Streaming MKV to BDP-S590 (subtitle charset)
rricardi
Post Sun Oct 13, 2013 4:43 pm
Hi all,
I am trying to stream a MKV video to my Sony BDP-S590 with subtitles of different languages in the MKV file.
Audio and video runs smooth, sutbtitles are shown as well BUT with strange characters. Maybe the charset (ANSI, UTF-8 or other) might be changed, maybe adjust Serviio, maybe both...
I am also considering buying a WD Live, they say it works perfectly, but I prefer one last shot with Serviio.
Anyone could help me please? I can obviously provide extra information it needed.
Many thanks in advance!
Post Sun Oct 13, 2013 6:29 pm
Re: Streaming MKV to BDP-S590 (subtitle charset)
rricardi wrote:...sutbtitles are shown as well BUT with strange characters. Maybe the charset (ANSI, UTF-8 or other) might be changed, maybe adjust Serviio, maybe both...
Indeed, both the console and subtitles must have the same charset.
Could you provide MediaInfo tools result of your mkv file, and "ffmpeg -i" ? (see my signature link)
rricardi
Post Sun Oct 13, 2013 10:17 pm
Hi Illico, many thanks for replying. Please find below requested information:
ffmpeg
C:\Archivos de programa\Serviio\lib>ffmpeg.exe -i "c:\Documents and Settings\Rod
rigo Ricardi\Escritorio\Filmes\Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-B
RENYS\Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-BRENYS.mkv"
Input #0, matroska,webm, from 'c:\Documents and Settings\Rodrigo Ricardi\Escrito
rio\Filmes\Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-BRENYS\Truque.de.Mest
re.2013.720p.BluRay.x264.HDC.DUAL-BRENYS.mkv':
    title           : Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-BRENYS
    creation_time   : 2013-09-03 06:47:10
  Duration: 01:55:22.80, start: 0.000000, bitrate: 6621 kb/s
    Stream #0:0: Video: h264 (High), yuv420p, 1280x534 [SAR 1:1 DAR 640:267], 23
.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(por): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
      title           : Portugues AC3 5.1- BRENYS
    Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s
MediaInfo
Unique ID                                : 217716142459930392107666227544910899897 (0xA3CA9A938DFF75928FD82F6E4FCAAAB9)
Complete name                            : C:\Documents and Settings\Rodrigo Ricardi\Escritorio\Filmes\Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-BRENYS\Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-BRENYS.mkv
Format version                           : Version 4 / Version 2
File size                                : 5.34 GiB
Duration                                 : 1h 55mn
Overall bit rate                         : 6 622 Kbps
Movie name                               : Truque.de.Mestre.2013.720p.BluRay.x264.HDC.DUAL-BRENYS
Encoded date                             : UTC 2013-09-03 06:47:10
Writing application                      : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Writing library                          : libebml v1.3.0 + libmatroska v1.4.0
Format settings, ReFrames                : 12 frames
Duration                                 : 1h 55mn
Bit rate                                 : 5 594 Kbps
Height                                   : 534 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.341
Stream size                              : 4.51 GiB (84%)
Writing library                          : x264 core 136 r2348+704+51 d1baef6 tMod [8-bit@all X86_64]
Encoding settings                        : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=17.0000 / qcomp=0.60 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=50000 / vbv_bufsize=62500 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0
Audio #1
Duration                                 : 1h 55mn
Bit rate                                 : 448 Kbps
Delay relative to video                  : 1s 870ms
Stream size                              : 370 MiB (7%)
Title                                    : Portugues AC3 5.1- BRENYS
Language                                 : Portuguese
Audio #2
Duration                                 : 1h 55mn
Bit rate                                 : 448 Kbps
Thanks a lot for helping once again!
Post Mon Oct 14, 2013 7:07 am
rricardi wrote:Hi Illico, many thanks for replying. Please find below requested information:
No subtitle tracks in you mkv file, only two audio tracks (Portuguese,English)?
- Do you have an external subtitle file (srt, sub, etc.).
- Does video track already has subtitle burned into frames ?
rricardi
Post Tue Oct 15, 2013 12:17 am
Geez... wrong file Illico! My apologies.
