Retrieve metadata in certain language
matmat07
Post Tue Dec 04, 2012 1:01 am
How does this work? For example, this file: My.Series.3x17.title.FR.avi has the "FR" tag which means it's in french. Will Serviio recognize that and fetch a french title? Should it say "français"?
Post Tue Dec 04, 2012 11:06 am
Re: Retrieve metadata in certain language
You can select the language in the console, on Metadata tab. It's not per file.
matmat07
Post Tue Dec 04, 2012 10:10 pm
What does it do? Because the console language is changed in the console setting tab
Post Wed Dec 05, 2012 11:13 pm
Console language and metadata language are two different settings.
sbec67
Post Thu Dec 06, 2012 3:17 pm
a naming in the File Name to select the Language would be cool.... :)
Something similar to Season / Episode in the TV-Series (S01E01)
Something like L_DE / L_EN /L_FR
Greetz
Sbec
r-win
Post Thu Dec 06, 2012 3:53 pm
sbec67 wrote:a naming in the File Name to select the Language would be cool.... :)
Ew, sounds like a dirty hack to me. Why don't you retrieve the meta data in a different language using some kind of tool which is capable of XBMC nfo files?
If you use nfo files, you're in control!
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
matmat07
Post Fri Dec 07, 2012 12:41 am
zip wrote:Console language and metadata language are two different settings.
Can you be clear on what the two does? I still don't understand what metadata does
Post Fri Dec 07, 2012 2:11 pm
It'll load french metadata (title, description, etc) from the online databases, if available.
matmat07
Post Sat Dec 08, 2012 10:23 pm
but it cannot detect language in the title right?
Post Sun Dec 09, 2012 12:21 am
No, it'll use the language as selected in the console.
matmat07
Post Sun Dec 09, 2012 7:24 pm
Thanks now I understand :) Now going to post this as an requested feature :P if not asking too much
