Mediabrowser UTF-8
howi42
Post Tue Oct 15, 2013 6:47 pm
Mediabrowser UTF-8
Is there a way to let the mediabrowser display UTF-8 encoded characters correctly ?
In my case this is about german special characters which are displayed wrongly.
malabarth
Post Wed Oct 16, 2013 7:40 pm
Re: Mediabrowser UTF-8
Yep, it's a real problem.
For example, /raid/Séries is not a valid path, the scan don't event get inside the folder.
But when I rename it to /raid/Series, it's fully working.
I hope It will be fixed soon.
Post Wed Oct 16, 2013 8:34 pm
2 different things. If the characters re in the file path and not added to library, you have to fix your locale settings on Linux to be UTF-8, otherwise Java will ignore it.
For showing in MediaBrowser, can you post an image?
howi42
Post Sun Oct 20, 2013 8:35 pm
Snapshots attached; the same 2 dirs in Windows and the mediabrowser. In this case french characters
Post Mon Oct 21, 2013 8:00 pm
Did you try to change website encoding to UTF-8 in the browser?
howi42
Post Tue Oct 22, 2013 8:45 am
Makes no difference.
When I see the page in the browser, it is probably already too late.
