Sharp Aquos DLNA Profiles
LeonScottKennedy
Post Sun Jan 06, 2013 9:50 pm
dear community.
i've a problem with my Sharp Aquos LC-46LE824E and the profiles from serviio, i want to play '.avi' Files i set the profile to 'Panasonic Viera E/S/ST/VT (2011)' with this Settings i can't see '.mkv' files in the folders, when i switch to 'Samsung TV (A-Series)' i can play without any problems ".mkv" files. with the Samsung profile i can see all the other ".avi" files with the playtime but when i press play, the video will not start.
i think the Sharp DLNA Client is very bad, i can't stop, resume, rewind or forward from any video file. all files will start at a playtime from 11 secounds, iv'e no settings found to change or modify this problem.
which way should be go to play all files with only one profile? at the moment i switch the profiles with the 'serviidroid' android application from my couch but this is not realy a good solution.
lsk
slyguy42o
Post Mon Jan 07, 2013 4:23 pm
Re: Sharp Aquos DLNA Profiles
so does it not work properly with the "Sharp Aquos" profile?
Serviio does it's best to auto detect the device but some devices don't ID themselves properly so you have to select the proper profile manually.
You shouldn't have to switch profiles around, the profile set provided has support for a pretty descent chunk of devices out there but in some cases manual profile tweaking is required for TV's that don't fall within the provided configs.
If your finding that the Sharp Aquos profile is not working for some file types, you will need to do a bit of tweaking to get different types to play.
LeonScottKennedy
Post Mon Jan 07, 2013 7:20 pm
when i use the "Sharp Aquos" profile than i can't see or browse anything, no movies, no series. with a lot of other profiles i can see the files but no playback.
so i think the 'Sharp Aquos' profile doesn't work.
lsk
slyguy42o
Post Mon Jan 07, 2013 7:53 pm
ok, does it work if you set "generic DLNA profile" ? This config *should* work for your TV as it transcodes everything regardless of format.
For best results you will need to take the working parts of the Samsung and Panasonic profiles and use those as a baseline to modify the Sharp profile for your TV
Here is a guide on profile editing.
http://www.serviio.org/index.php?option ... icle&id=16
kaisersoze
Post Tue Jan 08, 2013 8:08 am
LeonScottKennedy wrote:when i use the "Sharp Aquos" profile than i can't see or browse anything, no movies, no series. with a lot of other profiles i can see the files but no playback.
lsk
I have Sharp Aquos LC-40LE924E so pretty much the same TV and pretty much the same problem.
This resolved my problems with avi files.
Added this part to Sharp Aquos profile:
<Matches container="avi" vCodec="mpeg4" />
<Matches container="avi" vCodec="msmpeg4" />
Actually copied from Sony Bravia 2012 US profile.
Please see posts:
viewtopic.php?f=6&t=63&start=210#p59862
viewtopic.php?f=5&t=4671&start=40#p55461
kaisersoze
Post Wed Feb 20, 2013 7:54 am
Does anyone have problems with the Playback controls (FF, RW, Pause, Play) as I have - it is not working well?
Sharp Aquos Model LC-40LE924E (similar as 814/824/925)
I found this topic
viewtopic.php?f=5&t=2921#p18484
but profile from this topic does not solve my problem.
All videos are transcoded as targetVCodec="mpeg2video" and tested with mpegts and mpeg containers, it is playing well (avi and mkv) but Playback controls does not work properly.
I suppose Tv is confused about size and time during transcoding and streaming.
Any suggestions?
kaisersoze
Post Tue Mar 05, 2013 7:30 am
kaisersoze wrote:Does anyone have problems with the Playback controls (FF, RW, Pause, Play) as I have - it is not working well?
I found this topic
Any suggestions?
With Serviio 1.2 the same problem.
Playback controls does not work properly on Sharp Aquos (FF, RW, Pause).
I will be satisfied with Pause only :)
Pause does freeze(pause) the Movie, but after resume it is not continued on proper place - part of Movie is skipped. (both mkv and avi)
Does anyone has an idea how to solve problem?
kaisersoze
Post Sun Mar 17, 2013 9:58 pm
I found this topic
Any suggestions?