Please find below the right one:
MediaInfo
Unique ID                                : 254837004249313595859621638559529517217 (0xBFB7D25DB1DDBC9A9E13EBB38ADD40A1)
Complete name                            : C:\Documents and Settings\Rodrigo Ricardi\Escritorio\Filmes\The.Internship.2013.UNRATED.1080p.WEB-DL.H264-PHD\The.Internship.2013.UNRATED.1080p.WEB-DL.H264-PHD.mkv
File size                                : 4.09 GiB
Duration                                 : 2h 5mn
Overall bit rate                         : 4 679 Kbps
Encoded date                             : UTC 2013-10-01 08:25:29
Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format profile                           : High@L4.0
Format settings, ReFrames                : 5 frames
Duration                                 : 2h 5mn
Height                                   : 810 pixels
Audio #1
Duration                                 : 2h 5mn
Bit rate                                 : 384 Kbps
Stream size                              : 344 MiB (8%)
Audio #2
Codec ID                                 : A_AAC
Duration                                 : 2h 5mn
Language                                 : Spanish
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Text #2
Format                                   : UTF-8
Language                                 : French
Text #3
Format                                   : UTF-8
Language                                 : Spanish
Text #4
Format                                   : UTF-8
Menu
00:00:00.000                             : en:Chapter 1
00:05:27.000                             : en:Chapter 2
00:07:50.000                             : en:Chapter 3
00:14:21.000                             : en:Chapter 4
00:19:40.000                             : en:Chapter 5
00:25:58.000                             : en:Chapter 6
00:28:59.000                             : en:Chapter 7
00:32:35.000                             : en:Chapter 8
00:35:04.000                             : en:Chapter 9
00:36:18.000                             : en:Chapter 10
00:41:51.000                             : en:Chapter 11
00:44:34.000                             : en:Chapter 12
00:48:04.000                             : en:Chapter 13
00:50:39.000                             : en:Chapter 14
00:58:27.000                             : en:Chapter 15
01:02:17.000                             : en:Chapter 16
01:06:08.000                             : en:Chapter 17
01:11:12.000                             : en:Chapter 18
01:14:02.000                             : en:Chapter 19
01:15:46.000                             : en:Chapter 20
01:18:51.000                             : en:Chapter 21
01:21:27.000                             : en:Chapter 22
01:24:10.000                             : en:Chapter 23
01:26:07.000                             : en:Chapter 24
01:27:57.000                             : en:Chapter 25
01:29:37.000                             : en:Chapter 26
01:31:39.000                             : en:Chapter 27
01:37:15.000                             : en:Chapter 28
01:42:32.000                             : en:Chapter 29
01:48:12.000                             : en:Chapter 30
01:54:18.000                             : en:Chapter 31
01:57:36.000                             : en:Chapter 32
ffmpeg
\The.Internship.2013.UNRATED.1080p.WEB-DL.H264-PHD.mkv"
.UNRATED.1080p.WEB-DL.H264-PHD.mkv':
    creation_time   : 2013-10-01 08:25:29
  Duration: 02:05:15.35, start: 0.000000, bitrate: 4679 kb/s
    Chapter #0.0: start 0.000000, end 327.000000
      title           : Chapter 1
    Chapter #0.1: start 327.000000, end 470.000000
      title           : Chapter 2
    Chapter #0.2: start 470.000000, end 861.000000
      title           : Chapter 3
    Chapter #0.3: start 861.000000, end 1180.000000
      title           : Chapter 4
    Chapter #0.4: start 1180.000000, end 1558.000000
      title           : Chapter 5
    Chapter #0.5: start 1558.000000, end 1739.000000
      title           : Chapter 6
    Chapter #0.6: start 1739.000000, end 1955.000000
      title           : Chapter 7
    Chapter #0.7: start 1955.000000, end 2104.000000
      title           : Chapter 8
    Chapter #0.8: start 2104.000000, end 2178.000000
      title           : Chapter 9
    Chapter #0.9: start 2178.000000, end 2511.000000
      title           : Chapter 10
    Chapter #0.10: start 2511.000000, end 2674.000000
      title           : Chapter 11
    Chapter #0.11: start 2674.000000, end 2884.000000
      title           : Chapter 12
    Chapter #0.12: start 2884.000000, end 3039.000000
      title           : Chapter 13
    Chapter #0.13: start 3039.000000, end 3507.000000
      title           : Chapter 14
    Chapter #0.14: start 3507.000000, end 3737.000000
      title           : Chapter 15
    Chapter #0.15: start 3737.000000, end 3968.000000
      title           : Chapter 16
    Chapter #0.16: start 3968.000000, end 4272.000000
      title           : Chapter 17
    Chapter #0.17: start 4272.000000, end 4442.000000
      title           : Chapter 18
    Chapter #0.18: start 4442.000000, end 4546.000000
      title           : Chapter 19
    Chapter #0.19: start 4546.000000, end 4731.000000
      title           : Chapter 20
    Chapter #0.20: start 4731.000000, end 4887.000000
      title           : Chapter 21
    Chapter #0.21: start 4887.000000, end 5050.000000
      title           : Chapter 22
    Chapter #0.22: start 5050.000000, end 5167.000000
      title           : Chapter 23
    Chapter #0.23: start 5167.000000, end 5277.000000
      title           : Chapter 24
    Chapter #0.24: start 5277.000000, end 5377.000000
      title           : Chapter 25
    Chapter #0.25: start 5377.000000, end 5499.000000
      title           : Chapter 26
    Chapter #0.26: start 5499.000000, end 5835.000000
      title           : Chapter 27
    Chapter #0.27: start 5835.000000, end 6152.000000
      title           : Chapter 28
    Chapter #0.28: start 6152.000000, end 6492.000000
      title           : Chapter 29
    Chapter #0.29: start 6492.000000, end 6858.000000
      title           : Chapter 30
    Chapter #0.30: start 6858.000000, end 7056.000000
      title           : Chapter 31
    Chapter #0.31: start 7056.000000, end 7515.349000
      title           : Chapter 32
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x810 [SAR 1:1 DAR 64:27],
 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default)
    Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
    Stream #0:2(spa): Audio: aac, 48000 Hz, stereo, fltp
    Stream #0:3(eng): Subtitle: subrip
    Stream #0:4(fre): Subtitle: subrip
    Stream #0:5(spa): Subtitle: subrip
    Stream #0:6(por): Subtitle: subrip
Many thanks indeed!
Post Tue Oct 15, 2013 7:31 am
The embedded subtitles are in UTF-8, so on serviio console, you have to set the same charset value (UTF-8).
Could you enable detailed logging and post here the log section where the embedded sub were extracted (ffmepg command line)?
Could you extract the subtitles with mkvmerge tools and post here one with wrong character ?
