBJECT>
(object begin)
(object begin)
Property: <Name:         sampletype, STRING:   avc1>
(object end)
(object end)
(object end)
(object begin)
Property: <Name:             length, NUMBER:   71632858.00>
Property: <Name:          timescale, NUMBER:   44100.00>
(object begin)
(object begin)
Property: <Name:         sampletype, STRING:   mp4a>
(object end)
(object end)
(object end)
(object begin)
Property: <Name:             length, NUMBER:   600.00>
(object begin)
(object end)
(object end)
(object begin)
(object begin)
(object end)
(object end)
(object end)
(object end)
(object end)
  duration              1624.33
  moovPosition          36.00
  width                 640.00
  height                360.00
  videocodecid          avc1
  audiocodecid          mp4a
  avcprofile            77.00
  avclevel              31.00
  aacaot                2.00
  audiochannels         2.00
trackinfo:
  length                974616.00
  timescale             600.00
sampledescription:
  sampletype            avc1
  length                71632858.00
  timescale             44100.00
sampledescription:
  sampletype            mp4a
  length                600.00
  timescale             600.00
sampledescription:
  length                600.00
  timescale             600.00
sampledescription:
Input #0, flv, from 'rtmp://cp53909.edgefcs.net:1935/mp4:flash/playback/_definst_/catalyst_13_15.mp4 app=ondemand?auth=daEdzaBaJaNdmcyd3d0b9aIataUbEc8a7av-bqqHkc-8-oks_wEAqH&aifp=v001 playpath=mp4:flash/playback/_definst_/catalyst_13_15.mp4 swfUrl=http://www.abc.net.au/iview/images/iview.jpg swfVfy=1':
    moovPosition    : 36
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    videoframerate  : 25
    audiochannels   : 2
File '/home/god/Videos/catalyst3.mp4' already exists. Overwrite ? [y/N] y
w:640 h:360 pixfmt:yuv420p tb:1/1000 fr:25/1 sar:1/1 sws_param:flags=2
[graph 1 input from stream 0:1 @ 0xad8e220] tb:1/44100 samplefmt:s16 samplerate:44100 chlayout:0x3
[libx264 @ 0xadaa650] using SAR=1/1
[libx264 @ 0xadaa650] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle Cache64
[libx264 @ 0xadaa650] profile High, level 3.0
[libx264 @ 0xadaa650] 264 - core 120 r2151 a3f4407 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=3 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to '/home/god/Videos/catalyst3.mp4':
    moovPosition    : 36
    avcprofile      : 77
    avclevel        : 31
    aacaot          : 2
    videoframerate  : 25
    audiochannels   : 2
Stream mapping:
*** 1 dup!
HandleCtrl, received ctrl. type: 6, len: 6 time=00:01:27.86 bitrate= 554.0kbits/s dup=1 drop=0
HandleCtrl, Ping 1021871023
sending ctrl. type: 0x0007
HandleCtrl, received ctrl. type: 6, len: 6 time=00:06:40.54 bitrate= 519.1kbits/s dup=1 drop=0
HandleCtrl, Ping 1022171964
HandleCtrl, received ctrl. type: 6, len: 6 time=00:10:45.70 bitrate= 617.6kbits/s dup=1 drop=0
HandleCtrl, Ping 1022471974
HandleCtrl, received ctrl. type: 6, len: 6 time=00:14:36.36 bitrate= 675.3kbits/s dup=1 drop=0
HandleCtrl, Ping 1022771985
WriteN, RTMP send error 104 (5 bytes)275kB time=00:17:15.00 bitrate= 659.1kbits/s dup=1 drop=0
Return to Plugin development
Users browsing this forum: Baidu [Spider] and 1 guest