Debug lines:
2013-03-17 22:36:00,940 DEBUG [GETMethodProcessor] Delivering bytes 170598400 - 50000000000 from transcoded file, based on time range 1026 - 7314
2013-03-17 22:37:24,828 DEBUG [GETMethodProcessor] Delivering bytes 349318144 - 50000000000 from transcoded file, based on time range 2111 - 7314
2013-03-17 22:38:14,782 DEBUG [GETMethodProcessor] Delivering bytes 256987551 - 50000000000 from transcoded file, based on time range 4234 - 7314
2013-03-17 22:39:27,293 DEBUG [GETMethodProcessor] Delivering bytes 445344684 - 50000000000 from transcoded file, based on time range 5807 - 7314
So I paused movie about every minute or so.
From debug lines - does anyone knows why are time ranges so strange and why Pause function skips part of the movie (avi, mkv all the same).
It is pretty useless to watch movies without playback functions - at least pause.
Does anyone has any idea?
Profile (everything else is same as Sharp Aquos Profile):
<Matches container="matroska" vCodec="h264" aCodec="ac3"/>
<Matches container="matroska" vCodec="h264" aCodec="mp3"/>
<Matches container="flv" vCodec="h264"/>
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="mp4" />
<Matches container="asf" />
<Matches container="rm" />
<Matches container="avi" />
<Matches container="flac" />
<Matches container="ogg" />
<Matches container="mp3" />
</Audio>
Post Sun Mar 17, 2013 11:31 pm
try some other profile, starting with Generic. Looks like the TV doesn't play nice with transcoded files.
kaisersoze
Post Wed Mar 20, 2013 8:56 pm
Maybe I'm an annoying but tried more or less every profile and couldn't solve Pause issue.
Could someone explain debug lines:
Debug lines:
What is delivering bytes (bytes sent from Serviio?), what is time range (timestamp from TV?)?
Problem is as follows:
After every Pause movie time is doubled.
So after 1min, Pause is pressed. I suppose then Serviio send only part of the movie from 1min but TV somehow remembers that Pause is pressed on 1min and Movie continues on 2min. After next Pause Movie continues on 4min and so on.
Is it possible to somehow configure that Serviio always sending whole movie?
Thanks in advance
Post Thu Mar 21, 2013 10:18 pm
the TV makes a request for time range of the file, if it asks for a wrong time range Serviio can do nothing about it.
It seems it should work like this:
- you play the file from the beginning (range 0 - end)
- you pause at 5 seconds
- you press play (tv asks for range 5 - end)
If the TV somehow asks for double start time, not much I can do.
kaisersoze
Post Fri Mar 22, 2013 10:30 am
Any chance of "pre-transcoding"?
Like noticed on following link:
http://forum.conceiva.com/showthread.ph ... #post12393
Post Fri Mar 22, 2013 4:02 pm
I don't think so.
LeonScottKennedy
Post Sun Apr 14, 2013 4:09 pm
Now i have .mkv Files that my Sharp will not playback, but i don't know why.
FF, FR, Stop or other commands will not work only press play. :)
lsk
LeonScottKennedy
Post Wed Apr 17, 2013 9:13 am
I installed Serviio new, with removing all old files and settings. the tv starts and i setup the 'Samsung - B' profile...
