Retrieve metadata in certain language
• Page 1 of 1
How does this work? For example, this file: My.Series.3x17.title.FR.avi has the "FR" tag which means it's in french. Will Serviio recognize that and fetch a french title? Should it say "français"?
Re: Retrieve metadata in certain language
You can select the language in the console, on Metadata tab. It's not per file.
Petr
Help translate Serviio
What does it do? Because the console language is changed in the console setting tab
Console language and metadata language are two different settings.
Petr
a naming in the File Name to select the Language would be cool....
Something similar to Season / Episode in the TV-Series (S01E01)
Something like L_DE / L_EN /L_FR
Greetz
Sbec
Greetz
Sbec
sbec67 wrote:a naming in the File Name to select the Language would be cool....![]()
Ew, sounds like a dirty hack to me. Why don't you retrieve the meta data in a different language using some kind of tool which is capable of XBMC nfo files?
If you use nfo files, you're in control!
Linksys WRT320N | Samsung PS-50C7700 | Microsoft XBOX 360 | Windows 8.1 | Linux Ubuntu 13.04
zip wrote:Console language and metadata language are two different settings.
Can you be clear on what the two does? I still don't understand what metadata does
It'll load french metadata (title, description, etc) from the online databases, if available.
Petr
but it cannot detect language in the title right?
No, it'll use the language as selected in the console.
Petr
Thanks now I understand
Now going to post this as an requested feature
if not asking too much
• Page 1 of 1
Users browsing this forum: Google [Bot] and 25 guests