with this file will it work,
File size                                : 878 MiB
Duration                                 : 20min
Overall bit rate                         : 6 062 Kbps
Encoded date                             : UTC 2013-01-28 20:51:33
Writing application                      : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 13 2011 06:24:21
Writing library                          : libebml v1.2.2 + libmatroska v1.3.0
Format profile                           : High@L4.0
Format settings, CABAC                   : Ja
Duration                                 : 20min
Bit rate                                 : 5 365 Kbps
Width                                    : 1 920 Pixel
Height                                   : 1 080 Pixel
Frame rate mode                          : konstant
Frame rate                               : 25,000 FPS
Scan type                                : progressiv
Bits/(Pixel*Frame)                       : 0.103
Stream size                              : 777 MiB (89%)
Language                                 : Deutsch
Default                                  : Ja
Forced                                   : Ja
colour_primaries                         : BT.709
transfer_characteristics                 : BT.709
matrix_coefficients                      : BT.709
Audio #1
Format profile                           : Dolby Digital
Duration                                 : 20min
Bit rate mode                            : konstant
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 Kanäle
Sampling rate                            : 48,0 KHz
Stream size                              : 27,8 MiB (3%)
Language                                 : Deutsch
Default                                  : Ja
Forced                                   : Ja
Audio #2
Duration                                 : 20min
Bit rate                                 : 384 Kbps
Channel(s)                               : 6 Kanäle
Stream size                              : 55,6 MiB (6%)
Language                                 : Englisch
Default                                  : Nein
Forced                                   : Nein
And with this file the TV return in error 'can't play video file'
File size                                : 609 MiB
Duration                                 : 21mn 59s
Overall bit rate                         : 3 873 Kbps
Writing application                      : HandBrake 0.9.8
Writing library                          : libmkv 0.6.5
Format profile                           : Main@L3.0
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Bit rate                                 : 3 348 Kbps
Width                                    : 720 pixels
Height                                   : 576 pixels
Frame rate mode                          : Variable
Standard                                 : PAL
Writing library                          : x264 core 120
Encoding settings                        : cabac=0 / ref=1 / deblock=0:0:0 / analyse=0:0 / me=dia / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=0 / intra_refresh=0 / rc=crf / mbtree=0 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=0
Color primaries                          : BT.601 NTSC
Matrix coefficients                      : BT.601
Audio #1
Duration                                 : 21mn 59s
Bit rate                                 : 224 Kbps
Stream size                              : 35.2 MiB (6%)
Language                                 : German
Audio #2
Duration                                 : 21mn 59s
Bit rate                                 : 224 Kbps
Text #1
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Text #2
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Language                                 : German
Menu
00:00:00.000                             : Chapter 1
00:06:07.688                             : Chapter 2
00:15:10.248                             : Chapter 3
00:20:44.688                             : Chapter 4
00:21:58.728                             : Chapter 5
can someone help me to modify the 'Profile' for my TV to play all video files?
Post Wed Apr 17, 2013 11:28 am
Did you tyr the Sharp profile?
THese files look very similar, probably something in the way the file is encoded that is breaking compatibility.
LeonScottKennedy
Post Wed Apr 17, 2013 9:26 pm
zip wrote:Did you tyr the Sharp profile?
Of course but without any solution, on my Sharp TV with the Sharp profile it will play nothing, no .mkv no .avi.
in the serviio version before the last two releases 1.9 iirc?! my Sharp tv play with the stock 'Samsung B' profile these two .mkv files.
kaisersoze
Post Thu Apr 18, 2013 5:56 pm
Maybe this helps.
My profile for Sharp Aquos LE924E - please see bellow.
It is working with all my video files (avi, mkv etc.)
"Only" problems are pause, FF, RW
<Profile id="19" name="Sharp Aquos" extendsProfileId="1">
<Detection>
<HttpHeaders>
<User-Agent>.*SHARP-AQUOS.*</User-Agent>
</HttpHeaders>
</Detection>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/mpeg" name="MPEG_TS_SD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_3GPP_SP_L0B_AMR</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
</MediaFormatProfiles>
</Audio>
<OnlineTranscoding>
</OnlineTranscoding>
kaisersoze
Post Sat Apr 20, 2013 6:18 am
Could someone help me with following:
This video plays:
Input #0, matroska,webm, from 'crtani/The.Incredibles.(2004).HRsink.720p/The Incredibles (2004) 1080p.HDTV.Hr Audio-badw.mkv':
ENCODER : Lavf54.49.102
Duration: 01:50:34.65, start: 0.000000, bitrate: 3605 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
Stream #0:1(hrv): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
This video doesn't play:
Input #0, matroska,webm, from 'dokumentarni/BBC.Setnja.s.dinosaurima.E01-E06.DVDRip.HRSink.x264/E01 - Nova krv.mkv':
creation_time : 2013-03-05 13:06:17
Duration: 00:29:09.60, start: 0.000000, bitrate: 1001 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 640x464 [SAR 1:1 DAR 40:29], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
Stream #0:1: Audio: ac3, 48000 Hz, stereo, fltp, 128 kb/s (default)
My profile is above.
Of course when I comment
<!--Matches container="matroska" vCodec="h264" aCodec="ac3"/--> both videos will be transcoded and working but how should I distinct those two videos and for first to set up only remuxing and for second transcoding.
Thanks in advance
Post Mon Apr 22, 2013 12:01 pm
No way to distinguish, unless they have different H264 profiles/levels.
